Old 04-06-2009, 11:34   #16 (permalink)
Member: 370837
Thanks Meter: 5
Smile
just change flex it's works 101% good job
Old 04-08-2009, 19:24   #17 (permalink)
Member: 451174
Thanks Meter: 1
my n81 problem was when i on it it sayed (feature not supported) i change R2500 now its working 100% thank u and gsm forum
Old 04-12-2009, 08:17   #18 (permalink)
Member: 68833
Thanks Meter: 68
work for me .....just bypass with wire
thanks for this solution
The Following User Says Thank You to ahhongchai For This Useful Post:
Old 05-20-2009, 11:36   #19 (permalink)
Babak's Avatar
Member: 32731
Thanks Meter: 1
Originally Posted by srv View Post
tri this and post result
N2530 Removed And Made The Connection
Worked !
Thanks
Old 06-20-2009, 16:26   #20 (permalink)
Member: 99639
Thanks Meter: 20
n81 camer
trai 100% ok ....................................
The Following 5 Users Say Thank You to BIJAR For This Useful Post:
Old 07-01-2009, 12:58   #21 (permalink)
gsmstroong's Avatar
Member: 302306
Thanks Meter: 44
Thanks tostefo
thanks for solution
GSM STROONG
Old 07-01-2009, 15:05   #22 (permalink)
Member: 249798
Thanks Meter: 1
chang flex cable 100% working with me
Old 07-10-2009, 20:48   #23 (permalink)
qpraba's Avatar
Member: 112404
Thanks Meter: 21
me too its flex cable problem
Old 07-15-2009, 04:54   #24 (permalink)
Registered User
Member: 928411
Thanks Meter: 25
Change cable 1000% ok
Old 11-29-2009, 11:02   #25 (permalink)
Member: 558794
where can i found the R2500 in the board?
Old 11-30-2009, 22:18   #26 (permalink)
Teepat's Avatar
Member: 599669
Thanks Meter: 115
bro jus t replace only the flex cable(connector)
Old 12-01-2009, 05:40   #27 (permalink)
Member: 482670
Thanks Meter: 125
rehot components ( r2530, n2530, c2530, L2520, if still same then change D2500 camera ic )
check out r2530,c2530 2.8v,L2520 1.8v ,if bad camera will not support
The Following 4 Users Say Thank You to Brother Hui For This Useful Post:
Old 12-19-2009, 13:26   #28 (permalink)
Member: 1063978
nice info master's..................
Old 12-21-2009, 09:12   #29 (permalink)
Member: 980727
Thanks Meter: 4
Originally Posted by Don_R View Post
Change N2531 worked 4 me
hi all
just change flex cable for this camera feature not supported problem
The Following 2 Users Say Thank You to indiawala For This Useful Post:
Old 12-21-2009, 09:17   #30 (permalink)
kashantariq2002's Avatar
Member: 1019981
Thanks Meter: 98
thanks for good work
N81 camera problem success repair... watari31 Nokia Hardware & Hardware Repair 3 12-30-2010 12:10
Nokia n81 camera problem transpirit Nokia Base Band 5 ( BB-5 ) 4 12-08-2009 05:06
nokia n81 keypad problem solution pls ??? roney_nexus Nokia Hardware & Hardware Repair 3 05-15-2009 04:50
n81 camera problem shami61 Nokia Hardware & Hardware Repair 2 02-08-2009 18:33
!!!E900 Camera problem Solution Here !!! SiRoYa UST Pro II 24 02-23-2007 02:55
Page generated in 0.18876 seconds with 10 queries
