Old 08-26-2008, 20:47   #1 (permalink)
mohammed-anis's Avatar
Member: 751223
Sonork: mobilecenter88
Thanks Meter: 538
1200,1208,1650 blue screen 100000000000000% solution tested
only blue light stand outgoing incoming not ok
complete flashing ui but set same condition
so change display connector
self test with hwk see lcd unknown this is connector problem
tested with 11 set
The Following 188 Users Say Thank You to mohammed-anis For This Useful Post:
Old 08-26-2008, 23:35   #2 (permalink)
qureshi7's Avatar
Member: 629260
Thanks Meter: 74
oh realy bt i cant understand
is lcd conector is short ther 4 thiz problm is came?
The Following 13 Users Say Thank You to qureshi7 For This Useful Post:
Old 08-27-2008, 15:05   #3 (permalink)
Member: 751223
Thanks Meter: 538
try one 100%...................
The Following 5 Users Say Thank You to mohammed-anis For This Useful Post:
Old 09-19-2008, 14:46   #4 (permalink)
Member: 371754
Thanks Meter: 24
tested by me 100% ok
The Following 8 Users Say Thank You to aduhaii_HP For This Useful Post:
Old 09-27-2008, 16:13   #5 (permalink)
Member: 695304
Thanks Meter: 20
i have Nokia 1200 with water dameg dispaly is yellow after few secon plz help
me
The Following 10 Users Say Thank You to naeem? For This Useful Post:
Old 09-29-2008, 19:40   #6 (permalink)
vipinverma's Avatar
Member: 138224
Thanks Meter: 56
thanks
1000 percent working i make out board conector pin .... Thanks bro 7 set ok now
The Following 7 Users Say Thank You to vipinverma For This Useful Post:
Old 09-29-2008, 22:56   #7 (permalink)
Registered User
Member: 101744
Thanks Meter: 69
The Following 2 Users Say Thank You to alito315744 For This Useful Post:
Old 09-30-2008, 04:55   #8 (permalink)
azez.sd's Avatar
Member: 735523
Sonork: 100.1591830
Thanks Meter: 262
The Following 2 Users Say Thank You to azez.sd For This Useful Post:
Old 09-30-2008, 06:46   #9 (permalink)
Member: 764060
Thanks Meter: 23
i have nokia 2626 after few secends the display turn into blue light after few secend i had changed lcd connector done full flash then too the problem is not solving plz help mee
The Following 6 Users Say Thank You to shahbaz_tamboli For This Useful Post:
Old 10-04-2008, 17:42   #10 (permalink)
Member: 751223
Thanks Meter: 538
bro just rehot cpu only
The Following 3 Users Say Thank You to mohammed-anis For This Useful Post:
Old 10-04-2008, 19:32   #11 (permalink)
Member: 871978
Sonork: rana
Thanks Meter: 5
i have 1208 today i changed its charging jack(every thing was ok before this),when i switched it on then it said"local mode"what is this,then it started charging,hands free,data cable at mobi mb also was ok.but after a few time when i again restarted it it showed again local mode.on connceting charger it said"not charging"after this my set is completly dead,no on,no msg........nothing .plz help me ..what is problem...
The Following 3 Users Say Thank You to shahidali109 For This Useful Post:
Old 10-04-2008, 19:37   #12 (permalink)
Member: 356169
Thanks Meter: 34
The Following 3 Users Say Thank You to labsmaster For This Useful Post:
Old 10-04-2008, 19:42   #13 (permalink)
sayaicat's Avatar
Member: 160314
Thanks Meter: 50
i'll try later...
thx bro
The Following 4 Users Say Thank You to sayaicat For This Useful Post:
Old 10-04-2008, 23:21   #14 (permalink)
multi_mobile's Avatar
Member: 502659
Thanks Meter: 101
help me in blue screen
heloo brother plz help me and more deals so easy in blue screen i have 5 sets 1200,1208 same condisation
The Following 2 Users Say Thank You to multi_mobile For This Useful Post:
Old 10-05-2008, 02:35   #15 (permalink)
techseeker"ems"'s Avatar
Member: 343227
Thanks Meter: 22
hi mate. check the solders of your charging pin. there may be shortings in it.
The Following 4 Users Say Thank You to techseeker"ems" For This Useful Post:
nokia 1200 1208 1650 1209 PA jumper solution m zubair Nokia Hardware & Hardware Repair 7 06-12-2014 04:15
nokia 1200 1208 1650 Dead , Restart , not charging , local & test mode solution m zubair Nokia Hardware & Hardware Repair 4 12-09-2009 03:00
1200 1208 1650 test mode local mode solution yahia ali Nokia Hardware & Hardware Repair 0 05-03-2009 12:28
Page generated in 1.29634 seconds with 9 queries
