10-03-2008, 13:29 | #1 (permalink) |
Freak Poster Join Date: Oct 2004 Age: 44
Member: 88552 Status: Offline Thanks Meter: 13 | U900 Flash i have nspro V.5 and want to flash/ change language. always "phone not found" have anyone a pitcure of cable typ i have the E210 cable ( rj45-usb-phone in) br east51 |
10-03-2008, 14:52 | #2 (permalink) |
No Life Poster Join Date: Dec 2002 Location: Romania
Member: 19254 Status: Offline Sonork: 100.72990 Thanks Meter: 25,395 | connect the phone inj Download mode using NsPro E210 cable to NsPro box. Check if the phone is detected on device manager as "SAMSUNG CDMA MODEM" If the phone is detected on windows device manager, will be detected by NsPro as well. |
10-07-2008, 13:38 | #3 (permalink) |
Insane Poster Join Date: Apr 2006 Location: bad sector
Member: 255965 Status: Offline Thanks Meter: 10 | Reading file acknowledge failed When I tried to flash phone i got this message: "Reading file acknowledge failed" Writing ModemCode file Proceeding with file... Press NEXT to continue... |
10-07-2008, 18:48 | #4 (permalink) |
Freak Poster Join Date: Sep 2005 Location: Bulgaria Age: 37
Member: 182669 Status: Offline Thanks Meter: 87 | i have same problem too,for now phone Dead.I tryed with all flash fiiles from support but with No success.May be with next realize this bug will be fixed |
10-16-2008, 21:23 | #7 (permalink) |
Junior Member Join Date: Sep 2006 Location: Poland Age: 45
Member: 344558 Status: Offline Thanks Meter: 5 | Try this flasher and write boot files.I just repaired samsung with same issue. http://www.mediafire.com/?nydjqz3jimd |
11-19-2008, 16:33 | #10 (permalink) | |
Freak Poster Join Date: Jan 2004 Location: czech rep.
Member: 49095 Status: Offline Thanks Meter: 10 | Quote:
I had the same problem with NS-PRO and U900 flashing, for programming you have to use Multidownloader 5.33 and first you need DOWNGRADE BOOTLOADER, then you can successfully flash and revive your U900. B.R. :-) | |
The Following User Says Thank You to aleshek For This Useful Post: |
flashed unlock u900 flash phone but phone restarting | osom | LG | 6 | 08-28-2008 07:59 |
Anyone Succeeded To Flash U908 With U900 Flashes And Make It Work?? | tsarkh | Samsung Flashers, Software, Firmware. | 0 | 08-19-2008 08:57 |
U900 flash error! NAND Write! | hacktek | LG | 14 | 06-18-2007 11:32 |
U900 Flashed With V11 Unlock File | Nasmi | FuriousGold | 2 | 05-09-2007 01:07 |
U900 flash orig | Pretone | LG | 0 | 04-11-2007 18:56 |
