Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > HTC > HTC & PDA WM( With Touchscreen)
HTC & PDA WM( With Touchscreen) HTC, I-mate, Qtek, HP, Hitachi, and many other Pocket PC windows CE base devices
Old 10-20-2008, 18:00   #1 (permalink)
U.F.O.'s Avatar
Member: 801293
Sonork: 100.1581561
Thanks Meter: 170
Diamond free unlock check here
Now you can unlock your Diamond with free solution download her
good luck.
KOKO_TARGET
The Following 26 Users Say Thank You to U.F.O. For This Useful Post:
Old 10-20-2008, 18:05   #2 (permalink)
JHUN PANABO's Avatar
Member: 785769
Thanks Meter: 138
did you test this
sw mate..
Old 10-20-2008, 18:20   #3 (permalink)
U.F.O.'s Avatar
Member: 801293
Sonork: 100.1581561
Thanks Meter: 170
Originally Posted by JHUN PANABO View Post
did you test this
sw mate..
yes tested by me and worked good
KOKO_TARGET
The Following 3 Users Say Thank You to U.F.O. For This Useful Post:
Old 10-20-2008, 18:36   #4 (permalink)
Member: 545073
Thanks Meter: 6
page is not displaying for me bro. can u send me link again plz.
The Following User Says Thank You to gbeaugold For This Useful Post:
Old 10-20-2008, 18:51   #5 (permalink)
U.F.O.'s Avatar
Member: 801293
Sonork: 100.1581561
Thanks Meter: 170
http://rapidshare.com/files/15587025...ARGET.rar.html
Good luck
KOKO_TARGET
Old 10-20-2008, 18:55   #6 (permalink)
U.F.O.'s Avatar
Member: 801293
Sonork: 100.1581561
Thanks Meter: 170
Tested by me and worked good
any one else test it ????
KOKO_TARGET
Old 10-21-2008, 11:07   #7 (permalink)
Member: 6313
Thanks Meter: 1
Tested by me... work ok!
Old 10-21-2008, 12:44   #8 (permalink)
Member: 255455
good luck.
KOKO_TARGET
good work i test it and worked good
tanks koko_target
Old 10-22-2008, 20:11   #9 (permalink)
U.F.O.'s Avatar
Member: 801293
Sonork: 100.1581561
Thanks Meter: 170
Sorry for blocked link
This is new link
http://rapidshare.com/files/156561365/Diamond.rar.html
Good luck.
KOKO_TARGET
The Following 5 Users Say Thank You to U.F.O. For This Useful Post:
Old 10-22-2008, 22:08   #10 (permalink)
Member: 882694
Thanks Meter: 1
Just to add my 2 cents, this does work but is a pain in the proverbial backside.
Once you get to the last stage (where you have to use the "DiamUnlock" program you have a fraction of a second to click on the "Remove SIM lock" (or similar) then commit.
In order to make this easier, when you load it hit the "Check SIM lock" button at the bottom right of the screen. This will open a little box that stops the program from coling allowing you to actually use it.
It took me countless attempts until I did that but I can say it does work. And it is free. (question is, how much is your time worth?)
The Following User Says Thank You to anothercupboard For This Useful Post:
Old 10-26-2008, 02:30   #11 (permalink)
Member: 885204
Thanks to OP! Just downloaded zip files to use on a T-Mobile MDA Compact 4 which I understand is basically the same as a Diamond. The instructions are a bit vague for a novice like me. Can Anyone who has used this 3 step procedure please give me a step by step guide. I have read the instructions but am unsure of the following: Do I run the unlock from the computer by clicking on a box or do I run the unlock from the phone?
What do I do with "Diamond -sst. bat" as it is not an executable file?
Is running "DiamondCustomRUU.exe" actually flashing a new radio to the phone and do I need to do anything like copy a new radio file after this step?
Where do I copy "DiamUnlock.exe" onto in my phone?
Can you easily "Unbrick" your phone if you do not follow the procedure correctly?
Does this solution work like the "paid for" ones in that there are 3 steps to unlock the phone?
Many Thanks in advance!
Old 10-26-2008, 17:38   #12 (permalink)
Member: 163933
Sonork: 100.1608969
Thanks Meter: 13
Hello man you will execute the third step inside programfile of your phone
transfer it true Activesync........100% working.
The Following User Says Thank You to eribod For This Useful Post:
Old 10-27-2008, 18:51   #13 (permalink)
Member: 885204
Thanks for the reply. Does this mean that the 1st and 2nd steps are completed by just opening a program from the pc?
Cheers!
Old 10-28-2008, 23:05   #14 (permalink)
Bi0H4z4rD's Avatar
Member: 52560
Thanks Meter: 226
This solution is working and 100% tested. Only step3 is a little tricky, but works perfectly.
The Following User Says Thank You to Bi0H4z4rD For This Useful Post:
Old 10-28-2008, 23:09   #15 (permalink)
Member: 885204
Thanks for the confirmation that this works but can you answer my question about what to do with "Diamond-sst.bat" as it does not appear to be an executable file?
Cheers!
Unlock HTC Diamond FREE arybraga HTC & PDA WM( With Touchscreen) 7 07-11-2009 16:29
Spice 404n not netork unlock,chek this log infinity team. maheshsaiganesh Infinity-Box 1 10-16-2007 13:54
***A60 & C60 unlock solution her**** bakarioss Siemens-Benq RingTones and WallPapers 63 06-12-2004 20:24
Page generated in 0.26606 seconds with 10 queries
