Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Rocker Dongle (By Legija)
Old 11-10-2008, 12:08   #1 (permalink)
legija's Avatar
Member: 256342
Sonork: None
Thanks Meter: 28,276
How to Unlock new QUALCOM (3G ) Samsung models
This is short manual for new 3G Samsung phones (U900, U800, F480, U700 etc)
In order to unlock it, do the following steps:
  • Power on the phone and activate "QUALCOM" USB Mode - type *#782872# and confirm.
  • Connect phone to PC USB port with USB cable
  • Make sure to install QUALCOM drivers ! ! ! (Support/Drivers/Samsung/Qualcom_driver.rar)
  • Start Samsung Rocker and select Your model
  • Com port selection is done automaticaly, You DO NOT NEED to select port
  • Check "Unlock" and click "Do Job"
  • Thats it
If everything is done well, You should have following log in Samsung Rocker :
Samsung Rocker v1.21Beta
Loaded 456 models
Available COM ports: COM1, COM3, COM17, COM29
Doing Job, Please Wait
Using \\.\COM30 port
Modell: SGH-U900
MSLAddress: R6VQ488053
IMEI: 352442-02-184326-1
Calculating... OK
MSL2 Code: PASSED
MSL2 Password: PASSED
Closed \\.\COM30 port
Using \\.\COM15 port
Unlocking... OK
Unlock & Unfreeze: DONE
Closed \\.\COM15 port
Resetting Phone
To exit QUALCOM mode, type *#726872# via keyboard.
Please post any successfull logs here.
Thanks.
The Following 27 Users Say Thank You to legija For This Useful Post:
Old 11-14-2008, 12:04   #2 (permalink)
Registered User
Member: 136967
Thanks Meter: 7
hi sir i cant put the fone on that mode bec when i start the fone itsasking for the fone password pls help me with that thanx
Old 11-14-2008, 17:55   #3 (permalink)
legija's Avatar
Member: 256342
Sonork: None
Download v1.23 from support. Unlock it once in cdma mode and reboot phone, user lock should be removed, so You can enter qualcom mode afterwards.
Old 11-16-2008, 04:34   #4 (permalink)
Member: 416710
Thanks Meter: 391
People who only have the Dongle and need unlock a phone with combo cable can use prolific adapter or need ftdi interface to unlock the phone?
Old 11-16-2008, 12:45   #5 (permalink)
legija's Avatar
Member: 256342
Sonork: None
You can unlock phones only with USB cable, just need to repeat process twice.
Old 11-17-2008, 18:52   #6 (permalink)
Registered User
Member: 595504
Sonork: 100.1580419
Thanks Meter: 249
in mi case model samsung F480 can`t detect in eny way in device manager phone exist
Old 11-17-2008, 19:03   #7 (permalink)
legija's Avatar
Member: 256342
Sonork: None
Post log from process, please.
Old 11-17-2008, 19:07   #8 (permalink)
Registered User
Member: 595504
Sonork: 100.1580419
Thanks Meter: 249
here Is my Screan Shoot
Old 11-17-2008, 19:10   #9 (permalink)
Registered User
Member: 595504
Sonork: 100.1580419
Thanks Meter: 249
The Driver is Corecct instalate Please Help me ti unlock this model
Old 11-17-2008, 19:17   #10 (permalink)
legija's Avatar
Member: 256342
Sonork: None
Why dont You use LATEST version? Samsung Rocker v1.23 ?
Old 11-17-2008, 19:55   #11 (permalink)
Registered User
Member: 595504
Sonork: 100.1580419
Thanks Meter: 249
Samsung Rocker v1.23Beta
Loaded 464 models
Available COM ports: COM1, COM18, COM5, COM41, COM42
Modem Port Detected On COM41
PhoneLock and SimLock Disabled
Serial Port Detected On COM42
Modell: SGH-F480V
MSLAddress: R4WQ909709
IMEI: 353670-02-306596-7
Calculating... OK
MSL2 Code: PASSED
Unlocking... OK
Resetting Phone
Finished
Old 11-17-2008, 19:55   #12 (permalink)
Registered User
Member: 595504
Sonork: 100.1580419
Thanks Meter: 249
Loaded 464 models
Modell: SGH-F480V
Calculating... OK
MSL2 Code: PASSED
Unlocking... OK
Resetting Phone
Finished
Old 11-20-2008, 22:27   #13 (permalink)
Member: 610980
Thanks Meter: 1
U800 doesn't unlock. Here's log:
Loaded 464 models
Available COM ports: COM28, COM29
Modem Port Detected On COM28
Serial Port Detected On COM28
Modell:
MSLAddress: 	~~~ü›Í~
COM port or Imei Read Error
or something like this occuring every time. Even if imei and msl read correctly - error on MSL2. Tried U700 - things are the same. What am I doing wrong?
Old 11-21-2008, 10:52   #14 (permalink)
legija's Avatar
Member: 256342
Sonork: None
If You use usb data cable, You must enter QUALCOM mode first. As it said in manual.
Old 11-21-2008, 20:17   #15 (permalink)
Member: 610980
Thanks Meter: 1
Everything was done as you said in 1st post. I tried even generic ZTE modem drivers - nothing changed.
how to unlock new firm 2g 3.1 3g 3.1 gtcellrepair iPhone 2 / iPhone 3G / iPhone 3GS 4 09-09-2009 22:14
how to unlock new samsung z500 falak QUALCOMM Models (3G) 2 07-15-2005 21:32
How to unlock new models ;) distefano SagMaster Team OLD Products 16 03-11-2005 19:52
How to unlock new samsung X600???????? gsmnice SYSOL Platform 5 06-29-2004 08:23
Page generated in 0.26089 seconds with 10 queries
