Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > BB5BOX Products > BB5KING for (BB5BOX)
Old 11-14-2008, 14:49   #1 (permalink)
Member: 372482
Thanks Meter: 93
UFS problem please help
Searching for UFS box ...
UFS box NOT detected
UFS box UFSBOX_BB5_FLASH_bb5challenge ...
Error. 0x11130101
ERROR!
Operation time: 00:00.
Successfully done.
Thread phone exit.
What I have to do with this problem? Help
Old 11-14-2008, 18:30   #2 (permalink)
enzawigroup's Avatar
Member: 141363
Sonork: 100.1594362
Thanks Meter: 148
try to update the ufs box to ver 208
br
Old 11-14-2008, 19:51   #3 (permalink)
Member: 372482
Thanks Meter: 93
My ufs firmware is 208...
Old 11-14-2008, 19:56   #4 (permalink)
nae
Registered User
Member: 215866
Sonork: 100.1617874
Thanks Meter: 125
just unplug and plug again ufs from usb whitout close BB5King program
and press "Chk Conections"
The Following User Says Thank You to nae For This Useful Post:
Old 11-14-2008, 20:40   #5 (permalink)
megdy's Avatar
Member: 628115
Thanks Meter: 113
The problem not on cacle...
My friends told me the problem whit this
1. UFS box firmware should be 208. If any of you not have this firmware inside their box, can easy upgrade to 208 following this steps:
- Download this soft: http://www.bb5king.com/files/mobileE...3.0_beta11.exe
- Install it
- After install plug your UFS device
- Start installed program
- At the left top select your ufs device and click connect
- An automatic prompt ask you if you want to upgrade your firmware
- Confirm it
(thanks to user Serjer for pointing to this software)
2. Some UFS manufacturers used one wrong IC chip. If still encounter errors on some phones, please open your UFS box and check with this picture info:
Sorry for any troubles created to our end-users, but our BB5 King team is not responsable of UFS boxes firmware updates and manufacture process.
Also, for better performance and to avoid communication errors, we still recomand to all our BB5 King users to use JAF interface, is more faster and more stable.
The Following 4 Users Say Thank You to megdy For This Useful Post:
Old 11-14-2008, 20:42   #6 (permalink)
megdy's Avatar
Member: 628115
Thanks Meter: 113
Hope Cinek can give solution for us
Old 11-14-2008, 21:26   #7 (permalink)
Member: 372482
Thanks Meter: 93
Try this solution http://forum.gsmhosting.com/vbb/showthread.php?t=630144
and all your problems are away.
Old 03-24-2009, 19:33   #8 (permalink)
oldsindbad's Avatar
Member: 17189
Thanks Meter: 66
well I tried the following
while I have both HWK and the JAF on the same PC
I tried the unlocker on the JAF interface and all was OK
now
IF you try the 5310 and notice the problems on unlocking
try the following
connect it to HWk and disconect the JAF fbus interface
and check the connection
now you should notice the difference
and the unlocking will work
thanx in advance
Old 04-26-2009, 17:59   #9 (permalink)
orangade's Avatar
Member: 521955
Thanks Meter: 261
I install the soft but don't work. this error: "Sorry, application was expired? Check wxw.mxkey.biz for update, please!"
But the website is offline.
Have you got a solution please?
Thank's in advance
Old 04-27-2009, 08:51   #10 (permalink)
orangade's Avatar
Member: 521955
Thanks Meter: 261
Problem solved: Change the date of your pc and is ok for the update!
The Following User Says Thank You to orangade For This Useful Post:
Old 05-19-2009, 09:24   #11 (permalink)
Member: 491576
Sonork: 1212
Thanks Meter: 14
Brother I have new ufs3+hwk but the problem is when i setup main file & connect the ufs box they want usb driver then i located the driver & open the software but when i connect its show HWK not locate. But why? when i buy it the seals man show & check me the box it's 100% ok but my PC say error. So what can i do?
PLEASE HELP ME.
Old 05-19-2009, 10:18   #12 (permalink)
PASSIONATE_BOYS's Avatar
Member: 541591
Sonork: 100.1611509
Thanks Meter: 7,361
PLEASE HELP ME.
Post log to know the exact problem.
The Following User Says Thank You to PASSIONATE_BOYS For This Useful Post:
Old 02-03-2010, 08:02   #13 (permalink)
Member: 957863
Thanks Meter: 9
brothers when m try to instal ufs3 hwk on my pc its says that( screen shot is attachment is linked) am try both files one by one but not done .i have no any more prioves version instal on my pc...... plz solve my prob
The Following User Says Thank You to qaisar1980 For This Useful Post:
Old 01-06-2011, 11:24   #14 (permalink)
Registered User
Member: 583416
Thanks Meter: 2
Locating HWK Upgrade server...
HWK Upgrade server found!
Preparing connection to server...
Connecting to HWKUpgrade server...
Connection to server failed: Socket Error # 10061
Connection refused.(No connection could be made because the target machine actively refused it.)
The Following 2 Users Say Thank You to muhammadmakki For This Useful Post:
Old 01-06-2011, 13:36   #15 (permalink)
Member: 1317020
Sonork: 100.1616949
Thanks Meter: 19
this might be hwk server problem
Problem with SETool and UFS interface. PLEASE HELP!! fingusio HWK 5 01-09-2008 11:41
@ufs team ----ufs-2 . please help ---- 137parth UFS2 + UFS3-Tornadoflasher 16 02-17-2005 08:21
Page generated in 0.23536 seconds with 9 queries
