Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > McnPro Box
Old 11-29-2008, 21:00   #1 (permalink)
Mcnbox's Avatar
Member: 726283
Sonork: 100.76027
Thanks Meter: 7,616
Arrow McnPro - Pinouts Detection Procedure - A Quick Scan Guide
Quick scan RX ,TX
- Txd Rxd Gnd and Api(sky cpu) Pinout Scan
- Supports MTK TI ADI INF SKY AGE OM SPD...
- Takes just a few seconds
Step by Step:
  • Connect McnPro to computer and open the main software
  • Connect the phone with the right cable via USB etc.
  • Use our special cable to connect phone to Negative / Positive, Box can automatic identification and that already have Protection System, so don't worry about the polarity.
  • Press [Scan Rx Tx]
  • If you already know the based cpu in phone, just select the related one (will be fast), otherwise select "Auto" (will take a few more seconds than usuall)
  • Hold power-on button of your phone and press start button on the software interface , in just a few second you will get results ,eg.
    Scanning results:
    GND: 12 13 ,RXD 10, TXD 15
    Scanning results:
    Spd chipset
    GND: 12 13 ,RXD 10, TXD 15, Boot:6
    API Scanning results:
    API Pin 4-5
  • You can save the scan results , because you might need that for the flash process
  • BTW, for SKY cpu it's a little be different, Api can be detected and phone can be Reset. IMEI can be change too. (plz follow the window step by step procedure, its very easy.) eg.
    Scanning results:
    SKY chipset
    Scanning API pin(Please waiting...)
    API pin 5-6
    Connect ok
    Modify imei...
    Modify successful !
USB Scan
- Charge / Boot pin ,USBD+/-
- Will take more seconds than above step
Step by Step:
  • Press [USB Scan]
  • In select option choose the same cable which you used, Eg. Mcnpro-11
  • Hold power-on of your phone and press [Read starts] button on the software interface .eg.
    Scanning pin-status, please waiting..
    9,10 short-pin
    >>Pin-status scanning completed
  • Press [Charge-pin] button Box will be start to analyzing ,then follow the window step by step to do the procedure.when computer find a new USB device which mean's all step done. eg.
    USB D-:8 USB D+: 7 VCC:1 GND: 6 11
    If scan other phone ,please press [stop]
The Following 19 Users Say Thank You to Mcnbox For This Useful Post:
PadFinder pinout detection procedure GSMtricks PadFinder box 12 09-22-2009 18:45
NetDongle Quick Start guide :) Invisible Sonics Box 1 07-04-2005 22:16
Quick Repair Guide kulibin Sony Ericsson Hardware Repair 7 05-15-2003 23:44
Page generated in 0.16077 seconds with 9 queries
