Go Back   GSM-Forum > Product Support Sections > Special Solutions / Services / WebShop > HalaGSM WebShop
Old 01-08-2009, 23:52   #1 (permalink)
Halas's Avatar
Member: 20059
Sonork: 100.73934
Thanks Meter: 2,756
J.A.F. Box Pkey(98 Cables)
J.A.F. Box + Pkey + 100 Cables
J.A.F Box + Pkey is A full service software for Nokia phones. flashing, change language, debrand etc. A must have solution for the collection
Description :
JAF is the ONLY third party flasher which supports USB flashing. USB flashing is very good and usefull because in case a new phone come out, the user can IMMEDIATELY FLASH THE PHONE, he doesn't need to wait for new F-Bus cable release and to pay expensive delivery costs. The CA-53 cable is included in nearly EVERY BB5 Nokia package.
- revive dead phones using simple USB cable CA-53 (no need to buy F-Bus cable and to pay expensive delivery costs)
- BB5 models flashing supported using simple USB cable CA-53
- the only flasher that can correctly flash Nokia N80 by USB
- the only flasher that can repair N91 white screen problem
Following phones FLASHING is possible by P-Key and CA-53 USB cable (without JAF Box, just P-Key dongle):
- 3250 (RM-38)
- 6125 (RM-178)
- 6131 (RM-115)
- 6270 (RM-56)
- 6280 (RM-78) also empty gallery problem solved
- 6630 (RM-1)
- 6680 (RM-36)
- 6681 (RM-57)
- 6682 (RM-58)
- 7370 (RM-70)
- E60 (RM-49)
- N70 (RM-84)
- N70CH (RM-99)
- N71 (RM-67)
- N90 (RM-42)
- N91 (RM-43)
- N80 (RM-92)
- 6234 (RM-123)
Free service for original JAF box owners.
Unlock code calculator for:
Panasonic: A10x, CL50, G5x/G70, GD55, ST55, X300
NEC: 342, e101
Philips: 568
To avoid reselling codes only 20 codes are allowed in 60 days. After 60 days 20 more credits will be added. If the 20 codes have not been used within 60 days, the credits become expired.
JAF 1.96 beta5
add FILE SYSTEM FORMAT in dct4, bb5 fbus and usb mode. Old user area format and drive format are removed being replaced by new function. So to format the phone select File Sys Format from service menu. It will autodetect file system and prompt you to select drives and density when available. On N91 don't format DRIVE E: bcs it's hard drive from phone and takes 30 mins to format, so better to format using phone menu and charger.
added timeout on usb communication. If there is a problem with usb software should not hang.
added language info on ape variant on dct4 ape phones (9500 etc...)
added normal mode transition for dct4 ape phones to set test mode.
added language window hack to display languages from ini file when selecting ape variant files, cnt files and user files for dct4 fbus mode.
added last modified jaf_nok4models.ini (thx to ahmedksal and mainboard)
JAF update
added support for AMD flash chip in bb5 6280 (fbus only). Flash this phone only with fbus if you have gallery problem. USB support will be added in next version.
added support for N91, N80 USB flashing and future uni store loaders.
added support for N91, N80 fbus flashing, also for N80 ape variant flashing.
added support for latest flash loaders version 6.14. You can find them on support until full setup is launched.
improved bb5 fbus flashing and corrected small bugs
improved bb5 usb flashing by using pkey only. You don't need jaf interface connected with usb, when you flash a phone, so you can spare a usb port.
added support for new flash pack files to USE INI function.
some cosmetic changes in bb5 tab to increase the size of product codes list box.
changed the support access using pkey.
JAF 1.92 final
rewritten loaders selection for DCT3 phones (hoping to solve all flash id problems)
improved DCT3 power-up in local mode. ¡¡ãContact service¡¡À phones are booted ok now
other small bugs corrected
About J.A.F:
Works on Win2000, XP (XP preferred)
Future free updates and support
Real-time online updates
Fast USB flashing capability
Fastest Flashing device on the market
No extra power needed, it uses USB power
Nokia DCT3 supported models:
2100 , 3110 , 3210 , 3310 , 3315, 3330 , 3350 , 3390, 3410 , 3610 , 5110 , 5110i, 5130, 5190, 5210 , 5510 , 6080, 6110 , 6130 , 6138, 6150 , 6190, 6210 , 6250 , 7110 , 8210 , 8250 , 8290, 8850 , 8855 , 8890
DCT3 FEATURES:
- read/write flash
- unlock SP simlocks
- rebuild / repair IMEI
- set factory defaults
- reset User Code
- read/write PM
- turbo flashing
- write eeprom (fls and pmm format supported, no need to convert files)
Nokia DCT4 supported models:
1100 , 1600 , 3100 , 3100b, 3108 , 3200 , 3200b, 3300 , 3360, 3510 , 3510i , 3530 , 3590, 3595, 5100 , 6108 , 6610 , 6100 , 6200, 6220 , 6230 , 6260 , 6310 , 6310i , 6500 , 6510 , 6590, 6600 , 6620 , 6650 , 6800 , 6820 , 7200 , 7210 , 7250 , 7250i , 7600 , 7650 , 7610 , 7710 , 8310 , 8390, 8910 , 8910i , 9300 , 9500
DCT-4 WD2: 3600, 3650 , 7650 , 6600 , N-Gage
DCT4 FEATURES:
- flash software (upgrade/downgrade)
- unlock SP locks
- lock phone to any provider
- turbo flashing speed
- flashing Bluetooth
- save user settings (pm and phone books)
- full factory defaults
- self-testing (a very useful feature)
- repair ¡¡ãContact provider¡¡À, etc.. using new technology
- format user area for WD2 and EPOC
- reset user lock (security code)
NOKIA DCT-L supported models:
9290, 9210 , 9210i (communicator)
DCT-L FEATURES:
- unlock
- set FAID
FREE ADDON - Philips Software
Philips supported phones:
Alcatel OT155, Alcatel OT156, Alcatel OT355, Azalis 238, Azalis 268, Fisio 120, Fisio 121, Fisio 311, Fisio 316, Fisio 620, Fisio 625, Fisio 820, Fisio 822, Fisio 825, Fisio 826, Genie 2000, Ozeo, Philips 160, Philips 162, Philips 189, Philips 289, Philips 330, Philips 350, Philips 355, Philips 362, Philips 530, Philips 535, Philips 630, Philips 636, Philips 639, Philips 650, Philips 655, Philips 659, Philips 755, Philips 760, Philips 855, Philips 859, Siemens SF65, Xenium, Xenium 9@98, Xenium 9@9a, Xenium 9@9c, Xenium 9@9d, Xenium 9@9e, Xenium 9@9i, Xenium 9@9++
Philips software features:
unlock
repair locks
backup/restore phone
read/write flash
recovery mode
Package includes *:
1 J.A.F. Box
PKey-V
cable set (98 pcs)
list for packs 3: 85 pcs cables ( for current purple models)
1 Nokia DKU2
2 USB A-B
3 Nokia 1100
4 Nokia 1110
5 Nokia 2650
6 Nokia 6100
7 Nokia 6101
8 Nokia 6230
9 Nokia 6270
10 Nokia 7260
11 Nokia 7270
12 Nokia 7280
13 Nokia 7360
14 Nokia 7380
15 Nokia 7610
16 Nokia 8800
17 Nokia 3250
18 Nokia 5200
19 Nokia 5500
20 Nokia 5700
21 Nokia 6131
22 Nokia 6151
23 Nokia 6233
24 Nokia 6280
25 Nokia 6290
26 Nokia 6300
27 Nokia 6630
28 Nokia 6680
29 Nokia 7370
30 Nokia 7390
31 Nokia E50
32 Nokia E60
33 Nokia E61
34 Nokia E65
35 Nokia E70
36 Nokia N70
37 Nokia N71
38 Nokia N73
39 Nokia N80
40 Nokia N90
41 Nokia N91
42 Nokia N93
43 Nokia N93i
44 Nokia N95
45 Nokia 2630
46 Nokia 2760
47 Nokia 3110C
48 Nokia 3500
49 Nokia 5310
50 Nokia 5610XM
51 Nokia 6110N
52 Nokia 6120
53 Nokia 6126
54 Nokia 6267
55 Nokia 6500S
56 Nokia 6500C
57 Nokia 7500
58 Nokia 8600
59 Nokia N76
60 Nokia N77
61 Nokia N81
62 Nokia N92
63 Nokia N95 8G
64 Nokia E61i
65 Nokia E62
66 Nokia E90
67 Easy flash II
68 Nokia 2600c
69 Nokia 6555
70 Nokia N75
71 Nokia 8800E
72 Nokia N82
73 Nokia E51
74 Nokia N78
75 Nokia 5000
76 Nokia 6122c
77 Nokia 3120c
78 Nokia 7310C
79 Nokia 5220XM
80 Nokia 3555B
81 Nokia E71
82 Nokia 5320XM
83 Nokia E66
84 Nokia 1680C
85 Nokia 6210N
list for packs 4: 13 pcs cables (update with new and comeing models)
1 Nokia 5208
2 Nokia 7610S
3 Nokia 3600S
4 Nokia 6220C
5 Nokia N96
6 Nokia 7210C
7 Nokia 6600F
8 Nokia 6600S
9 Nokia N79
10 Nokia 6650D
11 Nokia 2680
12 Nokia 7070
13 Nokia N85
Price 179 Usd
To order
http://www.halagsm.com/site.php?p=det&prod=1
B.R
Hala Gsm
The Following 4 Users Say Thank You to Halas For This Useful Post:
Old 01-09-2009, 11:43   #2 (permalink)
honyjee's Avatar
Member: 506989
Sonork: 100.1585406
Thanks Meter: 81
sir give me 10 boxes price ?
please register in www.halagsm.com
we will add you like reseller to see price for 10 pcs
send me you user name PM
Halas
Old 02-19-2010, 10:23   #3 (permalink)
Edwins c's Avatar
Member: 107334
Thanks Meter: 10
what is our hope for J.a.f boxes any good news still coming to us J.a.f users
Spiderman Box (21 cables) Halas Main Sales Section 0 11-20-2009 10:31
Cyclone Box (Without cables) IPMART ipmart WebShop 0 03-27-2009 11:50
New 10Pin 26 In 1 Cable Set Compatible For MT Box (exclusive 68pcs MT Box cables) IPMART ipmart WebShop 0 11-05-2008 14:50
Smart Clip ONLY, Smart Clip+Dreambox SE, HWK-UFS box (no cables) Gsmserver Main Sales Section 0 04-17-2008 11:46
DCT4 FLASHER, Universal box (42 cables) Gobi Main Sales Section 0 08-21-2002 12:21
Page generated in 0.15964 seconds with 9 queries
