Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > McnPro Box
Old 03-19-2009, 20:07   #1 (permalink)
PhoneCareCenter's Avatar
Member: 574123
Sonork: 100.1581804
Thanks Meter: 1,839
How to Format MTK Chips with Mcnpro Box >>
1 - Open Mcn Pro Software & Select Boot. Like Below
2 - Select RX & TX, then select Chip Type.Press Power Button & Press Start.
3 - Pinouts will be detected & Applied in few seconds like below, if not Press Apply or Save Pinout.
4 - Press Read Button on McnPro Software, choose a location then name the file & Save it.
5 - Wait few minutes, depending on CPU Type (6228 cpu takes longer timer) (6226 cpu apprx 4minutes)
6 - Flash is Read & Saved.
7 - Now press the Format Button, Press Power Button when asked to do so & wait for a few seconds...
8 - Phone is perectly ok with full signal, to get Languange to English press *#0000# Language will be set to Default..
Enjoy McnPro Box with the best Support
www.mcnbox.com
Good Luck
The Following 9 Users Say Thank You to PhoneCareCenter For This Useful Post:
Old 03-20-2009, 07:03   #2 (permalink)
deepak2005's Avatar
Member: 253019
Thanks Meter: 31
thans sir for this info
wbr
Deepak
Old 03-20-2009, 07:18   #3 (permalink)
mohit_kripalu01's Avatar
Member: 486357
Sonork: 100.1602846
Thanks Meter: 1,220
nice job bro keep it up ................... thanxs
Old 04-04-2009, 19:13   #4 (permalink)
iwan8818's Avatar
Member: 859702
Sonork: 100.1619060
Thanks Meter: 78
screenshott for spd pleaseee
Old 04-05-2009, 15:21   #5 (permalink)
Member: 574123
Sonork: 100.1581804
Thanks Meter: 1,839
@iwan8818
Will try to Post SPD Unlock & Format Operation ScreenShots tomorrow.
McnPro Team
Old 04-08-2009, 19:24   #6 (permalink)
iwan8818's Avatar
Member: 859702
Sonork: 100.1619060
Thanks Meter: 78
where spd screenshoot? waitinggggg....
Old 04-08-2009, 19:49   #7 (permalink)
iwan8818's Avatar
Member: 859702
Sonork: 100.1619060
Thanks Meter: 78
are sure can make good spd?
please show me screenshoot
Old 04-09-2009, 23:42   #8 (permalink)
Mcnbox's Avatar
Member: 726283
Sonork: 100.76027
Thanks Meter: 7,616
SPD Unlock & Format , The procedure which is same like " Format MTK Chips" , Diff is just select SPD, then can start ...
Best Regards !
Mcnbox Team
Old 04-10-2009, 17:32   #9 (permalink)
fokal2008's Avatar
Member: 953931
Sonork: 1652252
Thanks Meter: 897
Arrow format spd 100/100 ok with mcnpro
i have successfuly format spd mcu with mcnpro.
after scan tx rx and gnd, i make read flash and seved,after that i restart my box and i scan rx tx gnd again.and i press format.
see logs...................
Formatting, Please Power Off & On
Connected
Boot Information:
downloading Boot
CPU Type: 6600D
Flash Type: SAMSUNG K5A(J)63xxCT
Flsh Size??00800000(Hex Bytes)
Baudrate set to:921600
Formatting Nor Flash...
>>Nor Format completed
Old 04-10-2009, 18:58   #10 (permalink)
Member: 574123
Sonork: 100.1581804
Thanks Meter: 1,839
@fokal2008
Very glad to see that u're happy with McnPro, New Update is in Progress.
Good Luck
McnPro Team
The Following User Says Thank You to PhoneCareCenter For This Useful Post:
How is working OM CPU with Mcnpro Box >> Mcnbox McnPro Box 0 07-19-2009 10:08
How is working Spreadtrum CPU with Mcnpro Box >> Mcnbox McnPro Box 2 06-30-2009 18:17
Without USB connector how to flash /unlock phone with Mcnpro Box Mcnbox McnPro Box 0 06-27-2009 12:31
How is working ADI Chips with McnPro Box >> Mcnbox McnPro Box 17 06-05-2009 14:58
How is working INFINEON Chips with McnPro Box >> Mcnbox McnPro Box 0 06-02-2009 08:32
Page generated in 0.24219 seconds with 9 queries
