Old 04-28-2009, 19:56   #1 (permalink)
gsmsikar's Avatar
Member: 28004
Sonork: 100.1601142
Thanks Meter: 770
sigmatel s90 new type
i have a sigmatel s90 dead , i was unable to connect it with any box ,
it is having a connector similar to that used in nokia 5310 and nokia 3600s,
then after searching i got a t33i pinout details in the PCB , i also tried that but that was also not successful ...
is there any solution to connect and revive this set ?
i am trying to attach all the helpful images related to this set ..
thanks and please help me urgently/////
Old 04-30-2009, 08:28   #2 (permalink)
neeraj1st's Avatar
Member: 271008
Thanks Meter: 280
i have the same problem mate but no sucess
Old 04-30-2009, 23:19   #3 (permalink)
Member: 130995
Thanks Meter: 35,227
Hello,
What is this phone CPU chip name ?
Old 05-01-2009, 16:17   #4 (permalink)
.:KRISHNA:..:MOBILE:.'s Avatar
Member: 304012
Thanks Meter: 322
Originally Posted by InfinitySupport View Post
Hello,
MTK chip name MT6226BA 0832-BOALDP4AHB
Old 05-02-2009, 23:08   #5 (permalink)
Member: 148515
Thanks Meter: 19,534
hello!
i can explane how to detect Tx/Rx pins by measuring voltages on them
Old 05-03-2009, 05:19   #6 (permalink)
gsmsikar's Avatar
Member: 28004
Sonork: 100.1601142
Thanks Meter: 770
please explain sir ,
i am ready to learn about this method , as more and more chinese phones are coming which are not detected by the pinfinders...
Old 05-03-2009, 20:21   #7 (permalink)
Member: 1001635
Thanks Meter: 63
Originally Posted by InfinityHelp View Post
hello!
Sir please explain the method for finding Rx Tx of that phone.I have 3 sets of that model.
Please help...........
Old 05-05-2009, 07:34   #8 (permalink)
neeraj1st's Avatar
Member: 271008
Thanks Meter: 280
i try to detect this handset with manual tx rs pinouts on there jeck but no sucess i thinks this model was not detect with infinity or any oter box like spider man i try it bot but no sucess i thinks tere is some change of hardware thats why this handset not detect
Old 05-05-2009, 17:56   #9 (permalink)
gsmsikar's Avatar
Member: 28004
Sonork: 100.1601142
Thanks Meter: 770
today i got another set , same as above and it is also dead ..
same problem ..
it is also not able to connect by any method ..
what to do ?
now i have same two sets ...
Old 05-06-2009, 05:52   #10 (permalink)
Sony_computers's Avatar
Member: 570022
Thanks Meter: 67
[QUOTE=gsmsikar;4401277]i have a sigmatel s90 dead , i was unable to connect it with any box ,
Not Working Sir..... i test it on 10 sets only one set is okay with your pinout and have no sound after formating send okay pinout please. My yahoo id is [email protected]
Old 05-06-2009, 07:47   #11 (permalink)
Rise's Avatar
Member: 39022
Sonork: 1575244
Thanks Meter: 94
How it's possible
here i have sucess many sigmatel S90 through infinity
may be ur set was damage through hardware or u put set 30min without battery and then after u can try.
next time if i get this model then i will show details
Old 05-08-2009, 07:10   #12 (permalink)
gsmsikar's Avatar
Member: 28004
Sonork: 100.1601142
Thanks Meter: 770
this is the picture of the complete PCB
Old 05-08-2009, 19:45   #13 (permalink)
Rise's Avatar
Member: 39022
Sonork: 1575244
Thanks Meter: 94
@gsmsikar
listen dear, u putt battery and on the set and then
check the meter to these six points , if meter shows buzzz(beep) then that is tx and then rx must be near to tx
1st find tx
after u can easily to find rx
Old 05-08-2009, 20:14   #14 (permalink)
gsmsikar's Avatar
Member: 28004
Sonork: 100.1601142
Thanks Meter: 770
Originally Posted by Rise View Post
@gsmsikar
1st find tx
where do i put the negative and positive terminal of the meter ?
Old 05-09-2009, 08:05   #15 (permalink)
Rise's Avatar
Member: 39022
Sonork: 1575244
Thanks Meter: 94
dear, u select meter on beep side
and negative (black wire) on ground side and other red wire u can check six point 1 by 1 , but phone should be on and then check
1st u check ground without battery
how
it's simple , 2meter pin u in same ground area its shows beep ,
it's confirm this is ground
then 1 -ve pin u put on ground and +ve pin on six points without battery then there is 1 or 2 points have must ground points , which u have idea that this point is ground ,
then after u put the battery or use power supply to on the set and then u check by meter.
putt meter -ve on ground and check 5points with +ve , it should shows beep
on 1 point then this point is Tx, then after u can easily to check Rx through 1 by 1 connect and check on infinity.
Rx near to Tx
about value through meter , not say confirm
because many set shows different value in RX , Tx
u can't say exact that which 1 is Rx or Tx through value
new sigmatel S90 PINOUT manoj saraswat Chinese Models & Cloned Phones 12 01-04-2010 01:21
New sigmatel s90 100% complete sollution kumar_gsm_kumar Infinity-Box 1 06-07-2009 08:30
Sigmatel s90 fm flightmode cellbhai Infinity-Box 17 01-22-2009 19:56
sigmatel s90 SATISH Infinity-Box 2 09-20-2008 09:28
Sigmatel S90 SATISH Chinese Models & Cloned Phones 1 08-27-2008 13:29
Page generated in 0.26687 seconds with 10 queries
