Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > McnPro Box
Old 05-31-2009, 18:09   #1 (permalink)
Mcnbox's Avatar
Member: 726283
Sonork: 100.76027
Thanks Meter: 7,616
Arrow How is working ADI Chips with McnPro Box >>
1. Open Mcnpro Box main software .Start to scan phone , Apply info.(this time you need holding phone Power on Key)
2. Now you can see Software automatic convert to ADI interface ( Included related target boot )
3. Start to unlock or format phone before we need readout the phone Flash. Press Direct read ,and keep press power on Key , don't leave your finger away from power on Key(This is very important).
A . IF the phone switch on, still keep holding power on Key, just disconnect "+" from battery connector and reconnect "+" to battery connect.
B . Or disconnect "+" and cable , phone will be go to switch off, pulg in cable , you can see software ready start
going to downloading boot. then connect "+" to battery connect.
Now Please waiting a few mins. then save the Bin file to computer.
4. Steup for unlock . Press the unlock and select the saved file which we read above. then you can get the phone unlock code , manual type into phone, Phone unlocked .
5. For format need make backup before .
6. For flash just choose the related flashfile then press Flash button
Enjoy Easy plug / play games.
Best Regards !
Mcnbox Team
The Following 6 Users Say Thank You to Mcnbox For This Useful Post:
Old 05-31-2009, 19:58   #2 (permalink)
Member: 217769
Thanks Meter: 24
hi ; not work for me . Please try to test it with " MSP430 Herc/Ath " i've test many phones many times like you say without success.It detects the pinouts but the phone always switch on on "read" process.So it display " Read Flash id Error 1 " THANKS
Old 05-31-2009, 20:45   #3 (permalink)
PhoneCareCenter's Avatar
Member: 574123
Sonork: 100.1581804
Thanks Meter: 1,839
@elhadjioumar
Try To Keep your finger Pressed on the Power Button during all Operations...... Try to post Logs Here.
Good Luck
Old 05-31-2009, 21:09   #4 (permalink)
Member: 217769
Thanks Meter: 24
Your explainations are clears and too easy to be executed but it don't work for me.That's why i ask you to test the soft with " MSP430 Herc/Ath "target please.I've 20 pieces with me and I have the same problem with all them.
Old 05-31-2009, 21:20   #5 (permalink)
Member: 574123
Sonork: 100.1581804
Thanks Meter: 1,839
Contact me in Private, will see how best I can help u out....
Old 05-31-2009, 21:51   #6 (permalink)
Mcnbox's Avatar
Member: 726283
Sonork: 100.76027
Thanks Meter: 7,616
@elhadjioumar
If problem still not fix yet !
Then Post Flash Type or better take a PCB picture of you phone .
Thanks
Old 05-31-2009, 22:20   #7 (permalink)
Member: 217769
Thanks Meter: 24
Originally Posted by Mcnbox View Post
@elhadjioumar
Thanks
this is a picture of one the phones that i tested .The soft detect it like "Adi MSP430 Herc/Ath"
The Following User Says Thank You to elhadjioumar For This Useful Post:
Old 05-31-2009, 22:34   #8 (permalink)
Member: 217769
Thanks Meter: 24
thi is the log:
Welcome to use McnBox!
serial port now: COM14
S/N:MCN20******* - D0*** Firmware Ver:V1.01 CheckSum:952E-B6BE
Box Connected !
The Box High-speed Serial port: COM14
Scanning (please waiting...)
Scanning results:
Type:Herc/Ath
GND:1 5 10 12 13,RXD:7,TXD:9
>>[G:1 5 10 12 13 R:7 T:9] Apply to Box
Holding power-key...
Connected OK
DownLoading boot...
Boot OK
Old 06-01-2009, 01:05   #9 (permalink)
Member: 574123
Sonork: 100.1581804
Thanks Meter: 1,839
@elhadjioumar
As we can see, Phone is Detected & Boot is loaded Perfectly. Try Taking a Picture of the PCB and post it here, make sure Cpu & Flash Ic's are Clearly Visible.... All new Flash Types will be added A.S.A.P.
McnPro Team
Old 06-02-2009, 04:12   #10 (permalink)
Mcnbox's Avatar
Member: 726283
Sonork: 100.76027
Thanks Meter: 7,616
hi , friend
I had test .check here is the logs :
  Connected OK
  DownLoading boot...
  Boot   OK
  Flash   ID: 00980095
  Flash Types: TOSHIBA TC58FVB641XB( 0x800000 )
>>Reading...
BTW, be sure you press the power on button as well .
The Following User Says Thank You to Mcnbox For This Useful Post:
Old 06-02-2009, 15:45   #11 (permalink)
Member: 574123
Sonork: 100.1581804
Thanks Meter: 1,839
U can also try Use the Latest Version of McnPro Software..
Good Luck
Old 06-04-2009, 13:52   #12 (permalink)
Member: 217769
Thanks Meter: 24
Good Luck
HI.YOUR SOFT DON'T WORK I TRIED ALL POSSIBLE TEST IN VAIN .
BUT I HAVE SUCCESS WITH SPIDER CRAKED.IT CONFIRM MCN DETECT THE ADI & SPD BUT CANNOT READ IT. THERE'S LONG DAYS I TRY TO EXPLAIN U THIS BUT YOU NEVER TRY TO BELIEVE ME .NOW I HOPE U WILL DO. MAY BE IT WILL HELP U TO SOLVE MY PROBLEM .
ps: I USE MCN USB SCAN FOR CONNECTION
Old 06-04-2009, 15:29   #13 (permalink)
Member: 574123
Sonork: 100.1581804
Thanks Meter: 1,839
@elhadjioumar
SpreadTrum & ADI are very much Supported by McnPro Software, Tested on over 200pcs before Release. For ADI Chips just keep Power Button Pressed, am sure thats a Simple Instruction.
As for SpreadTrum, there have been no complains, not here, not on our other Forums. We have Posted Instructions on How to Use McnPro Software,we also told u to post Picture of PCB to help u solve the problem.
I also told u to Contact me on Messanger for Fast Support & Step by Step Instructions.
Guess u choose not to be helped.
Old 06-04-2009, 16:05   #14 (permalink)
Member: 217769
Thanks Meter: 24
@elhadjioumar
I'm the only one who write on this section of the forum and u say I don't want to be helped.......I've add your adress on messenger for trying to contact u but your statut is everytime offline...my adress is " [email protected] "
Old 06-04-2009, 18:46   #15 (permalink)
Member: 574123
Sonork: 100.1581804
Thanks Meter: 1,839
@elhadjioumar
I'm Online 18hours Everyday Bro... Almost all Users Contact me on Messanger, anyway if ever u need Fast help. U know where to find me.
Good Luck
McnPro Team
How is working OM CPU with Mcnpro Box >> Mcnbox McnPro Box 0 07-19-2009 10:08
<< How is working Anyka CPU with Mcnpro Box Mcnbox McnPro Box 0 07-04-2009 10:40
How is working Spreadtrum CPU with Mcnpro Box >> Mcnbox McnPro Box 2 06-30-2009 18:17
How is working INFINEON Chips with McnPro Box >> Mcnbox McnPro Box 0 06-02-2009 08:32
How to Format MTK Chips with Mcnpro Box >> PhoneCareCenter McnPro Box 9 04-10-2009 18:58
Page generated in 0.30870 seconds with 9 queries
