Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > McnPro Box
Old 06-03-2009, 08:16   #1 (permalink)
Mcnbox's Avatar
Member: 726283
Sonork: 100.76027
Thanks Meter: 7,616
Arrow Regarding SPD 6600 Series CPU working with Mcnpro Box
Regarding SPD 6600 Series CPU working with Mcnpro Box. ( of course still very easy to play )
1. All most 6600 Series CPU normal we are using USB Scan detect.
2. If always found "Unknow USB device" etc. which means your operation is wrong , and phone still did not connect well .
3. The Right Operation:
  • Connect phone via USB cable, put on power cable "+" "-" to phone battery connector via adaptor ( The red and black one, no need battery )
  • Start to " USB Scan " , No need to power on the phone , holding power on key and press " Read status " , Often we scan 2 times to be sure the scan result which is correct.
  • Then start to find " charge Pin " ( The operate Just follow the window , detect each pin we 'd better waiting 10s ).
  • Other option of the delaytime, normal i setting to 800 , which is Phone power on delayed time .
  • Finish those step , We can press " Start " to Scan phone now .
  • After Computor will be tell you found new device and start to install driver. then can Apply the scan result.
4. Finish Scan , then you can doing Flash , Unlock etc.
if you can have problem , Please post here , let's help you around !
Best Regards !
Mcnbox Team.
The Following 7 Users Say Thank You to Mcnbox For This Useful Post:
Old 06-03-2009, 13:04   #2 (permalink)
Member: 217769
Thanks Meter: 24
Best Regards !
Mcnbox Team.
ok after scan i install corectly the drivers but the optons of spd stay inactive on the soft .I cannot read or unlock ......what is wrong ?
Old 06-03-2009, 14:15   #3 (permalink)
PhoneCareCenter's Avatar
Member: 574123
Sonork: 100.1581804
Thanks Meter: 1,839
@elhadjioumar
Try Using the Latest Version of McnPro Software, also try to Scan TX - RX on some SpreadTrum CPU's to solve your problem, if detected, then continue with Unlock, Format, Flash Options....
Good Luck
The Following User Says Thank You to PhoneCareCenter For This Useful Post:
Old 05-09-2010, 10:05   #4 (permalink)
Member: 134922
Thanks Meter: 3
hello sir, i'm new in mcnbow user
i confuse about using mcn to find pin, read and format for spreadtrum cpu
i have read your explaination
about "connect phone via usb cable" this cable , you mean service cable?
i find all my cable for service cable jack, no usb cable or i must buy for it?
thanks
Old 05-09-2010, 12:31   #5 (permalink)
Mcnbox's Avatar
Member: 726283
Sonork: 100.76027
Thanks Meter: 7,616
thanks
Yes, the cable is service cable from Mcnpro Package, eg, 35-C14C.
Best regards !
Mcnbox
Old 05-10-2010, 04:57   #6 (permalink)
Member: 134922
Thanks Meter: 3
sir, i have done as you told, but after the program found usb d+ and usb d-
the 'unlock, format, read, and flash' icons become hidden
whats wrong? thanks
Old 05-10-2010, 10:37   #7 (permalink)
Mcnbox's Avatar
Member: 726283
Sonork: 100.76027
Thanks Meter: 7,616
whats wrong? thanks
Post here your scan result !
A,) After pinout detect ,then Apply it to Box
B,) The sametime you can see the software interface near bottom right corner, the COM port get changed. and in computer device management control panel there have other port named "SCI USB2Serial" port too.
C,) Then do what you wanna to do for your phone
Best regards !
Mcnbox
The Following User Says Thank You to Mcnbox For This Useful Post:
Old 05-10-2010, 19:14   #8 (permalink)
Member: 315793
Thanks Meter: 1
Hello sir pls tell ,me when i scan usb scan he new hardware but whice driver i selected spd cpu she auto install driver pls hellp me
Old 05-10-2010, 21:00   #9 (permalink)
Mcnbox's Avatar
Member: 726283
Sonork: 100.76027
Thanks Meter: 7,616
So what's your problem ?
A), Driver at C:\Program Files\Mcnbox Team\Mcnpro Box\Drivers\Mobile divers
B), Just choose this folder then install
Any problem , post here , we will help around , don't worry !
Best regards !
Mcnbox
Old 05-13-2010, 04:47   #10 (permalink)
Member: 770791
Sonork: Nick
Thanks Meter: 18
Best Regards !
Mcnbox Team.
try to phonelock maxtron mg-168 but unsuccessful... phone driver was detectd, read phone is ok, but cant to open phone lock code..(cpu spd 6600R)..how to solve?
thanks..
Old 05-13-2010, 11:52   #11 (permalink)
Mcnbox's Avatar
Member: 726283
Sonork: 100.76027
Thanks Meter: 7,616
thanks..
Post Any logs?
Mcnbox
Old 05-13-2010, 13:05   #12 (permalink)
Member: 770791
Sonork: Nick
Thanks Meter: 18
Post Any logs?
Mcnbox
Scan Pinout
Welcome to use McnBox!
Selected COM11 COM12 COM10 COM7
Initialize in progress...
Checking data, wait...
Serial number: MCN2009xxxxxxxxxxxxxxxx
Firmware version: V1.06
Checksum value: 2E95-0DBE
Box Connected!
Box Operating at high speed port: COM12
[G:1 5 10 11 12 13 18 D-:9 D+:8] Apply to Box
Format
Formatting, Please Power Off & On
Start connecting, wait
Boot Info:
Initialize Boot...
CPU : 6600R
Flash(Nand) CODE: 00AD0076
Flash(Nand) Type: NF_HY27XS08121M
Flash(Nand) Size: 04200000
Read
Boot Info:
Initialize Boot...
CPU : 6600R
Completed
Unlock
cant unlock... sory log unlock i forget to save....
Old 05-13-2010, 15:27   #13 (permalink)
Member: 574123
Sonork: 100.1581804
Thanks Meter: 1,839
@Jatnick
If u used the New Method, your File will still be in McnPro Folder in the Programmes Folder of your Hard Disk (Where McnPro is Installed).. Just add the file and Press Unlock..
McnPro Team
Old 05-14-2010, 12:08   #14 (permalink)
Member: 770791
Sonork: Nick
Thanks Meter: 18
Originally Posted by PhoneCareCenter View Post
@Jatnick
McnPro Team
still not open phonelock code
Old 05-14-2010, 13:25   #15 (permalink)
Mcnbox's Avatar
Member: 726283
Sonork: 100.76027
Thanks Meter: 7,616
I checked today , 6600R have some bugs, this problem should be fixed at next version .
Mcnbox
How is working OM CPU with Mcnpro Box >> Mcnbox McnPro Box 0 07-19-2009 10:08
<< How is working Anyka CPU with Mcnpro Box Mcnbox McnPro Box 0 07-04-2009 10:40
How is working Spreadtrum CPU with Mcnpro Box >> Mcnbox McnPro Box 2 06-30-2009 18:17
How is working ADI Chips with McnPro Box >> Mcnbox McnPro Box 17 06-05-2009 14:58
How is working INFINEON Chips with McnPro Box >> Mcnbox McnPro Box 0 06-02-2009 08:32
Page generated in 0.30506 seconds with 9 queries
