Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > CPF-box Products > CPF-Dongle
Old 07-25-2009, 18:27   #1 (permalink)
cellcarcol's Avatar
Member: 138781
Thanks Meter: 850
backup made with cpf_dongle can be used in another model?
hi,
I got a phone DEAD verykool i250 cpu MTK 6229, when I read the flash will be able to revive the dead.
what steps should I follow to read the flash and eeprom of these teams.
I also like to register for your forum.
Old 08-05-2009, 07:21   #2 (permalink)
Member: 317599
Thanks Meter: 32
Talking
Originally Posted by cellcarcol View Post
hi,
i got a phone dead verykool i250 cpu mtk 6229, when i read the flash will be able to revive the dead.
What steps should i follow to read the flash and eeprom of these teams.
yes u read flash file from same working fone and flash dead same set 10000 set on if software problem
Old 08-22-2009, 03:13   #3 (permalink)
Member: 458568
Thanks Meter: 8
First you must plug the phone working good and press read after you read the flash plug dead phone and press write flash is easy but after write flash you must change imei because your phone now have the imei of the phone you read the flash .
I hope you can do it
Old 09-07-2009, 04:52   #4 (permalink)
..:::YMG:::..'s Avatar
Member: 667126
Sonork: 100.1651201
Thanks Meter: 229
what is the size of flash file should be select in cpf dongle to read the flash file?
Old 09-07-2009, 06:50   #5 (permalink)
FasGsm's Avatar
Member: 283725
Sonork: 100.1584053
Thanks Meter: 1,927
No need to select any address cpf will auto detect flash chip size and read file.
Old 09-08-2009, 16:51   #6 (permalink)
Member: 458568
Thanks Meter: 8
after you write flash you must change imei to original because backup imei field too .
Old 09-17-2009, 19:51   #7 (permalink)
cellcarcol's Avatar
Member: 138781
Thanks Meter: 850
already solved and thanks to a crack program from which you copied
Infinity Files can be USED in CPF-II? raja16sep CPF-BOX Ⅱ 1 03-25-2009 15:58
can a k750 main and fs backup be used in another k750? sorinm SonyEricsson (USB-Smart) 2 08-19-2006 10:43
MOTOROLA E1000 ,V1010 ,V3X can be depersonalized MMS so can be used in any COUNTRY? crossings Smart-Clip 0 04-01-2006 11:26
what wintesla can be used in win xp alif30 Phoenix Black Box 4 02-11-2005 10:23
Which LCD's can be used in 3100? atoo Nokia Digital Core Technology 4 ( DCT-4 ) 6 12-13-2003 17:31
Page generated in 0.17249 seconds with 10 queries
