Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > MXKEY (by Alim Hape) > MXKEY Nokia Flasher and Unlocker (by Alim Hape)
Old 09-16-2009, 14:29   #1 (permalink)
kalpeshoza's Avatar
Member: 462292
Thanks Meter: 397
N-85 rm-333 after flashing problem
Version from phone: ICPR72_08w44.1
Version from file: 30.019
Using device: UFS_USB V2.8 (c) SarasSoft 2007.
RAP Data :
SYSTEM ASIC ID: 000000010000022600010006400C192101031103 [RAPIDO3G ver: 1.x]
EM1 ID: 00000295
EM2 ID: 00000B22
PUBLIC ID: 14B00007F07100521EE22B1C7F34D6A3ECC426E3
ASIC MODE ID: 00
ROOT KEY HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE
ROM ID: 4B9B75103E691FF8
SecondaryBoot: RAPIDOv11_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3AC0
Supported RAP Ids: 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105
FlashID0: 00EC 0040 - 0040 0121 [Samsung 2Gb DDP OneNAND,2 Gbits] type: ONENAND,RAP
ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000
ExtDEVC: FFFF 0000 - 0000 0000
Algorithm: RAPIDOv11_algo.fg [XSR 1.5] version: 1.35.0 revision: 0.0 size: 0x272B0
RAP PAPUBKEYS HASH: B5385A493D2188678E1FD88DA506480F874E2949
Reading RAP NPC (0x190 bytes).
Reading RAP VARIANT (0x0 bytes).
Reading RAP CCC (0x160 bytes).
Reading RAP HWC (0xD4 bytes).
Flash Imei: 35637602269779
NPC_DATA saved OK
CCC_DATA saved OK
HWC_DATA saved OK
SIMLOCK_DATA saved OK
SIMLOCK_KEY_DATA saved OK
WMDRM_PD_DATA saved OK
RF_DATA saved OK
WARRANTY_DATA saved OK
PROD_DATA saved OK
BT_DATA saved OK
LOCK_DATA saved OK
LOCK120_DATA saved OK
BB_DATA saved OK
WLAN_DATA saved OK
RPL saved to "C:\mobileEx\3.2\data\backup\RPL\BB5_3563760226977 9_BACK.rpl"
Processing file: RM-333_30.019_prd.core.fpsx as MCU
[BB5,XSR 1.5] size: 42.23 MB
Supported RAP Ids: 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101051103, 400C192101051103
RAP Data :
EM1 ID: 00000295
EM2 ID: 00000B22
ASIC MODE ID: 00
Total erase size: 64.00 KB
CMT ONENAND area [00040000-00082FFF]
CMT ONENAND area [00083400-003FFFFF]
CMT ONENAND area [00800000-00D5FFFF]
CMT ONENAND area [00D60000-09F7FFFF]
Format NAND
erased in 0.875 s
Flash programming ...
Valid PAPUB key found
CMT PAPUBKEYS, RAP Certificate 104 v1 written.
Programming completed in 3 min 31.453 s
Processing file: RM-333_30.019_021_prd.language.fpsx as PPM
[BB5,XSR 1.5] size: 22.81 MB
RAP Data :
EM1 ID: 00000295
EM2 ID: 00000B22
ASIC MODE ID: 00
Total erase size: 24.37 MB
CMT ONENAND area [07D20000-0957FFFF]
erased in 0.156 s
Programming completed in 2 min 1.843 s
Processing file: RM-333_30.019_53.1_prd.customer.fpsx as PPM
[BB5,XSR 1.5] size: 7.96 KB
RAP Data :
EM1 ID: 00000295
EM2 ID: 00000B22
ASIC MODE ID: 00
Total erase size: 10.00 MB
CMT ONENAND area [09580000-09F7FFFF]
erased in 0.093 s
Programming completed in 0.235 s
Processing file: rm333_ENO_x_2009wk20v0.A014.fpsx as CNT
[BB5,XSR 1.5] size: 2.59 MB
RAP Data :
EM1 ID: 00000295
EM2 ID: 00000B22
ASIC MODE ID: 00
Total erase size: 4.00 MB
CMT ONENAND area [00400000-007FFFFF]
erased in 0.062 s
Programming completed in 13.969 s
Processing file: RM-333_30.019_003_000_U001.uda.fpsx as CNT
[BB5,XSR 1.5] size: 15.99 MB
RAP Data :
EM1 ID: 00000295
EM2 ID: 00000B22
ASIC MODE ID: 00
Total erase size: 87.62 MB
CMT ONENAND area [09F80000-0F71FFFF]
erased in 0.500 s
Programming completed in 1 min 24.937 s
Flashing completed in 8 min 8.937 s
Phone Type: RM-333 (Nokia N85)
SW Version: V ICPR72_09w18.1 19-05-09 RM-333 (c) Nokia
Imei plain: 35637602269779-5
Product Code: 0561390
Language Pack:
- not available.
This phone have PM308 protected, SD security in not restorable.
Avoid manual erase to this phone !
SIMLOCK seems to be valid
SUPERDONGLE_KEY seems to be valid
SIMLOCK_TEST passed
SECURITY_TEST passed
Imei: 356376022697795
Version: SIMLOCK SERVER
Provider: Nokia Test, Country: Finland
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
PROFILE_BITS: 0000000000000000
BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
Total time to process is 8 min 20.969 s
AFTER flashing all UI setting ok and testmode in display but when power on only vibrete
The Following User Says Thank You to kalpeshoza For This Useful Post:
Old 09-16-2009, 15:10   #2 (permalink)
joni_rajpura's Avatar
Member: 508072
Thanks Meter: 1,621
try to power on with flesh cablein normel mode
Old 09-16-2009, 21:08   #3 (permalink)
mohA™'s Avatar
Member: 199405
Sonork: 100.1576571
Thanks Meter: 322
its normal mode after flashing with wrong flash file
next time look first what u choise in ur flash path
u reflashed ENO file in UR CONTENT PACKAGE
REFLASH AGAIN WITH RIGHT PACKAGE
WBR
The Following User Says Thank You to mohA™ For This Useful Post:
Old 09-17-2009, 05:32   #4 (permalink)
kalpeshoza's Avatar
Member: 462292
Thanks Meter: 397
WBR
Thanks but i am not select file manually is auto selected flash file any way i try again and post result.
Old 09-17-2009, 14:48   #5 (permalink)
kalpeshoza's Avatar
Member: 462292
Thanks Meter: 397
flash ok now
flashing ok mobile in on now but i can not restore my o/g rpl backup see
RPL: "C:\mobileEx\3.2\data\backup\RPL\BB5_3563760226977 9_BACK.rpl"
Updating PRODUCTCODE (0561390)... OK
Updating PSN (CSD805462)... OK
Updating HWID (1102)... OK
Updating SIMLOCK...OK
Updating SUPERDONGLE_KEY from backup ...error 0x0
Updating WMDRM_PD...OK
Updating WARRANTY ...OK
Updating PROD ...OK
Updating BT ...OK
Restoring RF/BB DATA from backup ...
RAP Data :
EM1 ID: 00000295
EM2 ID: 00000B22
ASIC MODE ID: 00
Erasing CMT NPC ... OK
Updating RF ...OK
Updating BB ...OK
RAP Data :
EM1 ID: 00000295
EM2 ID: 00000B22
ASIC MODE ID: 00
NPC verified Ok.
Updating CMT NPC ...OK
Updating CMT CCC ...OK
Updating CMT HWC ...OK
Certificate programmed successfully !
SW Version: V ICPR72_09w18.2 22-06-09 RM-333 (c) Nokia
Language Pack:
- not available.
SUPERDONGLE_KEY invalid!
WD timer enabled, phone will reboot itself after 3 min.
SIMLOCK_TEST passed
Counter: 0/3, 0/10
The Following 2 Users Say Thank You to kalpeshoza For This Useful Post:
Old 09-17-2009, 17:13   #6 (permalink)
Andra's Avatar
Member: 976728
Sonork: 1589709
Thanks Meter: 4,775
@kalpeshoza
first err is bug in new version.
maybe u can use old version.
SIMLOCK_TEST passed
and your phone must restore backup ( if have ) or fixing by RPL from nokia server (if doesnt have)
br,
Old 09-17-2009, 17:25   #7 (permalink)
kalpeshoza's Avatar
Member: 462292
Thanks Meter: 397
@MobileEx-Team
yes i have a o/g rpl back up i try with write rpl and restreimei but same problem not try in old version yet try and tell u result tommorow hope old version work for me ................
Old 09-18-2009, 03:46   #8 (permalink)
Andra's Avatar
Member: 976728
Sonork: 1589709
Thanks Meter: 4,775
and u have
SIMLOCK_TEST passed
point is.
must looking unprotect frimware in same flash add
ex :
Phone with Protect Frimware - Phone With Unprotect Frimware
5130 - 5310
5800 - E75
to restore your SuperDongle.
br,
Old 09-18-2009, 05:52   #9 (permalink)
kalpeshoza's Avatar
Member: 462292
Thanks Meter: 397
same error in old version
how can i recover .....
Old 09-18-2009, 07:25   #10 (permalink)
Andra's Avatar
Member: 976728
Sonork: 1589709
Thanks Meter: 4,775
can u read this
br,
The Following User Says Thank You to Andra For This Useful Post:
Old 09-19-2009, 11:59   #11 (permalink)
kalpeshoza's Avatar
Member: 462292
Thanks Meter: 397
@ MobileEx-Team THanks i understand that but tell me one thing if i get rpl form server and then right it work ? or waitng for solu in 308 pm
Old 09-21-2009, 15:17   #12 (permalink)
Chevka's Avatar
Member: 82106
Thanks Meter: 1,208
upload here your original backup of RPL and read full PM of the phone.
i'll try to help, but not a promise....
The Following 2 Users Say Thank You to Chevka For This Useful Post:
Old 09-21-2009, 18:56   #13 (permalink)
mohA™'s Avatar
Member: 199405
Sonork: 100.1576571
Thanks Meter: 322
if u have pm 308 or full pm backup, try this program 2 can convert it 2 rpl file and write it 2ur phone ,may be ur full 308 will restore in rpl data
http://gsm-cafe.com/uploaded/7_1253305297.rar
many thanks 4 (www.gsm-cafe.com)
WBR
The Following 5 Users Say Thank You to mohA™ For This Useful Post:
Old 09-21-2009, 21:34   #14 (permalink)
Member: 169616
Thanks Meter: 20
WBR
IMEI is now 12345............... et PM 308 broken, no backup
I think that ASK is the one solution to restore RPL but any tool to convert it
This my ASK for 6500s if you can change to RPL
[CERT_PROG_DATA_IN]
RAP_PUBLIC_ID=15500217379402546C24A90908A6BEC3860A F27B
APE_PUBLIC_ID=
Old 09-22-2009, 05:13   #15 (permalink)
kalpeshoza's Avatar
Member: 462292
Thanks Meter: 397
check PM bro ..........
N 85 - RM 333 py MXKEY ??? petit1959 MXKEY Nokia Flasher and Unlocker (by Alim Hape) 1 02-25-2010 21:11
plez help this problem nokia 7210c rm-436 after flashing dead khalid0909 HWK 3 06-08-2009 13:28
Page generated in 0.31636 seconds with 10 queries
