10-21-2009, 09:01 | #1 (permalink) |
Freak Poster Join Date: May 2006
Member: 279960 Status: Offline Thanks Meter: 56 | Is there any patch or anything to kill bb5 watch dog timer? PS: this is for only certificate damaged phones ( dont post here that rpl will fix the problem all know its ) |
The Following User Says Thank You to GsmTracer For This Useful Post: |
10-21-2009, 09:23 | #2 (permalink) | |
selective member algo bruteforce SL3 Join Date: Dec 2007 Location: IRELAND
Member: 665113 Status: Offline Sonork: 100.1583029 Thanks Meter: 1,165 | Quote:
If you are asking about this, you should know that if anyone would have managed to find the location of SUPERDONGLE_KEY in PM file or from any flash area of the damaged phone that has to be decoded / extracted, I think solution would be already given to public free/or paid. Following by this that most tools can recover BB5 SIMLOCK_KEY and SIMLOCK_KEY_DATA values on SW DAMAGED SL1 and SL2 phones, and as most tools does backup nothing but IMEI(and the following: NPC_DATA , CCC_DATA , HWC_DATA , R&D) but leaving SUPERDONGLE_KEY and other important keys behind the backup, or we should say - there is no programmer that can extract SUPERDONGLE_KEY from phone PM file or FLASH file, because if it would be - we should have full RPL REPAIR service working sepparately from NOKIA TUCSON server - independent, or credit/log based system that tools would provide... Pathed or Rebuild SUPERDONGLE_KEY data would be very valuable... If I'm wrong - maybe someone are working on it, or if they have it they are preparing for something big and would not let the information trough fingers because this is worth dozens of cash. In either way it would be very useful.... BR Last edited by Mr.Ultimate; 10-21-2009 at 09:32. | |
The Following User Says Thank You to Mr.Ultimate For This Useful Post: |
10-21-2009, 11:54 | #3 (permalink) |
No Life Poster Join Date: Dec 2006 Location: Karachi, Pakistan Age: 33
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,589 | Hi, What is security watchdog ? Security watchdog is HW module in the CPU that monitors software activity and restarts power to all CPU logic, phone with invalid NPC 12345? the wd timer will be enabled. And the security watchdog timer will switch the phone off after 15-30 minutes, This is aslo a part of PM and flash as above said, superdongel_key location is PM 1 and 309 I think, this is special PM fields that contains sx4 key and signing data,RF,Energy Managment data etc, when st_security_failed in phone self-test means need to load superdongel_key, writing this fileds from another working phone works sometime but with WD problem. At this moment no one can make this PM fields. Regards, Ali |
The Following 7 Users Say Thank You to ..::Angel::.. For This Useful Post: |
10-21-2009, 15:13 | #4 (permalink) |
Member: 279960 Status: Offline Thanks Meter: 56 | talking about to patch the timer not to disable.. that means to extend the timer to its maximum time not to 15 min etc.. there may be possible to extend its to maximum timing that may be 604 800 seconds ( 7 days ) or 2 629 743 seconds ( 1 month ) etc... wd timer cant be disabled w/o superdongle key but there is possibility to patch its timer.. |
10-21-2009, 18:07 | #5 (permalink) | |
No Life Poster Join Date: Feb 2000 Location: UK
Member: 1024 Status: Offline Thanks Meter: 5,510 | Quote:
save to a text file (job for a 4 year old with 1 mg of brain) ? And what's the point of that - you will back up data of brand new, out of the box phones ? It's best to use a box that don't screw your phone while flashing. If you have mobile phone shop you will now that 99% of the phones that come with damaged PM - you have no back up for it. So pretty useless feature, unless if you want it done just for the sport. BR, Alex B-phreaks | |
10-21-2009, 18:35 | #6 (permalink) | |
No Life Poster Join Date: Dec 2000 Location: J.A.U - Just Another Unlocker Age: 44
Member: 2878 Status: Offline Thanks Meter: 9,123 | Quote:
i dont resarched this, but i think there is NO timer. the phone have watchdog with will check the phone while its running. the phone cant check complete all while startup, so it checks all while it is running, and when the security find some invalid info the watchdog restart the phone... maybe patching out this watchdog check or the restart function would work, but you can not extend this cause there are nothing to extend... | |
The Following 3 Users Say Thank You to oOXTCOo For This Useful Post: |
10-23-2009, 00:06 | #7 (permalink) | |
No Life Poster Join Date: Jan 2009 Location: England Age: 59
Member: 947561 Status: Offline Thanks Meter: 14,053 | Quote:
To be honest it could be usefull. If we could extract the complete RPL from a phone, just with one back-up we could always recover the phone whatever happens. As well it would help a lot in the upgrade/downgrade of the phones with PM308 write protected from/to V30/V31/v300 BR and always congratulations for jour tool Alex | |
10-23-2009, 01:44 | #8 (permalink) | |
My other point - only very few boxes screw phones up while flashing - yes, most times it happens because of user fault, and believe me I know how to use service tools, so keep your comment for someone else, find me crying somewhere - oh this box fu(ked-up my phone and etc.etc.. Im saying that 4 year old child couldnt create patch file for PA_SL2 PM308 protected phone MCU to patch certain area and restore it after rewriting PM308 field after successful MCU patch, and you know that, and Im not talking about brand new out of the box phones, Im talking about wrong way flashed phones/dead after downgrade, partially alive after sw interference phones repair just one like I had. All I was talking about that there is no one yet with patch flash trick out yet, only crossflash can help with protected PM308 rewriting... Thats all I wanted to say, no offence. And by the way - BIG THANKS to MX-KEY that is a very good and successful tool for nokia phones! My best regards to MX-KEY team! BR | |
10-23-2009, 01:53 | #9 (permalink) | |
BR | |
10-23-2009, 04:12 | #12 (permalink) |
Freak Poster Join Date: Mar 2007 Location: _-_-_-_-____---___---____---
Member: 459407 Status: Offline Sonork: 100.110689 Thanks Meter: 164 | i think super dongle located at pm filed 308 any section i didn't test but i try to repair it with other modified pm but not susses only one tinge strange that e65 WD invalid i writ pm From another working phone after some modify i see at mx key super dongle pass but when i reconnect phone again was changed to invalid i didn't know why ? |
10-23-2009, 07:03 | #13 (permalink) |
No Life Poster Join Date: Sep 2002 Location: Türkiye Age: 48
Member: 15880 Status: Offline Sonork: 100.1612155 Thanks Meter: 452 | i have one more phone with wd i have flashed and unlocked with cyclone after this all 4-5 mi. restarted phones i have bekups bud not help me model is 5800 i have eased flashed write rpl pm full pm etc. etc. same problem not helped for repair my problme how to can i see have this phone wd problme or not b.r senkron24 |
10-23-2009, 09:25 | #14 (permalink) | |
1. You should use nokia E75 flash to flash your 5800 MCU (this will allow you to overwrite protected PM308 field with original value that you have in undamaged PM backup file) 2. After successful flash to enable your phone to enter TEST/LOCAL mode you must erase NPC Certificate, phone may not show on screen that is in local/test mode but it should scan ok! 3. Write full PM backup that you have made before everything gone wrong. 4. After PM write Flash your 5800 with this file: RM-356_dp_5800d-1_ENO_x_2008wk42v0.033.fpsx 5. Flash with latest sw version and after that do SX4 auth, if unsucsessful SX4 bypas to rewrite important PM fields with same PM file 6. Write First your RPL backup file made with that phone 7. Post results here It worked for me ok To find out if any security tests / simlock tests / superdongle test have failed I would recommend using MX-Key 3.2 Rev.5.4 - its one of the best tools I've used yet for inspecting faults, otherwise you can use Nokia Phoenix Service tool BR Last edited by Mr.Ultimate; 10-23-2009 at 09:34. | |
10-23-2009, 11:38 | #15 (permalink) | |
Freak Poster Join Date: Feb 2007
Member: 456284 Status: Offline Thanks Meter: 14 | Quote:
I have a 5800 restart after 2 minutes.......... | |
is there any documant about lang info in bb5 | recepoz | Nokia Base Band 5 ( BB-5 ) | 4 | 01-24-2011 08:44 |
is there any code or software sulution for unlocking 2.2.1? | Cake | iPhone 2 / iPhone 3G / iPhone 3GS | 2 | 05-30-2009 04:39 |
is there any patch unlocking for A2 series | neeraj1st | SETool2 | 3 | 10-15-2008 11:05 |
is there any site or forum that can help me to repair my laptop?? | infogsm | Off Topic Zone | 9 | 04-18-2004 15:59 |
Is there any Site with Picutes to know all Mot. Models ? | AboAli | Motorola Old Legacy (EMMI) | 0 | 09-27-2001 15:48 |
