Old 11-06-2009, 15:16   #1 (permalink)
mendis's Avatar
Member: 221857
Thanks Meter: 13
NEED PINOUT FOR Egltel V6
hi,
need pinout for Egltel V6.
Old 11-08-2009, 20:30   #2 (permalink)
Member: 148515
Thanks Meter: 19,534
Originally Posted by mendis View Post
hi,
hello!
lets start from checking what CPU it is based.
you either can do this by disassembling phone or by typing *#0044# and pressing green (send) button.
if you will see "language set: english"- you can be sure, that this phone is supported by Infintiy software
If it does supported, and you dont have infinity Pinfinder- i can teach how to find pinout in minutes.
Just by measuring voltage on phone system connector pins.
Old 11-10-2009, 15:05   #3 (permalink)
mendis's Avatar
Member: 221857
Thanks Meter: 13
Hi thanks for your quick reply
That phone based on MT6223DA cpu.It have 2X5 mini usb system conector. now it in dead condition.I try to find TX,RX pins using my INFINITY PINFINDER but it not success.please guide me how to find TX,RX pins.
thanks
Old 11-10-2009, 16:06   #4 (permalink)
Member: 148515
hello!
what makes you think that it is dead by software reason? usually pinfinder can find pinout even on dead phone, if it is dead by software reason
Old 11-11-2009, 02:20   #5 (permalink)
mendis's Avatar
Member: 221857
Thanks Meter: 13
yes its dead due to software reason.i connect power supply with correct voltage when i press power butten its taking startup current.
Old 11-11-2009, 21:18   #6 (permalink)
Member: 148515
hello!
did you do modifications of main infinity box? (diode removing and shortcutting) ?
Old 11-12-2009, 02:04   #7 (permalink)
mendis's Avatar
Member: 221857
Thanks Meter: 13
hi,
no im not do anything to pin finder and INFINITY main box. still it under warranty.
Old 11-12-2009, 02:25   #8 (permalink)
Member: 148515
hello!
it is better to open main infinity box and remove that diode.
this will increase box output voltage to 5v instead of 4,2-4,3
procedure is described in pinfinder user manual
Old 11-12-2009, 15:44   #9 (permalink)
mendis's Avatar
Member: 221857
Thanks Meter: 13
hello
I modified my INFINITY box and try it still my pin finder can`t find TX,RX pins
Old 11-12-2009, 16:03   #10 (permalink)
Member: 130995
Thanks Meter: 35,227
hello
Hello,
Do you have an experience with PinFinder ?
Is it your first phone that you want to detect with PinFinder ?
Also, it may be that bottom connector do not have Rx/Tx pins, so try to open phone and check it's PCB, it may be that you will see Rx/Tx test points at phone PCB.
Old 11-12-2009, 16:30   #11 (permalink)
mendis's Avatar
Member: 221857
Thanks Meter: 13
Originally Posted by InfinitySupport View Post
Hello,
hello,
I have well experience with pin finder and infinity box. last few day i flash more thane 100 phones.and i open this phone and try to find TX,RX pins there are no any test point marks on that phone.
Old 11-12-2009, 16:37   #12 (permalink)
mendis's Avatar
Member: 221857
Thanks Meter: 13
please tell how to do this ?
Old 11-12-2009, 18:05   #13 (permalink)
Member: 130995
Hello,
Please, check this instruction: C:\Program Files\InfinityBox\pinout\ChineseMiracle\_How_to_fi nd_pinout.jpg
Old 11-14-2009, 10:50   #14 (permalink)
Member: 390205
pin0 finder not fine
Old 01-12-2010, 11:28   #15 (permalink)
Member: 390205
neeed pinout 4tx 5rx 6gnd
I need TP for MOTOROLA V6 tsarkh Motorola P2k 13 05-23-2007 19:38
need firmware for 5510 V6.00 bulet Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 04-08-2004 22:04
need pinout for Nokia 3520 or 3560. very need sp-lox Nokia CDMA 1 12-30-2003 20:59
need code for 8310 v6.20 !! crown Phone Unlocking Codes & Maps 0 11-27-2003 20:09
i need dongle for wintesla v6.43.. alnasser Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 03-07-2001 03:41
Page generated in 0.26603 seconds with 9 queries
