Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > MXKEY (by Alim Hape) > MXKEY Nokia Flasher and Unlocker (by Alim Hape)
Old 11-08-2009, 05:55   #1 (permalink)
asia_gsm's Avatar
Member: 435412
Sonork: 100.1608142
Thanks Meter: 289
Smile 7210c contact service+start up failed+auto off tested by mxkey done
flash already high and low version
using jaf ang hwk but still contact service
so i decided to info using mxkey
result: security failed
video procedure:
Download 5130_CS_Removed.rar from Sendspace.com - send big files the easy way
my use pm:
Download 7210c Full Modified PM.rar from Sendspace.com - send big files the easy way
sreenshot&loags:
Using device: UFS_USB V2.8 (c) SarasSoft 2007.
RAP Data :
SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x]
EM1 ID: 00000295
EM2 ID: 00000B22
PUBLIC ID: 0C60021127B45850E61C2AA8635C02C3E2BC42D3
ASIC MODE ID: 00
ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723
ROM ID: 273F6D55DFAAF68F
SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 9.11.1 revision: 0.0 size: 0x3C00
Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
FlashID0: 0089 8982 - 0000 8A31 [Intel NU48F512,512 Mbits] type: NOR,RAP
ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000
ExtDEVC: FFFF 0000 - 0000 0000
Algorithm: RAP3Gv3_algo_131.fg [BB5 ALGORITHM] version: 1.31.0 revision: 0.0 size: 0x297E0
Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
RAP PAPUBKEYS HASH: F1DCA5EA5203CD30A64D4D95ABCD621F4AB23026
Original Imei: 35574302511136
Original Product code: 0566933
Bluetooth ID: 0022FDE0F610
Phone Type: RM-436 (Nokia 7210 Supernova)
SW Version: V 06.51 23-03-09 RM-436 (c) Nokia
Imei plain: 355743xxxx
Product Code: 0566933
Language Pack:
- not available.
This phone have PM308 protected, SD security in not restorable.
- Avoid manual erase to this phone !
SIMLOCK seems to be valid
SUPERDONGLE_KEY seems to be valid
SIMLOCK_TEST passed
SECURITY_TEST passed
Imei: 355743025xxxxx
Version: SIMLOCK SERVER
Provider: Nokia Test, Country: Finland
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
PROFILE_BITS: 0000000000000000
BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
The Following 9 Users Say Thank You to asia_gsm For This Useful Post:
Old 11-08-2009, 09:39   #2 (permalink)
ashraf_bcs's Avatar
Member: 303373
Sonork: 100.1584377
Thanks Meter: 1,241
This solution works when phone simlock data is valid.If simlock data invalid or superdongle key damaged than not work.But we recieve maximum 7210c contact service phones with simlock data damaged. I just did it with jaf by writing pm feild 1 n 309 with sx4.when simlock data is correct n phone is contact service.
Old 11-08-2009, 14:38   #3 (permalink)
GsmUniversal's Avatar
Member: 649528
Sonork: 100.1590443
Thanks Meter: 6,958
this will not done yet... if simlock data is corrupt i mean pm 308 data is corrupted so no solution on any device..
only bb5 rpl will be solve that matter.
Old 11-08-2009, 15:48   #4 (permalink)
Member: 766984
Thanks Meter: 2
i think u need 5 steps
1- packup imie
2- erase phone
3write pm without 308
4-write imie packup
5-sx4
try it and im waitiing u
Old 12-19-2009, 15:34   #5 (permalink)
Member: 779470
Sonork: Waseem mobile
Thanks Meter: 101
plz help me
SW Version: V 07.23 17-07-09 RM-436 (c) Nokia
Imei plain: 35931002?????????
Product Code: 0566806
Language Pack:
- not available.
SIMLOCK invalid!
SUPERDONGLE_KEY invalid!
- WD timer enabled, phone will reboot itself after 3 min.
SIMLOCK_TEST failed!
TimeStamp: 2009-07-20T08:46:24Z
SW Version: 07.23
Variant Version: 012
ProductProfile: RM436_0566806_07.23_012.spr
Simlock: 0566806_simlock.bin
SIMLOCK_DATA corrupted!
Old 12-19-2009, 15:38   #6 (permalink)
ghost_team's Avatar
Member: 332555
Sonork: 100.114258
Thanks Meter: 30
can u upload video and pm file on rapidshare
thankx
Old 12-19-2009, 19:25   #7 (permalink)
rio_wp's Avatar
Member: 783663
Sonork: Ahmad Noer Asyadda
Thanks Meter: 32
I agree with your opinion sir
if only SECURITY_TEST failed.....
I think by trying to put a good pm and do execution PMM Auth. above problems quickly completed.
Tested by MXKEY Team. Take the chance to win 1 for free. What can be ? MANOLE MXKEY LABORATORY (Mobile Expert Laboratory) 514 04-07-2010 10:54
N96 Phone Start-up failed Contact the retailer (security Test failed in reading) dmaetrey MXKEY Nokia Flasher and Unlocker (by Alim Hape) 4 02-08-2010 13:46
N85 Phone start up failed sim lock test failed how to solve it?? alasdro Nokia Base Band 5 ( BB-5 ) 7 12-14-2009 18:29
7210c contact service+start up failed+auto off tested by mxkey done "KINO" MXKEY Nokia Flasher and Unlocker (by Alim Hape) 10 11-07-2009 07:58
@ VDO HOWTO repair contact service ,Start up failed By MX-KEY Tom_ptm MXKEY Nokia Flasher and Unlocker (by Alim Hape) 1 11-05-2009 15:26
Page generated in 0.28313 seconds with 9 queries
