12-06-2009, 10:17 | #1 (permalink) |
No Life Poster Join Date: Jun 2005 Location: Kamalia, Pakistan. Age: 38
Member: 151871 Status: Offline Thanks Meter: 71,421 | Do you Try to unlock New T156 with Infinity ? -> Post log here !! Please, try to use this software: http://www.infinity-box.com/download...1_v1.72_v1.rar Use "sp-unlock #2" button from software "Service" page. Please, try to make unlock, let's see results. If you will see at end of log text like this: verification result: ... verification result: ... verification result: ... verification result: ... verification result: ... and if phone will be not unlocked after first try, do not try to unlock phone again ! Please, send information about unlock result, operation log and full text from phone back label to [email protected] Thank you ! Mobile should be Powered ON and must be light on !! condition when you try to unlock it !! After unlock try , Post here your Log with Results Once Again Really Thanks to Infinity Team to give us that solution , even its under Test but i really Happy !! BR Faisal_Computer Last edited by Faisal_Computer; 12-06-2009 at 10:24. |
The Following 21 Users Say Thank You to Faisal_Computer For This Useful Post: |
12-06-2009, 10:44 | #3 (permalink) |
Member: 151871 Status: Offline Thanks Meter: 71,421 | => module version: 1.72 => operation started: COM3 ==> set_com_port ==> set_baud_rate ==> check_comm_link ==> set_v24_mode ==> set_baud_rate ==> check_comm_link ==> get_ms_id imei: 353081039201168 ==> get_sw_version sw ver: P1.2PU01V01.01 ==> get_sec_version sec ver: 00.31Et(4242) ==> reading... access result: 00 access level: 03 verification result: F06001005612010000010105020503050405040000000000 verification result: F0600100561200FF00010105020503050405000000000000 verification result: F0600100561200FF00010105020503050405000000000000 verification result: F0600100561200FF00010105020503050405000000000000 verification result: F0600100561200FF00010105020503050405000000000000 last error: No errors ==> close_com_port => operation finished Finished, time used: 6 sec Power Off/On phone now ! not unlocked !! BR Faisal_Computer |
The Following 8 Users Say Thank You to Faisal_Computer For This Useful Post: |
12-06-2009, 10:45 | #4 (permalink) |
Member: 151871 Status: Offline Thanks Meter: 71,421 | => module version: 1.72 => operation started: COM3 ==> set_com_port ==> set_baud_rate ==> check_comm_link ==> set_v24_mode ==> set_baud_rate ==> check_comm_link ==> get_ms_id imei: 353081035032955 ==> get_sw_version sw ver: P1.2PU01V01.01 ==> get_sec_version sec ver: 00.31Et(4242) ==> reading... access result: 00 access level: 03 verification result: F0600100561200FF00040105020503050405000000000000 verification result: F0600100561200FF00040105020503050405000000000000 verification result: F0600100561200FF00040105020503050405000000000000 verification result: F0600100561200FF00040105020503050405000000000000 verification result: F0600100561200FF00040105020503050405000000000000 last error: No errors ==> close_com_port => operation finished Finished, time used: 7 sec Power Off/On phone now ! Unlock DONE !! with Infinity BR Faisal_Computer |
The Following 11 Users Say Thank You to Faisal_Computer For This Useful Post: |
12-06-2009, 10:46 | #5 (permalink) |
Member: 151871 Status: Offline Thanks Meter: 71,421 | => module version: 1.72 => operation started: COM3 ==> set_com_port ==> set_baud_rate ==> check_comm_link ==> set_v24_mode ==> set_baud_rate ==> check_comm_link ==> get_ms_id imei: 353081039139566 ==> get_sw_version sw ver: P1.2PU01V01.01 ==> get_sec_version sec ver: 00.31Et(4242) ==> reading... access result: 00 access level: 03 verification result: F06001005612010000010105020503050405020000000000 verification result: F0600100561200FF00010105020503050405000000000000 verification result: F0600100561200FF00010105020503050405000000000000 verification result: F0600100561200FF00010105020503050405000000000000 verification result: F0600100561200FF00010105020503050405000000000000 last error: No errors ==> close_com_port => operation finished Finished, time used: 7 sec Power Off/On phone now ! not unlocked !! Br Faisal_Computer |
The Following 6 Users Say Thank You to Faisal_Computer For This Useful Post: |
12-06-2009, 10:47 | #6 (permalink) |
Member: 151871 Status: Offline Thanks Meter: 71,421 | => module version: 1.72 => operation started: COM3 ==> set_com_port ==> set_baud_rate ==> check_comm_link ==> set_v24_mode ==> set_baud_rate ==> check_comm_link ==> get_ms_id imei: 353081036854126 ==> get_sw_version sw ver: P1.2PU03V01.01 ==> get_sec_version sec ver: 00.3231Et(4242) ==> reading... access result: 00 access level: 03 verification result: F06001005612010000010105020503050405020000000000 verification result: F0600100561200FF00010105020503050405000000000000 verification result: F0600100561200FF00010105020503050405000000000000 verification result: F0600100561200FF00010105020503050405000000000000 verification result: F0600100561200FF00010105020503050405000000000000 last error: No errors ==> close_com_port => operation finished Finished, time used: 6 sec Power Off/On phone now ! this mobile not unlock !! as i seen one thing that which mobile sag_d can , infinity also unlock and which Sag_d not unlock infinity also not unlock it BR Faisal_Computer |
12-06-2009, 10:50 | #7 (permalink) |
Freak Poster Join Date: Feb 2007
Member: 453604 Status: Offline Thanks Meter: 33 | CAN NOT UNLOCK THIS FONE, => module version: 1.72 => operation started: COM3 ==> set_com_port ==> set_baud_rate ==> check_comm_link ==> set_v24_mode ==> set_baud_rate ==> check_comm_link ==> get_ms_id imei: 353081033761597 ==> get_sw_version sw ver: P1.2PU01V01.01 ==> get_sec_version sec ver: 00.31Et(4242) ==> reading... access result: 00 access level: 03 verification result: F0600100561200FF00040105020503050405000000000000 verification result: F0600100561200FF00040105020503050405000000000000 verification result: F0600100561200FF00040105020503050405000000000000 verification result: F0600100561200FF00040105020503050405000000000000 verification result: F0600100561200FF00040105020503050405000000000000 last error: No errors ==> close_com_port => operation finished Finished, time used: 13 sec Power Off/On phone now ! Regards malik. |
The Following 5 Users Say Thank You to kash786 For This Useful Post: |
12-06-2009, 13:28 | #8 (permalink) |
Temporary banned !! Join Date: Apr 2007
Member: 482214 Status: Offline Sonork: 100.1617896 Thanks Meter: 316 | > module version: 1.72 => operation started: COM6 ==> set_com_port ==> set_baud_rate ==> check_comm_link ==> set_v24_mode ==> set_baud_rate ==> check_comm_link last error: Timeout while receiving - please check connection and that DUT is ON ==> close_com_port => operation finished Finished, time used: 24 sec Power Off/On phone now ! |
The Following 6 Users Say Thank You to m_tahir1 For This Useful Post: |
12-06-2009, 14:09 | #9 (permalink) |
Member: 482214 Status: Offline Sonork: 100.1617896 Thanks Meter: 316 | Huawei t156 new DWD_LOGGER HUAWEI T156 NEW => operation started ==> set_com_port ==> set_baud_rate ==> set_v24_mode ==> set_baud_rate ==> check_comm_link ==> get_ms_id imei: 353081033285050 ==> get_sw_version sw ver: P1.2PU01V01.01 ==> get_sec_version sec ver: 00.31Et(4242) ==> sec_get_security_status result: 00 sw_version_length: 4242 boot_core_state: 4242 system_access_level: 03 key_type: 4242 ==> sec_verify_system_code result: 05 ==> sec_get_security_status result: 00 sw_version_length: 4242 boot_core_state: 4242 system_access_level: 03 key_type: 4242 ==> sec_get_lock_status last error: Timeout while receiving - please check connection and that DUT is ON ==> close_com_port => operation finished Please, send operation.log file to support Include in your mail phone name and full text from phone back label DO NOT run this test many times, it's enough to read information only once ! |
12-06-2009, 14:20 | #10 (permalink) |
Member: 482214 Status: Offline Sonork: 100.1617896 Thanks Meter: 316 | t156 UNLOCK 1000% DONE => module version: 1.72 => operation started: COM6 ==> set_com_port ==> set_baud_rate ==> check_comm_link ==> set_v24_mode ==> set_baud_rate ==> check_comm_link ==> get_ms_id imei: 35308103XXXXXX ==> get_sw_version sw ver: P1.2PU01V01.01 ==> get_sec_version sec ver: 00.31Et(4242) ==> reading... access result: 00 access level: 03 verification result: F0600100561200FF00040105020503050405000000000000 verification result: F0600100561200FF00040105020503050405000000000000 verification result: F0600100561200FF00040105020503050405000000000000 verification result: F0600100561200FF00040105020503050405000000000000 verification result: F0600100561200FF00040105020503050405000000000000 last error: No errors ==> close_com_port => operation finished Finished, time used: 11 sec Power Off/On phone now ! |
The Following 7 Users Say Thank You to m_tahir1 For This Useful Post: |
12-06-2009, 16:09 | #11 (permalink) |
Freak Poster Join Date: Sep 2007 Location: waz pakistan 03436375500
Member: 586872 Status: Offline Thanks Meter: 34 | CAN NOT UNLOCK THIS FONE, => module version: 1.72 => operation started: COM18 ==> set_com_port ==> set_baud_rate ==> check_comm_link ==> set_v24_mode ==> set_baud_rate ==> check_comm_link ==> get_ms_id imei: 353081037212571 ==> get_sw_version sw ver: P1.2PU03V01.01 ==> get_sec_version sec ver: 00.3231Et(4242) ==> reading... access result: 00 access level: 03 verification result: F06001005612010000010105020503050405020000000000 verification result: F0600100561200FF00010105020503050405000000000000 verification result: F0600100561200FF00010105020503050405000000000000 verification result: F0600100561200FF00010105020503050405000000000000 verification result: F0600100561200FF00010105020503050405000000000000 last error: No errors ==> close_com_port => operation finished Finished, time used: 12 sec Power Off/On phone now ! |
The Following 5 Users Say Thank You to meer_fsn2 For This Useful Post: |
12-06-2009, 16:18 | #12 (permalink) |
Member: 586872 Status: Offline Thanks Meter: 34 | CAN NOT UNLOCK THIS FONE, => module version: 1.72 => operation started: COM18 ==> set_com_port ==> set_baud_rate ==> check_comm_link ==> set_v24_mode ==> set_baud_rate ==> check_comm_link ==> get_ms_id imei: 353081037332571 ==> get_sw_version sw ver: P1.2PU03V01.01 ==> get_sec_version sec ver: 00.3231Et(4242) ==> reading... access result: 00 access level: 03 verification result: F06001005612010000010105020503050405020000000000 verification result: F0600100561200FF00010105020503050405000000000000 verification result: F0600100561200FF00010105020503050405000000000000 verification result: F0600100561200FF00010105020503050405000000000000 verification result: F0600100561200FF00010105020503050405000000000000 last error: No errors ==> close_com_port => operation finished Finished, time used: 12 sec Power Off/On phone now ! |
The Following 4 Users Say Thank You to meer_fsn2 For This Useful Post: |
12-06-2009, 16:18 | #13 (permalink) |
Member: 586872 Status: Offline Thanks Meter: 34 | CAN NOT UNLOCK THIS FONE, => module version: 1.72 => operation started: COM18 ==> set_com_port ==> set_baud_rate ==> check_comm_link ==> set_v24_mode ==> set_baud_rate ==> check_comm_link ==> get_ms_id imei: 353081037xxxxxxxxxxxxxxxxxxxx ==> get_sw_version sw ver: P1.2PU03V01.01 ==> get_sec_version sec ver: 00.3231Et(4242) ==> reading... access result: 00 access level: 03 verification result: F06001005612010000010105020503050405020000000000 verification result: F0600100561200FF00010105020503050405000000000000 verification result: F0600100561200FF00010105020503050405000000000000 verification result: F0600100561200FF00010105020503050405000000000000 verification result: F0600100561200FF00010105020503050405000000000000 last error: No errors ==> close_com_port => operation finished Finished, time used: 12 sec Power Off/On phone now ! |
12-06-2009, 18:25 | #15 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, Please, try to use this new software: http://www.infinity-box.com/download...1_v1.72_v2.rar Use "sp-unlock #2" button from software "Service" page. Please, try to make unlock, let's see results. If you will see at end of log text like this: verification result: ... verification result: ... verification result: ... verification result: ... verification result: ... and if phone will be not unlocked after first try, do not try to unlock phone again ! Please, send information about unlock result, operation log and full text from phone back label to [email protected] Thank you ! |
The Following 33 Users Say Thank You to InfinitySupport For This Useful Post: |
Do you try to unlock t156 on pana 1.74 [[post log here]] | /\/\A/\/| | Infinity-Box | 21 | 02-12-2010 21:31 |
New T156 with Infinity not unluck | meer_fsn2 | Infinity-Box | 1 | 12-06-2009 16:38 |
L6:08.DO.when try to unlock it says phone not found | beneto | Smart-Clip | 8 | 02-10-2009 10:05 |
Worning do not try to unlock sagem cid185,186 mobiles with current setool2 version. | Miftahudin | SETool2 | 1 | 12-24-2008 23:10 |
DO NOT TRY TO UNLOCK S OR C 35 -V.20 OR HIGHER WITH ZeeSiemensG3.exe! PHONE WILL BE D | Joseph | x1x to x45/x50 | 2 | 10-23-2001 20:48 |
