Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > MXKEY (by Alim Hape) > MXKEY Nokia Flasher and Unlocker (by Alim Hape)
Old 02-08-2010, 05:02   #1 (permalink)
Member: 497374
Sonork: 1587252:AZAD
Thanks Meter: 93
Thumbs up 5800 successfully sd repair with new update in mxkey
5800 successfully sd repair with new update in mxkey 100% successful thanks for ur hard work mxkey keep it up
Phone Type: RM-356 (Nokia 5800 XpressMusic)
SW Version: V ICPR72_09w06.2 03-03-09 RM-356 (c) Nokia
Imei plain: 357988030******
Product Code: 0591106
ApeCoreSw: V 21.0.025
Language Pack:
- not available.
This phone have PM308 protected, SD security in not restorable.
- Avoid SW Downgrade & manual erase to this phone !
SIMLOCK seems to be valid
SUPERDONGLE_KEY seems to be valid
SIMLOCK_TEST passed
SECURITY_TEST passed
Imei net: 3579880309*****
Version: SIMLOCK SERVER
Provider: Nokia Test, Country: Finland
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
PROFILE_BITS: 0000000000000000
BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
Old 02-08-2010, 05:15   #2 (permalink)
Member: 761225
Sonork: adryfia
Language Pack:
- not available.
SIMLOCK_TEST passed
Counter: 0/3, 0/10
How to repair???, can you tell me the trick step by step please....
Old 02-08-2010, 05:17   #3 (permalink)
Member: 469296
Thanks Meter: 12
teadh will be better if u will be share how to step.....
u can copy log forum no problem phone.... for what....
Old 02-08-2010, 05:18   #4 (permalink)
Member: 835794
Thanks Meter: 11
yes men show some procedure
how did you do that................
Old 02-08-2010, 05:32   #5 (permalink)
Member: 497374
Thanks Meter: 93
steps are
1. repair the simlock tick( mark simlock rpl ) .
2. next click the sd repair button.
3. go to pm tab and sd auth click it.
4. and load from file pm full pm from files and write 1 and 309 only this tick and write pm file that it u will get the phone and enjoy if any problem connect with in yahoo messange.
The Following User Says Thank You to azad4u For This Useful Post:
Old 02-08-2010, 06:05   #6 (permalink)
.::Indian::.'s Avatar
Member: 37015
Thanks Meter: 67
ple upload good pm for 5800 ver 31
Old 02-08-2010, 06:32   #7 (permalink)
naheed_gsm's Avatar
Member: 1025487
Thanks Meter: 64
steps are
yse sir u stap is good way i know that but i will try 5130 is sd problem use this option & this phone is made is contact service. what i do it.........plz help
Old 02-08-2010, 11:24   #8 (permalink)
Andra's Avatar
Member: 976728
Sonork: 1589709
Thanks Meter: 4,775
better open new thread.
SD repair in SL3 is supported
but not in SIMLOCK repair
br,
The Following User Says Thank You to Andra For This Useful Post:
7210c successfully sd repair with new update in mxkey azad4u MXKEY Nokia Flasher and Unlocker (by Alim Hape) 0 02-12-2010 10:41
100% ok SD Repair with Mxkey ashik123 MXKEY Nokia Flasher and Unlocker (by Alim Hape) 1 02-06-2010 10:20
n96 successfully sd repair by mxkey azad4u MXKEY Nokia Flasher and Unlocker (by Alim Hape) 1 02-03-2010 15:24
E1120 Successfully Direct Unlock with New Update Ver 11.00 kashi4gul UST Pro II 3 12-19-2009 12:41
N95 (8-gb) Successfully Unlocked with new Update in few seconds Ja\/\/aD Universalbox 4 04-06-2009 16:06
Page generated in 0.20789 seconds with 9 queries
