02-13-2010, 14:13 | #1 (permalink) |
No Life Poster Join Date: Apr 2006 Location: Pakistan
Member: 265626 Status: Offline Sonork: 100.1591486 Thanks Meter: 2,982 | Info regarding superdongle + security test failed 1. SuperDongle Repair 2. Security Test Failed 1. SUPERDONGLE REPAIR SIMLOCK invalid! SUPERDONGLE_KEY invalid! - WD timer enabled, phone will reboot itself after 3 min. SIMLOCK_TEST failed! SECURITY_TEST passed in this case a.press repair Super Dongle b.than SD Auth PM c.than good pm including fields pm1 and pm309 2. SuperDongle repair (case2) SIMLOCK passed! SUPERDONGLE_KEY passed! - WD timer enabled, phone will reboot itself after 3 min. SIMLOCK_TEST passed SECURITY_TEST passed a.press repair Super Dongle b.than SD Auth PM c.than good pm including fields pm1 and pm309 3. Security test Failed SIMLOCK passed! SUPERDONGLE_KEY passed! SIMLOCK_TEST passed SECURITY_TEST failed in this case no need to full erase than flash just in few steps u can do this a. first of all Do SX4 than PM1 and PM309 if no success than b. replace CCC and HWC cert of RPL from same model and write it back to ur phone than repeat the SX4 + pm process hope this will help u to sort out such errors |
The Following 35 Users Say Thank You to hasnain For This Useful Post: |
02-13-2010, 18:10 | #3 (permalink) | |
Freak Poster Join Date: Nov 2008
Member: 893550 Status: Offline Thanks Meter: 139 | Quote:
many many thanks | |
02-14-2010, 10:10 | #5 (permalink) | |
Freak Poster Join Date: Mar 2008 Location: Nepal
Member: 718059 Status: Offline Sonork: 100.1587605 Thanks Meter: 36 | Quote:
02-14-2010, 14:37 | #7 (permalink) |
Junior Member Join Date: Nov 2009 Location: Pakistan
Member: 1156668 Status: Offline Thanks Meter: 13 | HERE THE SOLUTION FOR NOKIA 7210C CONTACT SERVICE If after repair SD and/or Simlock (Super Dongle RPL and Simlock RPL upload) you get "SECURITY_TEST failed!" and/or "warning: SD authorized but verify failed!". This is comming usually because some PM fields and/or RPL sections are missing from your phone (e.g. DRM keys, CCC, ...). Solution 1 (easy way, maybe not work all time, depends how phone was damaged): - write full PM from SAME phone model (product number) WITHOUT fields 1, 308, 309 (and WITHOUT field 120 for SL20 based phones) - unplug/replug phone from JAF/UFS box - make Simlock RPL repair - make SD RPL repair - unplug/replug phone from JAF/UFS box - make SUPER SX4 Auth then write PM1 and PM309 if still have problems, use Solution 2: - backup RPL (NPC, CCC, HWC, ...), will call this ORIGINAL RPL - backup RPL from another working phone (same model) with SAME product code - edit this good RPL from another phone and remove NPC section (all lines who start with NPC_DATA_1 ... NPC_DATA_xx), will call this edited file CLONE RPL - backup full PM from another working phone (same model) with SAME product code, will call this file CLONE PM - full erase flash chip (use erase file regarding flash chip size) - flash phone (CMT, APE, ...) - upload CLONE RPL - upload ORIGINAL RPL - write full CLONE PM without fields 1,120,308,309 - unplug/replug phone from JAF/UFS box - make Simlock RPL repair - make SD RPL repair - unplug/replug phone from JAF/UFS box - make SUPER SX4 Auth then write PM1 and PM309 TRY AND POST RESULTS |
The Following 5 Users Say Thank You to 0C00L For This Useful Post: |
02-14-2010, 15:37 | #8 (permalink) | |
No Life Poster Join Date: May 2007 Location: Badui My home
Member: 508048 Status: Offline Thanks Meter: 123 | Quote:
this result.. SIMLOCK_DATA corrupted! Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.7687(12-02-2010), 1.0.0.12095(13-02-2010) Product: V 06.65 01-04-09 RM-495 (c) Nokia SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x] ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 ROM ID: 273F6D55DFAAF68F Calculating SIMLOCK using security server ... Connecting to server[main.mxkey.biz] ...OK, secure login ... Completed in 10.172 s RPL saved to "C:\mobileEx\3.3\data\backup\BB5_RM-495_355246030058044_SIM.RPL" Updating SIMLOCK...error 0x1 Reading Simlock info ... SIMLOCK_DATA corrupted! what else to do .. if the box was waiting for suport any idea... | |
02-14-2010, 16:40 | #9 (permalink) | |
Member: 265626 Status: Offline Sonork: 100.1591486 Thanks Meter: 2,982 | Quote:
Updating SIMLOCK...error 0x1 write now use other tool and press SL repair | |
The Following User Says Thank You to hasnain For This Useful Post: |
02-14-2010, 16:44 | #10 (permalink) |
No Life Poster Join Date: Jul 2007 Location: USA
Member: 540254 Status: Offline Thanks Meter: 30 | PLZ tell me how to backup rpl file for only ccc,hwc cuz there is tow CCC and HWC one under APE, and one under RAP..which one should I backed up to write it to another phone..? the one under RAP OR APE!!! |
02-14-2010, 16:48 | #11 (permalink) | |
in short read full RPL and the value under NPC is required NPC CCC HWC | |
02-14-2010, 17:04 | #12 (permalink) |
Member: 540254 Status: Offline Thanks Meter: 30 | SORRY mate..but u said only CCC&HWC only..For example I have now working phone..what I have to do is to backed up CCC&HWC under RAP..r8..???and then write those 2 files CCC&HWC to the broken phone..plz correct me.. |
02-14-2010, 17:16 | #13 (permalink) | |
open it in note pad remove all other fields than CCC and HWC thats all | |
02-14-2010, 17:25 | #14 (permalink) |
No Life Poster Join Date: May 2006 Location: lucknow
Member: 275643 Status: Offline Thanks Meter: 360 | dear plz guide me that how i get knowledge about pm file is there any data or website from where i get study material about pm files since u quote above that remove all other fields other than ccc and hwc what is ccc and hwc area i dont know plz clear more ? |
02-14-2010, 18:04 | #15 (permalink) | |
add me on msn messenger | |
N73 security test fail start up fail | mobile_mania | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 31 | 03-14-2013 19:33 |
succes full repair phone startup failed and security test failed | jagdish puri | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 0 | 03-12-2010 14:17 |
5800d rm-356 superdongle key invalid and security test failed ok.... | mesut07 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 1 | 02-13-2010 19:40 |
Success two security TEST failed but faile in one 5220 FAILE | khokonhajigonj | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 5 | 02-09-2010 15:38 |
3110C security test fail after sd repair now tested ok | GSMaxx | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 3 | 02-06-2010 11:19 |
