Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > MXKEY (by Alim Hape) > MXKEY Nokia Flasher and Unlocker (by Alim Hape)
Old 03-03-2010, 12:18   #1 (permalink)
hasnain's Avatar
Member: 265626
Sonork: 100.1591486
Thanks Meter: 2,982
BB5 Contact retailer After doing all process ( POST HERE )
Only Mxkey users
For those who tried all the steps posted in different threads and still facing same problem
1. Post here the logs
2. upload here the RPL
3. upload here the PM
will try to solve ur problem here
posted this because can't open too many thread
can't read and solve the problems there
really a headache
thanx
(*) Hasnain Mahmood Malik (*)
The Following 23 Users Say Thank You to hasnain For This Useful Post:
Old 03-03-2010, 13:15   #2 (permalink)
Member: 83984
Thanks Meter: 25
scan
Phone Type: RM-437 (Nokia E63)
SW Version: V ICPR71_09w22.9 16-10-09 RM-437 (c) Nokia
Imei plain: 35150204085065-3
Product Code: 0568890
ApeCoreSw: 400.21.013
ApeVariant: 400.21.013, ApeTest: RM437ENO874571920.a01
Language Pack:
- not available.
SIMLOCK seems to be valid
SUPERDONGLE_KEY seems to be valid
WMDRM_PD seems to be valid
SIMLOCK_TEST passed
SECURITY_TEST failed!
Imei net: 351502040850653
Version: SIMLOCK SERVER
Provider: Hutchinson 3G (3), Country: United Kingdom
Counter: 0/3, 0/10
CONFIG_DATA: 2342000000000000
PROFILE_BITS: 0000000000000000
BLOCK 1: 1=OPEN, DATA=23420F
BLOCK 2: 1=OPEN, DATA=23594F
BLOCK 3: 1=OPEN, DATA=23420F
BLOCK 4: 1=OPEN, DATA=23594F
The Following 2 Users Say Thank You to BATTAL For This Useful Post:
Old 03-03-2010, 13:31   #3 (permalink)
hasnain's Avatar
Member: 265626
Sonork: 100.1591486
Thanks Meter: 2,982
1. Post here the logs u only done this step
The Following User Says Thank You to hasnain For This Useful Post:
Old 03-03-2010, 13:32   #4 (permalink)
Member: 83984
Thanks Meter: 25
Language Pack:
- not available.
SIMLOCK_TEST passed
Counter: 0/3, 0/10
back up rpl
RAP Data :
SYSTEM ASIC ID: 000000010000022600010006400C192101031103 [RAPIDO3G ver: 1.13]
EM0 ID: 00000296
EM1 ID: 00000B22
PUBLIC ID: 1CD0010AC6918D52D88BA13B88AE27FF3EB5CED3
ASIC MODE ID: 00
ROOT KEY HASH: 9A28E119033B91D14D22838C86D0D53C
ROM ID: 4B9B75103E691FF8
SecondaryBoot: RAPIDOv11_2nd.fg [BB5] version: 1.37.1 revision: 0.0 size: 0x3B80
Supported RAP Ids: 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105
FlashID0: 00EC 0040 - 0080 0121 [Samsung 2Gb DDP OneNAND,2 Gbits] type: ONENAND,RAP
ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000
ExtDEVC: FFFF 0000 - 0000 0000
Algorithm: RAPIDOv11_algo.fg [XSR 1.5] version: 1.40.0 revision: 0.0 size: 0x27520
RAP PAPUBKEYS HASH: D9C25399C696B8549EDCDB1497A950B3A20DDFB6
Reading RAP NPC (0x190 bytes).
Reading RAP VARIANT (0x0 bytes).
Reading RAP CCC (0x160 bytes).
Reading RAP HWC (0xD4 bytes).
Flash Imei: 35150204085065
NPC_DATA saved OK
CCC_DATA saved OK
HWC_DATA saved OK
SIMLOCK_DATA saved OK
SIMLOCK_KEY_DATA saved OK
WMDRM_PD_DATA saved OK
RF_DATA saved OK
WARRANTY_DATA saved OK
PROD_DATA saved OK
BT_DATA saved OK
LOCK_DATA saved OK
LOCK120_DATA saved OK
BB_DATA saved OK
WLAN_DATA saved OK
RPL saved to "C:\mobileEx\3.3\data\backup\BB5_35150204085065_BA CK.rpl"
The Following User Says Thank You to BATTAL For This Useful Post:
Old 03-03-2010, 13:35   #5 (permalink)
hasnain's Avatar
Member: 265626
Sonork: 100.1591486
Thanks Meter: 2,982
can u upload that RPL here
thanx
The Following 2 Users Say Thank You to hasnain For This Useful Post:
Old 03-03-2010, 13:39   #6 (permalink)
Member: 83984
Thanks Meter: 25
back up rpl
RAP Data :
EM0 ID: 00000296
EM1 ID: 00000B22
ASIC MODE ID: 00
NPC_DATA saved OK
CCC_DATA saved OK
HWC_DATA saved OK
RF_DATA saved OK
PROD_DATA saved OK
BT_DATA saved OK
LOCK_DATA saved OK
BB_DATA saved OK
WLAN_DATA saved OK
pm
Writing PM from Node ...
Section: 1
Warning: failed to write 1 - 0 (114 bytes)
Warning: failed to write 1 - 2 (98 bytes)
Warning: failed to write 1 - 4 (110 bytes)
Warning: failed to write 1 - 6 (98 bytes)
Warning: failed to write 1 - 8 (110 bytes)
Warning: failed to write 1 - 13 (98 bytes)
Warning: failed to write 1 - 16 (98 bytes)
Warning: failed to write 1 - 18 (98 bytes)
Warning: failed to write 1 - 20 (98 bytes)
Warning: failed to write 1 - 22 (16 bytes)
Warning: failed to write 1 - 23 (4 bytes)
Warning: failed to write 1 - 24 (84 bytes)
Warning: failed to write 1 - 25 (4 bytes)
Warning: failed to write 1 - 26 (110 bytes)
Warning: failed to write 1 - 28 (98 bytes)
Warning: failed to write 1 - 29 (10 bytes)
Warning: failed to write 1 - 31 (98 bytes)
Warning: failed to write 1 - 33 (36 bytes)
Warning: failed to write 1 - 34 (80 bytes)
Warning: failed to write 1 - 35 (16 bytes)
Warning: failed to write 1 - 37 (4 bytes)
Warning: failed to write 1 - 39 (36 bytes)
Warning: failed to write 1 - 44 (182 bytes)
Warning: failed to write 1 - 45 (182 bytes)
Section: 2
- Key: 0, size 448 bytes written.
Section: 4
- Key: 3, size 10 bytes written.
- Key: 4, size 8 bytes written.
- Key: 5, size 8 bytes written.
- Key: 9, size 5 bytes written.
- Key: 26, size 132 bytes written.
Section: 8
- Key: 0, size 12 bytes written.
- Key: 1, size 12 bytes written.
- Key: 2, size 128 bytes written.
- Key: 3, size 128 bytes written.
- Key: 6, size 4 bytes written.
- Key: 7, size 8 bytes written.
- Key: 8, size 8 bytes written.
- Key: 9, size 16 bytes written.
Section: 11
- Key: 0, size 4 bytes written.
- Key: 1, size 4 bytes written.
- Key: 2, size 4 bytes written.
- Key: 3, size 4 bytes written.
- Key: 4, size 1 bytes written.
- Key: 5, size 6 bytes written.
- Key: 6, size 1 bytes written.
- Key: 7, size 2 bytes written.
- Key: 8, size 2 bytes written.
- Key: 9, size 2 bytes written.
- Key: 10, size 2 bytes written.
- Key: 11, size 2 bytes written.
- Key: 12, size 1 bytes written.
- Key: 13, size 1 bytes written.
- Key: 14, size 1 bytes written.
- Key: 15, size 1 bytes written.
- Key: 16, size 1 bytes written.
- Key: 17, size 1 bytes written.
- Key: 18, size 1 bytes written.
- Key: 19, size 2 bytes written.
- Key: 20, size 2 bytes written.
- Key: 21, size 1 bytes written.
- Key: 22, size 1 bytes written.
- Key: 23, size 4 bytes written.
- Key: 24, size 4 bytes written.
- Key: 25, size 2 bytes written.
- Key: 26, size 2 bytes written.
- Key: 27, size 2 bytes written.
- Key: 28, size 2 bytes written.
- Key: 29, size 1 bytes written.
- Key: 30, size 1 bytes written.
- Key: 31, size 1 bytes written.
- Key: 32, size 1 bytes written.
- Key: 33, size 1 bytes written.
- Key: 34, size 1 bytes written.
- Key: 35, size 1 bytes written.
- Key: 36, size 1 bytes written.
- Key: 37, size 1 bytes written.
- Key: 38, size 2 bytes written.
- Key: 39, size 2 bytes written.
- Key: 40, size 2 bytes written.
- Key: 41, size 2 bytes written.
- Key: 42, size 2 bytes written.
- Key: 43, size 4 bytes written.
- Key: 44, size 4 bytes written.
- Key: 45, size 4 bytes written.
- Key: 46, size 1 bytes written.
- Key: 47, size 16 bytes written.
- Key: 48, size 2 bytes written.
- Key: 49, size 2 bytes written.
- Key: 50, size 20 bytes written.
- Key: 51, size 10 bytes written.
- Key: 52, size 2 bytes written.
- Key: 53, size 20 bytes written.
- Key: 54, size 10 bytes written.
- Key: 55, size 1 bytes written.
- Key: 56, size 1 bytes written.
- Key: 57, size 1 bytes written.
- Key: 58, size 1 bytes written.
- Key: 59, size 1 bytes written.
- Key: 60, size 1 bytes written.
- Key: 61, size 1 bytes written.
- Key: 62, size 1 bytes written.
- Key: 63, size 1 bytes written.
- Key: 64, size 1 bytes written.
- Key: 65, size 1 bytes written.
- Key: 66, size 32 bytes written.
- Key: 67, size 32 bytes written.
- Key: 68, size 2 bytes written.
- Key: 69, size 2 bytes written.
- Key: 70, size 2 bytes written.
- Key: 71, size 2 bytes written.
- Key: 72, size 2 bytes written.
- Key: 73, size 2 bytes written.
- Key: 74, size 2 bytes written.
- Key: 75, size 2 bytes written.
- Key: 76, size 2 bytes written.
- Key: 77, size 2 bytes written.
- Key: 78, size 2 bytes written.
- Key: 79, size 2 bytes written.
- Key: 80, size 2 bytes written.
- Key: 81, size 2 bytes written.
- Key: 82, size 2 bytes written.
- Key: 83, size 2 bytes written.
- Key: 84, size 2 bytes written.
- Key: 85, size 2 bytes written.
- Key: 86, size 2 bytes written.
- Key: 87, size 2 bytes written.
- Key: 88, size 2 bytes written.
- Key: 89, size 2 bytes written.
- Key: 90, size 2 bytes written.
- Key: 91, size 2 bytes written.
- Key: 92, size 2 bytes written.
- Key: 93, size 2 bytes written.
- Key: 94, size 2 bytes written.
- Key: 95, size 2 bytes written.
- Key: 96, size 2 bytes written.
- Key: 97, size 2 bytes written.
- Key: 98, size 2 bytes written.
- Key: 99, size 2 bytes written.
- Key: 100, size 2 bytes written.
- Key: 101, size 2 bytes written.
- Key: 102, size 2 bytes written.
- Key: 103, size 2 bytes written.
- Key: 104, size 2 bytes written.
- Key: 105, size 2 bytes written.
- Key: 106, size 2 bytes written.
- Key: 107, size 2 bytes written.
- Key: 108, size 2 bytes written.
- Key: 109, size 2 bytes written.
- Key: 110, size 2 bytes written.
- Key: 111, size 2 bytes written.
- Key: 112, size 2 bytes written.
- Key: 113, size 2 bytes written.
- Key: 114, size 2 bytes written.
- Key: 115, size 2 bytes written.
- Key: 116, size 4 bytes written.
- Key: 117, size 4 bytes written.
- Key: 118, size 1 bytes written.
- Key: 119, size 4 bytes written.
- Key: 120, size 4 bytes written.
- Key: 121, size 4 bytes written.
- Key: 122, size 4 bytes written.
- Key: 123, size 16 bytes written.
- Key: 124, size 4 bytes written.
- Key: 125, size 2 bytes written.
- Key: 126, size 2 bytes written.
- Key: 127, size 1436 bytes written.
Section: 12
- Key: 0, size 102 bytes written.
Section: 31
- Key: 4, size 20 bytes written.
Section: 44
- Key: 0, size 1 bytes written.
Section: 50
- Key: 0, size 2 bytes written.
Section: 54
Section: 88
- Key: 0, size 36 bytes written.
Section: 96
- Key: 0, size 24 bytes written.
Section: 107
- Key: 0, size 21 bytes written.
- Key: 1, size 79 bytes written.
- Key: 2, size 79 bytes written.
- Key: 3, size 70 bytes written.
- Key: 25, size 132 bytes written.
- Key: 26, size 12 bytes written.
Section: 117
- Key: 1, size 3 bytes written.
- Key: 2, size 6 bytes written.
- Key: 3, size 1 bytes written.
- Key: 4, size 9 bytes written.
- Key: 5, size 10 bytes written.
- Key: 6, size 8 bytes written.
- Key: 8, size 42 bytes written.
- Key: 13, size 3 bytes written.
- Key: 14, size 3 bytes written.
- Key: 16, size 40 bytes written.
Section: 120
- Key: 0, size 944 bytes written.
- Key: 1, size 80 bytes written.
- Key: 2, size 20 bytes written.
- Key: 3, size 112 bytes written.
Section: 193
- Key: 2, size 8 bytes written.
- Key: 3, size 32 bytes written.
- Key: 4, size 32 bytes written.
- Key: 9, size 64 bytes written.
Section: 208
Section: 217
- Key: 0, size 32 bytes written.
Section: 308
- Key: 1, size 8192 bytes written.
- Key: 7, size 1 bytes written.
- Key: 9, size 40 bytes written.
Section: 309
Warning: failed to write 309 - 0 (4 bytes)
Warning: failed to write 309 - 1 (2 bytes)
Warning: failed to write 309 - 2 (12 bytes)
Warning: failed to write 309 - 4 (12 bytes)
Warning: failed to write 309 - 5 (12 bytes)
Warning: failed to write 309 - 7 (12 bytes)
Warning: failed to write 309 - 8 (12 bytes)
Warning: failed to write 309 - 17 (12 bytes)
Warning: failed to write 309 - 22 (12 bytes)
Section: 313
- Key: 0, size 615 bytes written.
Section: 322
Section: 334
Section: 341
- Key: 4, size 4514 bytes written.
Section: 354
- Key: 0, size 18 bytes written.
Section: 356
- Key: 1, size 8 bytes written.
Completed in 52.469 s
Old 03-03-2010, 13:45   #7 (permalink)
hasnain's Avatar
Member: 265626
Sonork: 100.1591486
Thanks Meter: 2,982
i need this file
can u upload it here
thanx
Old 03-03-2010, 13:55   #8 (permalink)
Member: 258623
Thanks Meter: 12
i have 5130 c
NPC verified Ok.
Updating CMT NPC ...OK
Updating CMT CCC ...OK
Updating CMT HWC ...OK
Updating PRODUCTCODE (0571584)... OK
Updating PSN (HEC345703)... OK
Updating HWID (1000)... OK
Updating LOCK ...
error 0x0
Updating SIMLOCK...error 0x17
Trying to update SUPERDONGLE_KEY ...error 0x0
Updating WMDRM_PD...OK
Certificate programmed successfully !
Phone Type: RM-495 (Nokia 5130c-2)
SW Version: V 07.91 29-10-09 RM-495 (c) Nokia
Imei plain: 35322303068974-0
Product Code: 0571584
Language Pack:
- not available.
This phone have PM308 protected, SD security in not restorable.
This is SL3 phone(Simlock2 format).
- Avoid SW Downgrade
& manual erase to this phone !
SIMLOCK invalid!
SIMLOCK_TEST failed!
SECURITY_TEST passed
TimeStamp: 2009-11-02T09:55:37Z
SW Version: 07.91
Variant Version: 021
ProductProfile: RM495_0571584_07.91_021.spr
Simlock: 0571584_simlock.bin
SIMLOCK_DATA corrupted!
The Following 2 Users Say Thank You to ankur_rani143 For This Useful Post:
Old 03-03-2010, 13:57   #9 (permalink)
Member: 83984
Thanks Meter: 25
thanx
ı posted rpl back up
Old 03-03-2010, 14:01   #10 (permalink)
Member: 258623
Thanks Meter: 12
not uplod rr failThis is SL3 phone(Simlock2 format).
- Avoid SW Downgrade & manual erase to this phone !
SIMLOCK invalid!
SW Version: 07.91
Old 03-03-2010, 14:02   #11 (permalink)
hasnain's Avatar
Member: 265626
Sonork: 100.1591486
Thanks Meter: 2,982
u posted logs
not uploaded RPL
Old 03-03-2010, 14:05   #12 (permalink)
Misbahullah's Avatar
Member: 938983
Sonork: 100.1585802
Thanks Meter: 102
hey man what do u do MR Hasnain wants your backup rpl it is located in
go to the above address and copy BB5_35150204085065_BA CK.rpl and upload it in this forum thanks
Old 03-03-2010, 14:05   #13 (permalink)
hasnain's Avatar
Member: 265626
Sonork: 100.1591486
Thanks Meter: 2,982
SIMLOCK invalid!
SW Version: 07.91
have u full RPL backup ??
if not than only RPL from nokia server will sovle ur problem
because its SL3 and no tool can repair the simlocks of SL3
thanx
Old 03-03-2010, 14:06   #14 (permalink)
Member: 938983
Sonork: 100.1585802
Thanks Meter: 102
NPC verified Ok.
Updating LOCK ...error 0x0
Language Pack:
- not available.
SIMLOCK invalid!
SW Version: 07.91
it is sl3 model and not supported at the moment you just wait for next update
The Following 2 Users Say Thank You to Misbahullah For This Useful Post:
Old 03-03-2010, 14:08   #15 (permalink)
Member: 258623
Thanks Meter: 12
my fail uplod isNPC verified Ok.
Updating LOCK ...
error 0x0
Language Pack:
- not available.
SIMLOCK invalid!
SW Version: 07.91
The Following User Says Thank You to ankur_rani143 For This Useful Post:
Post Here all BB5 contact Service repaired sucessfully by MT V2.02...... nofear99 Nokia Base Band 5 ( BB-5 ) 0 01-21-2010 20:38
post here all bb5 contact service CONTACT_SERVICE Nokia Base Band 5 ( BB-5 ) 6 10-05-2009 13:25
BB5 contact service after RPL & SX4 kabirhossain Nokia Hardware & Hardware Repair 3 02-14-2009 15:24
Page generated in 0.43350 seconds with 10 queries
