11-11-2003, 18:32 | #1 (permalink) |
Member deceased !! Join Date: Mar 2002 Location: www.griffinteam.net Age: 54
Member: 10248 Status: Offline Thanks Meter: 25 | Griffin version 2.06 release This version enables Griffin owners to repair phones with damaged IMEI. Case 1: UEM chip is ok and contains valid IMEI, then it is needed to compute the IMEI data for flash – Click read data, send the file to GriffinTeam and GriffinTeam will send you RPL file for IMEI data in flash, send the received RPL file to phone using WriteData. After that you phone should be working again. And the good news is that you have repaired the phone without changing the IMEI ( which is illegal in many countries). (when griffin reads ASK file it will show the IMEI that it read from UEM, before you send the file for computation check if the shown imei is 14 digits. Only in this case we will be able to compute correct RPL) Case 2: UEM chip is damaged so you need to replace it. In this case the phone will have ?????????????? for IMEI because UEM is not initialized and contains 000000000000000 for IMEI. You have two possibilities in this case. Write any RPL to phone and the phone will contain the IMEI that was in RPL file. But this will cause the phone to have different IMEI then the one that it originally had. As mentioned above this is illegal in many countries and it is risky to repair the phone in this way because you can end up in jail. If you wish to initialize the UEM with the specific IMEI, enter the IMEI you wish us to compute in the IMEI/ESN field and read log from the phone ( note: if you correctly replaced the UEM with new empty one, the IMEI read from UEM will be 000000000000000, only in this case the IMEI we compute will be correctly stored in UEM when you send the RPL file to phone). NOTE 1: The computation of RPL file will not be FREE. You will need to pay for the computation, but this is only because nice things cost money. Since griffin clients are too much we will not be able to process directly the ASK files from clients. Tomorrow we will publish list of resellers that will handle the processing for different countries. If you are interested in this service please refer to them for price inquiries and where to send the files. The price for computing RPL for Flash only(case 1) and for Flash+UEM(case 2) will be different. Note 2: Reading the IMEI from UEM is currently supported for DCT4 ( asic 2) phones. Support for asic5 and asci7 is to be released later. Another change to version 2.06 is that when sending the RPL file to phone Griffin also updates OriginalIMEI to contain the same value as the IMEI in RPL file. Please download version 2.06 from www.griffinteam.net . Best Regards, GriffinTeam |
11-11-2003, 22:05 | #5 (permalink) |
No Life Poster Join Date: Jun 2001 Location: Philippines Age: 47
Member: 4873 Status: Offline Thanks Meter: 5 | where will we send the RPL files to be computed? to Griffin or local Reseller? it would be nice if we could avail it from local resellers cause western union costs so much... and of course how much is the fee for RPL computation? BR |
11-12-2003, 05:14 | #6 (permalink) |
Freak Poster Join Date: Feb 2002 Location: china
Member: 9315 Status: Offline Thanks Meter: 0 | Hi, But I think You can't change IMEI that any digit, even the eeprom have been wrote once. May be only write the unprogramed bit in eeprom. Fro example: If the eeprom is 00000000000000, you can write any digit, but the eeprom has be 10011101000010, you only can change 0 to 1, but can't write 1 to 0 again. So if you want to change imei as you like, you have to change imei also. NO any other method! or you can make UEM with programmable device yourself. Is it right? Last edited by raino; 11-12-2003 at 05:19. |
11-12-2003, 10:22 | #8 (permalink) |
No Life Poster Join Date: Aug 2001 Location: P A K I S T A N _____________ Age: 40
Member: 5932 Status: Offline Thanks Meter: 1,694 | THIS FEATURE IS FOR THE PEOPLE THOSE UEM CHIP IS OK.. but thay changed FLASH IC or FLASH DATA IS EMPTY and want to rebuild UEM IMEI in flash chip. Best Regards, Wahab one more think... NOW ppl can use used UEM chips which are allready written.. but OK.. get working UEM chips from DEAD phones and write rpl. Last edited by DrMobile; 11-12-2003 at 10:27. |
11-12-2003, 10:58 | #9 (permalink) | |
Freak Poster Join Date: Apr 2002 Location: Romania Age: 56
Member: 11347 Status: Offline Thanks Meter: 6 | Quote:
Pozdrav Dejana Reg..... | |
11-13-2003, 10:26 | #12 (permalink) |
No Life Poster Join Date: Sep 2001 Location: United Kingdom Age: 48
Member: 6524 Status: Offline Thanks Meter: 246 | @ GRIFFINTEAM PLS CHEK YOUR NEW VER PICTHURE...I ATTACHED.. WHY U DONT ERASE SN: NO ???THIS SN: WORKING TO ACCESS WITH DOWNLOAD...PLS ERASE SN: NO IF POSSIBLE.. |
post sucessful flashing logs for bb5 phone with 2.06 release | chinchik | HWK | 0 | 10-29-2007 18:27 |
Griffin 2.06 Released | ahmedksal | Griffin | 1 | 09-13-2004 12:14 |
