ARM9 BASED M62 / M62+ All MYxxx Like: MY C3-2, MY X1-2, MY Z-55, MY X2-2, MY C-4, MY Z-3, MY C2-2,
MY V-75, MY X3-2, MY X-7, MY V-65, MY C-1, MY X-1w, MY C-6, MY C-5w, MY C-2, MY
X-2, MY X-6, MY G5, MY X-3, MY X-5, MW X1, MY V-56, VS2, VS1, MY C5-2, MY X-8,
MY X-4, MY C4-2, MY V-55, MY X5-2, MY C-3b, MY C-3s,MY100, MY200, MY300X, MY400, MY V-85, MY V-76,
MY X6-2 etc Also SG321i, VS3 & MY-S7 (Smart Phone) |
02-13-2003, 15:12 | #1 (permalink) |
No Life Poster Join Date: Nov 2001 Location: tunisia medenine Age: 56
Member: 7599 Status: Offline Thanks Meter: 14 | pb with read fields Myx5 but service mode not posible too{*2266326....} phone connected to pc data speed=4800 how to read fields with cable any sol? thanks in advance |
02-14-2003, 10:43 | #2 (permalink) |
Junior Member Join Date: Feb 2003 Location: Burton On Trent Age: 44
Member: 21230 Status: Offline Thanks Meter: 0 | There is no way to read those fields via the data cable as they are protected. The only way to find them out is to access them via the hotline menu. You "should" be able to access it by entering the code *2266326232X where X is any number from 0 to 9. Just try each one. Remember to press the OK button at the top after typing in the code (the one above the green), as it does not show the OK sometimes on the screen. You should now have a small square in the bottom right of your screen. Access the hotline menu by pressing down and then * key. You can then go to PROM and then to READING/WRITING. Enter the field you require (i.g 191,252,etc..) and jot it down. BE VERY CAREFUL WHAT YOU DO IN THIS, IF YOU ALTER ANY FIELDS YOU MAY CURRUPT YOUR PHONE, MAKING IT USELESS! NOTE: INSTRUCTIONS BELOW ARE ONLY FOR A CURRUPT PHONE ONLY!! If you cant enter the code because it says SIMLOCKED due to messing up your phone and is now unusable, just use SagemDr Program, edit field 0, then minus the last two digits of that code by minus 1. (e.g. ?? ?? ?? ?? ?? ?? 45 change it to 44). Turn off phone then back on. It will now say SIM NOT READY. You will be able to type in the MM code now and enter the hotline menu following instructions above. Remember to change field 0 back after you have read the fields you require and/or repaired the fields you have currupted NOTE: DO NOT EDIT FIELD 0 IF YOUR PHONE IS WORKING OK!! OR YOU COULD END UP WITH AN UNUSABLE PHONE! |
21 July 2008, Support added for Read ASK, Read field 308, Reset Counter blocked BB5 | NFF Box Team | Nokia Fault Finder Box | 24 | 11-24-2008 11:21 |
Myc2-3 can't read Field 5709 with ASTU | supergut68 | ARM9 BASED M62 / M62+ | 6 | 11-22-2007 21:23 |
problem with read field 5709 | Mounir | ARM9 BASED M62 / M62+ | 1 | 10-25-2004 12:57 |
can't read field 537 in mc922 | ask.m | Infineon C16X M51 & ARM7 M52 BASED | 2 | 04-17-2003 19:37 |
sagem mw 936 saying error reading field 5374 | douda | Infineon C16X M51 & ARM7 M52 BASED | 0 | 09-15-2002 15:16 |
