Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > DC Unlocker
Old 12-04-2017, 20:58   #1 (permalink)
Member: 2785673
fastboot: FAILED (remote: image verification error) after DC Phoenix unbrick
Hello
after i succesfully used DC Phoenix to recover Huawei Mate 8 (NXT-L29C432) i cannot flash TWRP or anything on my phone , as im still getting the "FAILED (remote: image verification error)" from fastboot. So i also cannot root and use the device as before
Im sure im not alone with this issue, but i cannot find any clear solution for this. Can you please help or advice me further??
I spent 15€, recovered the phone, but with this, its still partial success. Here some outputs:
fastboot flash recovery twrp-3.2.0-0-next . img
target reported max download size of 471859200 bytes
sending 'recovery' (22140 KB)...
OKAY [ 0.530s]
writing 'recovery'...
finished. total time: 0.562s
Before the use of DC Phoenix, i always get this number.
fastboot devices
QHC0216327001941 fastboot
Now:
fastboot devices
0123456789ABCDEF fastboot
In Fastboot mode, on phone screen i see:
PHONE Unlocked
FRP Lock
DC - Unlocker 2 Client 1.00.1308 reports:
FB LockState: UNLOCKED
USER LockState: LOCKED
unlocked
fastboot oem get-lockstate
(bootloader) locked
OKAY [ -0.000s]
finished. total time: -0.000s
fastboot oem get-bootinfo
(bootloader) unlocked
OKAY [ -0.000s]
In Developer menu i have the
"Allow OEM unlock" grayed & disabled, im unable to swich it on..
Can you please explain what happend and how to fix this?
Thank you for further help.
Old 12-04-2017, 23:07   #2 (permalink)
Member: 971926
Thanks Meter: 13
I'm having the same problem, have you found a solution?
Old 12-05-2017, 01:05   #3 (permalink)
Member: 971926
Thanks Meter: 13
I solved with the help of the firmware that recognized, but it did a good job to find out that even though it was OK when writing the firmware, it actually meant error because frp is active and can not disable it.
but as she showed me her original version with a great help from google and xda I managed to recover and yes
The Following User Says Thank You to fehveiga For This Useful Post:
Old 12-05-2017, 09:40   #4 (permalink)
Member: 2785673
Can you please write some good overview, which software/method did you usedto solve it? Can you be more specific? Cause .. i have no idea which direction should i go now. Can the HCU help?
Old 12-06-2017, 18:32   #5 (permalink)
Member: 2785673
Solved with mighty HCU client, i was able to import the just the SN back without problems. Then as usual.. unlock the bootloader, TWRP, SU... and now the phone is back in shape )
Page generated in 0.14460 seconds with 8 queries
