DUB-LX1 8.2.0.142(C185) USB Device REMOVAL / Cannot Flash Looking for a device in upgrade mode No devices detected in upgrade mode Device found: DYN6R19827000640 Detecting recovery partition File size: 3,854,012,100 bytes AMSS version: DUB-L22 8.2.0.173(C900) ERECOVERY_KERNEL partition found ERECOVERY_RAMDISK partition found ERECOVERY_VENDOR partition found 1/4/2020 10:36:58 AM Starting to try Rescue Recovery... Looking for a device in fastboot mode Device found: DYN6R19827000640 Getting IMEI... Getting build number... Getting model ... Getting battery state... Getting backdoor info... Getting lock state info... Getting lock boot info... Build number: DUB-LX1 8.2.0.142(C185) Model: DUB-LX1 Vendor/Country: Vendor/Country: hw/meafnaf Battery state: 3710mv OEM lock state info: user Lock state is lock fbLock state is lock OEM get bootinfo: ******************************************* Image is origin Verify mode is enforcing Check root info is safe Lock state is lock Root State: UNROOT ******************************************* Process identifier:21878210 Getting build number... Getting base version... Getting cust version... Getting preload version... Erasing ver .. . File size: 3,854,012,100 bytes AMSS version: DUB-L22 8.2.0.173(C900) Writing rescue_recovery_kernel partition RESCUE_RECOVERY_KERNEL partition update ...OK Writing rescue_recovery_ramdisk partition RESCUE_RECOVERY_RAMDISK partition update ...OK Writing rescue_recovery_vendor partition RESCUE_RECOVERY_VENDOR partition update ...OK Looking for device in upgrade mode... USB Device REMOVAL Type: @oem23.inf,%singlebootloaderinterface%;Android Bootloader Interface VidPid: VID_18D1&PID_D00D Instance id: DYN6R19827000640 |
So what happens when you follow the guide, put it manually in necessary mode and continue flashing? |
Flash in Edl Mode using XML firmware xtracted from App file |
