05-30-2018, 20:11 | #16 (permalink) |
Junior Member Join Date: Jul 2014
Member: 2230176 Status: Offline Thanks Meter: 0 | |
05-31-2018, 08:01 | #17 (permalink) |
Product Supporter Join Date: Sep 2013 Location: Lithuania, Kaunas
Member: 2023196 Status: Offline Thanks Meter: 1,892 | Hello, sorry do not quite understand, but if you can not detect device you should check device manager if phone appears there correctly to begin with. |
06-16-2018, 19:57 | #18 (permalink) |
Junior Member Join Date: Jan 2017
Member: 2667906 Status: Offline Thanks Meter: 0 | Hi I used this program to add a secondary IMEI to a P9L019, it was succesfull, but I cannot change the dual sim option. I can tick it but during the process the prog said this task skiped. The phone originaly was P9L09 , I flashed the oeminfo, so recognized as L19. (I wanted to overwrite it to enable the dual SIM, in vain ....)How can I change the dual sim state ? Or you have to modify something? thanks in advance A. |
06-17-2018, 04:23 | #19 (permalink) | |
Junior Member Join Date: Jun 2018
Member: 2845076 Status: Offline Thanks Meter: 0 | Quote:
06-18-2018, 09:31 | #21 (permalink) | |
Member: 2023196 Status: Offline Thanks Meter: 1,892 | Quote:
06-18-2018, 10:51 | #22 (permalink) |
Member: 2667906 Status: Offline Thanks Meter: 0 | So it is depend only on firmware, isnt it ? Cuse the firmware supports the dual sim mode, the oem,bin match with the firmware too . I have two Imei (first and second, the third is same like first ), a dual sim fw with a dual sim oem,bin but the phone not recognized the second slot. My original idea was that the probleme should solve if I (re)enable the dual sim option. But I cannot. The fw is an P9L19 so this dual sim. |
06-18-2018, 11:30 | #23 (permalink) | |
