12-01-2018, 11:54 | #1 (permalink) |
No Life Poster Join Date: Aug 2012 Location: under pross
Member: 1798174 Status: Offline Sonork: 100.114149 Thanks Meter: 1,048 | scc-u21 repair imei error 2018-12-01 11:18:48.454 Autodetect COM port and phone type start! 2018-12-01 11:18:49.404 Found COM port: COM34 2018-12-01 11:18:49.414 Found phone type: Huawei Android phone (Qualcomm CPU) New IMEI 1 : 867542021182053 New IMEI 2 : 867542021187052 2018-12-01 11:18:54.045 Connecting to server... 2018-12-01 11:18:54.925 Connected! 2018-12-01 11:18:54.925 Open COM port COM34 (DBAdapter Reserved Interface (COM34))... 2018-12-01 11:18:57.955 ERROR! Invalid command |
12-03-2018, 16:06 | #4 (permalink) |
Member: 1798174 Status: Offline Sonork: 100.114149 Thanks Meter: 1,048 | in supported models is supported but repair imei fail.... Ascend Y6 SCL-U21 Qualcomm MSM8909 2015 Yes Yes Yes - - Yes - Yes Yes Yes - Yes Yes and no answer from supporter bad support |
12-04-2018, 09:54 | #6 (permalink) | |
Member: 1798174 Status: Offline Sonork: 100.114149 Thanks Meter: 1,048 | Quote:
04/12/2018 09:41:58 Starting to write device in FORCE UPGRADE mode... File to update: SCC-U21_C900B057_Board_software_Southeast_Asia_Nonspec ific_testpoint.dgtks Device detected: COM63: Qualcomm HS-USB QDLoader 9008 (COM63) Writing MPRG...OK... Updating partition sbl1 ... Writing sbl1.mbn...OK Updating partition sec ... Writing sec.dat...OK Updating partition rpm ... Writing rpm.mbn...OK Updating partition tz ... Writing tz.mbn...OK Updating partition aboot ... Writing emmc_appsboot.mbn...OK Updating partition modemst1 ... Writing modem_st1.mbn...OK Updating partition modemst2 ... Writing modem_st2.mbn...OK Updating partition fsg ... Writing fs_image.tar.gz.mbn.img...OK Updating partition modem ... Writing NON-HLOS.bin...OK Updating partition persist ... Writing persist_1.img...OK Updating partition log ... Writing log.img...OK Updating partition boot ... Writing boot.img...OK Updating partition recovery ... Writing recovery.img...OK Updating partition cache ... Writing cache_1.img...OK Updating partition cust ... Writing cust_1.img...OK Updating partition system ... Writing system_1.img...OK Updating partition userdata ... Writing userdata_1.img...OK Writing userdata_2.img...OK Writing userdata_3.img...OK Writing userdata_4.img...OK Writing userdata_5.img...OK Writing userdata_6.img...OK Writing userdata_7.img...OK Writing userdata_8.img...OK Writing userdata_9.img...OK Writing userdata_10.img...OK Writing userdata_11.img...OK Writing userdata_12.img...OK Writing userdata_13.img...OK Writing userdata_14.img...OK Writing userdata_15.img...OK Updating partition system ... Writing system_2.img...OK Writing system_3.img...OK Writing system_4.img...OK Writing system_5.img...OK Writing system_6.img...OK Writing system_7.img...OK Writing system_8.img...OK Writing system_9.img...OK Writing system_10.img...OK Writing system_11.img...OK Writing system_12.img...OK Writing system_13.img...OK Writing system_14.img...OK Writing system_15.img...OK Writing system_16.img...OK Writing system_17.img...OK Writing system_18.img...OK Writing system_19.img...OK Writing system_20.img...OK Writing system_21.img...OK Writing system_22.img...OK Writing system_23.img...OK Writing system_24.img...OK Writing system_25.img...OK Writing system_26.img...OK Writing system_27.img...OK Writing system_28.img...OK Writing system_29.img...OK Writing system_30.img...OK Updating partition cust ... Writing cust_2.img...OK Writing cust_3.img...OK Writing cust_4.img...OK Updating partition cache ... Writing cache_2.img...OK Writing cache_3.img...OK Updating partition erecovery ... Writing erecovery.img...OK Updating partition PrimaryGPT ... Writing gpt_main0.bin...OK Updating partition BackupGPT ... Writing gpt_backup0.bin...OK Update force Update mode failed 04/12/2018 09:47:50 Writing device finished with ERROR phone dead now | |
12-04-2018, 17:25 | #7 (permalink) |
Product Supporter Join Date: Sep 2013 Location: Lithuania, Kaunas
Member: 2023196 Status: Offline Thanks Meter: 1,892 | So from IMEI repair attempt you went into board software flashing? Where is your head at? If mobile now doesn't flash with board software then only way to revive it is by replacing main board in it. |
The Following User Says Thank You to Namelocked For This Useful Post: |
