i nead to fix this problem Found modem : E5577Cs-321 Model : Huawei AuthVer 4 modem (New) IMEI : 86469503319ZZZZ Serial NR. : D2LDW17805004993 Firmware : 21.316.01.00.1029 Dashboard version : WEBUI_17.100.13.02.1029_MRE5 Web UI version : WEBUI_17.100.13.02.1029_MRE5 SIM Lock status : Locked (Card Lock) Wrong codes entered : 0 (unlock attempts left : 10) ================================================== ================= Unlocking, please wait ... Access denied (for dongle sharing) Error code 374 unlock failed ! |
Hi, please remove all usb sharing ports software... uninstall them restart pc and try gain, if you continuosly insist on that dongle will be blocked under advertise.... Best Regards Shensohau |
I do not have programs to share the usb port The problem has not yet been resolved |
This is the dongle id https://image.ibb.co/jLk0nG/Untitled_1.jpg https://ibb.co/ewfY7G |
Block now removed. If you do not know what service/software on your machine causes this then can suggest only to use dc-unlocker from another pc. Note: receiving multiple blocks for same reason may end up with a permanent block. |
