01-14-2017, 12:38 | #2 (permalink) |
No Life Poster Join Date: Aug 2010 Location: Inside Logic Age: 37
Member: 1377783 Status: Offline Sonork: 100.1611724 Thanks Meter: 3,336 | Hi, if your computer runs usb activity scanning/sharing service, therefore you got blocked. You must remove such service/software from computer before using DC-unlocker otherwise you will get blocked again. Now wait until block will removed!!! Best Regards Shensohau |
01-16-2017, 12:26 | #3 (permalink) |
Product Supporter Join Date: Sep 2013 Location: Lithuania, Kaunas
Member: 2023196 Status: Offline Thanks Meter: 1,892 | You got blocked second time for same reason Your computer runs usb activity scanning/sharing service, therefore you got blocked. You must remove such service/software from computer before using DC-unlocker otherwise you will get blocked again. Block now removed. If you do not know what service/software on your machine causes this then can suggest only to use dc-unlocker from another pc. Note: receiving multiple blocks for same reason may end up with a permanent block. |
04-01-2019, 16:07 | #5 (permalink) | |
Member: 2023196 Status: Offline Thanks Meter: 1,892 | Quote:
Block now removed. If you do not know what service/software on your machine causes this then can suggest only to use dc-unlocker from another pc. Note: receiving multiple blocks for same reason may end up with a permanent block. | |
05-13-2019, 09:25 | #7 (permalink) |
Member: 2023196 Status: Offline Thanks Meter: 1,892 | Your computer runs usb activity scanning/sharing service, therefore you got blocked. You must remove such service/software from computer before using DC-unlocker otherwise you will get blocked again. Block now removed. If you do not know what service/software on your machine causes this then can suggest only to use dc-unlocker from another pc. Note: receiving multiple blocks for same reason may end up with a permanent block. |
The Following User Says Thank You to Namelocked For This Useful Post: |
11-19-2019, 09:02 | #9 (permalink) | |
Block now removed. If you do not know what service/software on your machine causes this then can only suggest to use dc-unlocker from another pc. Note: receiving multiple blocks for same reason may end up with a permanent block. | |
