11-13-2017, 00:36 | #1 (permalink) |
Registered User Join Date: Feb 2012 Location: swimming
Member: 1725884 Status: Offline Sonork: swimming Thanks Meter: 293 | need help to repair huawei kii-l21 gr5 imei null.. DC - Unlocker 2 Client 1.00.1392 Detecting phone : selection : manufacturer - Huawei phones model - Auto detect (recommended) Found Applications port COM38 Found Diagnostics port COM40 Phone not found ! in fastboot modemodel - Auto detect (recommended) Found Phone : KIW-AL10 Model : Huawei phone in fastboot mode Firmware : KII-L23C469B340 FB LockState: LOCKED widevine LockState: LOCKED Bootloader Lock State: LOCKED Root State: UNROOT Bootloader WidevineKey: WidevineKey_NOTSET System State: OK Bootloader Version: 001.001.000 Battery state: 3809mv i flashed now KIW-L21_C900B076_Factory_firmware_Nonspecific_Android5 .1.1_EMUI_3.1_2.dgtks phone open with green and red& Blue lcd then open normal with same problem no service,no imei ,no wifi ,nobaseband but the big problem that model number changed to kIW-AL10 and build number show KII-L21C185B310,I think i need oem info but cant found it or i need factory firmware for KII-L21 TO return model id and solve lcd color display need urgent help from supporter,thanks... |
11-13-2017, 01:16 | #2 (permalink) |
Member: 1725884 Status: Offline Sonork: swimming Thanks Meter: 293 | when i check imei with imei info it shows this details IMEI 869254027048357 SN 86MDU16517001378 Product Model KII-L21 Customer Name Itsalat International Compnay - Egypt Signing Country Egypt Latest Delivery Place EG,CAIRO Delivery Date 2016-06-28 Warranty Models Full Warranty Warranty Expire 2017-11-01 Warranty Status Out of Warranty need help to solve this problem thanks... |
11-13-2017, 10:16 | #3 (permalink) |
Product Supporter Join Date: Sep 2013 Location: Lithuania, Kaunas
Member: 2023196 Status: Offline Thanks Meter: 1,892 | Please read Method 2 fully from repair guide, flashing factory firmware is not enough, need to flash full stock rom afterwards. However if after flashing phone with factory firmware alone it does not boot up - problem is on hardware level. |
The Following User Says Thank You to Namelocked For This Useful Post: |
11-13-2017, 16:52 | #4 (permalink) |
Member: 1725884 Status: Offline Sonork: swimming Thanks Meter: 293 | i have done all method i know it could be hardware problem but the problem now phone start up with lcd color red,green,blue and the model number changed to kiw-al10 and my model no kii-l21 i need help if you could upload kii-l21 factory firmware i think i could solve with factory or stock firmware by imei i gave you above thanks... |
The Following User Says Thank You to abo anas zayan For This Useful Post: |
11-13-2017, 16:59 | #5 (permalink) | |
Member: 2023196 Status: Offline Thanks Meter: 1,892 | Quote:
11-13-2017, 17:22 | #6 (permalink) |
Member: 1725884 Status: Offline Sonork: swimming Thanks Meter: 293 | phone boot up and works normally but it show color this at the beginning http://******.co/mv1ttrp51sqi and this happen after write factory firmware wrong i need help to make phone work normally like it was thanks... |
11-13-2017, 17:37 | #8 (permalink) | |
11-13-2017, 20:31 | #10 (permalink) |
Member: 1725884 Status: Offline Sonork: swimming Thanks Meter: 293 | problem for color display solved with this factory firmware KIW-AL10_C00B119_Factory_firmware_Android5.1.1_EMUI_3. 1_2.dgtks after that i flash this firmware in upgrade mode HUAWEI_GR5_Firmware_KII-L21_Android 6.0.1_EMUI 4.0_C185B310CUSTC185D004 now phone works with same problem imei null,no service,no baseband show,no sound but open normal without color display also model number changed to KIW-AL10 thanks... |
11-14-2017, 10:05 | #11 (permalink) | |
