08-25-2018, 10:51 | #1 (permalink) |
Insane Poster Join Date: Oct 2006
Member: 377110 Status: Offline Thanks Meter: 17 | how to connect the phone ? how should i connect phone for imei repair ? i enabled usb debug mode and connect usb cable and when i press phone info it does not detect the phone y3 y3 ii y5 y5 ii this is model list that i want to repair imei thanks in advance |
The Following User Says Thank You to alijamali For This Useful Post: |
08-25-2018, 11:03 | #2 (permalink) |
Member: 377110 Status: Offline Thanks Meter: 17 | how to connect the phone that hcu can detect it ? should i enable debug mode ? should i install any thing ? |
08-25-2018, 11:31 | #3 (permalink) |
Product Supporter Join Date: May 2013 Location: IN THIS WORLD ,LB,RO,
Member: 1933823 Status: Offline Thanks Meter: 1,273 | Follow the instruction on the right side for hisilicon or Qualcomm phones *#*#2846579#*#* for hisilicon and then you should select background settings then usb ports ans select manufacture mode then pc and hcu should see the phone to repair IF THIS POST WAS HELPFULL PRESS BUTTON |
The Following User Says Thank You to souma_k For This Useful Post: |
08-25-2018, 13:49 | #4 (permalink) | |
Member: 377110 Status: Offline Thanks Meter: 17 | Quote:
----------------------------- this code dosent work on this phones i tried this on y5 ii and y5 and y530 and dosent show anything ! | |
08-25-2018, 15:39 | #6 (permalink) |
Member: 377110 Status: Offline Thanks Meter: 17 | i am trying this code on y5 ii - its shows a menu after entering thid code but it dosent have any (back ground setting) or manufacture mode - i have searched all of this menu this are the menu items that it shows : setting phone info check network setting upgrade recovery battery charged menu and i have searched all the sub menu and didnt find anything that you said i am really confused right now !!! |
08-25-2018, 15:44 | #8 (permalink) |
Member: 377110 Status: Offline Thanks Meter: 17 | the point is this y5 ii model has a mtk cpu ! i can put this model in engeering mode with this code : *#*#3636633#*#* but after i enter the code of qualcomm or hsilicon code (*#*#2846579#*#*) its show the menu that i'v mentioned in last post and its shows : bordid : mt6582,y5iicun ?!!!!??? |
08-27-2018, 11:38 | #10 (permalink) |
Product Supporter Join Date: Sep 2013 Location: Lithuania, Kaunas
Member: 2023196 Status: Offline Thanks Meter: 1,891 | Instructions how to read bootloader unlock code from mtk phone: Huawei MTK phone bootloader code read ? HCU Client |
