05-13-2020, 15:54 | #2 (permalink) |
Product Supporter Join Date: Sep 2013 Location: Lithuania, Kaunas
Member: 2023196 Status: Offline Thanks Meter: 1,892 | Your computer runs usb activity scanning/sharing service, therefore you got blocked. You must remove such service/software from computer before using DC-unlocker otherwise you will get blocked again. Block now removed. If you do not know what service/software on your machine causes this then can only suggest to use dc-unlocker from another pc. Note: receiving multiple blocks for same reason may end up with a permanent block. |
05-13-2020, 17:03 | #3 (permalink) | |
Crazy Poster Join Date: Apr 2012 Location: Russia/Moscow
Member: 1748637 Status: Offline Thanks Meter: 5 | Quote:
07-27-2020, 13:10 | #5 (permalink) | |
Member: 2023196 Status: Offline Thanks Meter: 1,892 | Quote:
Block now removed. If you do not know what service/software on your machine causes this then can only suggest to use dc-unlocker from another pc. Note: receiving multiple blocks for same reason may end up with a permanent block. | |
