Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > DC Unlocker
Old 10-25-2018, 17:24   #1 (permalink)
Member: 1725169
Thanks Meter: 69
Unable Flash Huawei Phone FRD-AL00
10/25/2018 9:18:56 PM Starting to write device in FASTBOOT mode...
File to update: FRD-AL10_HL1FRDAL00M303_Factory_firmware_general_Andro id_6.0_EMUI_4.1.dgtks
Device found: WTK7N16A12005691
IMEI: xxxxxxxxxx
Build number: :FRD-L19C636B380
Product model: FRD-L19
Batery state: 3150mv
Erasing nvme partition
ERASE partition nvme ...FAILED
Cannot get FBlock info from device
Erasing cust partition
ERASE partition cust ...FAILED
Erasing misc partition
ERASE partition misc ...FAILED
Erasing userdata partition
ERASE partition userdata ...FAILED
Writing xloader partition with file fastbootimage/sec_xloader.img
xloader partition UPDATE ...FAILED
Writing ptable partition with file fastbootimage/ptable.img
ptable partition UPDATE ...FAILED
Writing fastboot partition with file fastbootimage/sec_fastboot.img
fastboot partition UPDATE ...FAILED
Writing dts partition with file fastbootimage/sec_dt.img
dts partition UPDATE ...FAILED
Writing fw_lpm3 partition with file fastbootimage/sec_lpm3.img
fw_lpm3 partition UPDATE ...FAILED
Writing sensorhub partition with file fastbootimage/sec_sensorhub.img
sensorhub partition UPDATE ...FAILED
Writing fw_hifi partition with file fastbootimage/sec_hifi.img
fw_hifi partition UPDATE ...FAILED
Writing teeos partition with file fastbootimage/sec_trustedcore.img
teeos partition UPDATE ...FAILED
Writing recovery partition with file fastbootimage/sec_recovery.img
recovery partition UPDATE ...FAILED
Erasing cache partition
ERASE partition cache ...FAILED
Writing cache partition with file fastbootimage/cache.img
cache partition UPDATE ...FAILED
Writing boot partition with file fastbootimage/sec_boot.img
Writing nvme partition with file fastbootimage/nvme.img
nvme partition UPDATE ...FAILED
Writing trustfirmware partition with file fastbootimage/sec_bl31.bin
trustfirmware partition UPDATE ...FAILED
Writing modem partition with file fastbootimage/sec_balong_modem.bin
modem partition UPDATE ...FAILED
Writing modem_dtb partition with file fastbootimage/sec_modem_dt.img
modem_dtb partition UPDATE ...FAILED
Writing modemnvm_update partition with file fastbootimage/nv.bin
modemnvm_update partition UPDATE ...FAILED
Writing modem_dsp partition with file fastbootimage/sec_lphy.bin
modem_dsp partition UPDATE ...FAILED
Writing modem_om partition with file fastbootimage/modem_fs.img
modem_om partition UPDATE ...FAILED
Writing modemnvm_img partition with file fastbootimage/modem_nv.img
modemnvm_img partition UPDATE ...FAILED
Writing 3rdmodem partition with file fastbootimage/3rdmodem.img
3rdmodem partition UPDATE ...FAILED
Writing 3rdmodemnvm partition with file fastbootimage/3rdmodemnvm.img
3rdmodemnvm partition UPDATE ...FAILED
Writing 3rdmodemnvmbkp partition with file fastbootimage/3rdmodemnvmbkp.img
3rdmodemnvmbkp partition UPDATE ...FAILED
Writing userdata partition with file fastbootimage/userdata.img
userdata partition UPDATE ...FAILED
Writing system partition with file fastbootimage/system.img
system partition UPDATE ...FAILED
Writing splash2 partition with file fastbootimage/splash2.img
splash2 partition UPDATE ...FAILED
Writing frp partition with file fastbootimage/frp.img
frp partition UPDATE ...FAILED
Writing cust partition with file fastbootimage/cust_factory.img
cust partition UPDATE ...FAILED
Writing secure_storage partition with file fastbootimage/secure_storage.img
secure_storage partition UPDATE ...FAILED
Update fastboot mode failed
10/25/2018 9:22:21 PM Writing device finished - INCOMPLETE
Old 10-25-2018, 19:01   #2 (permalink)
Mohsin-*'s Avatar
Member: 417298
Sonork: 100.1578269
Thanks Meter: 18,268
Tried Product model: FRD-L19 Firmware also .
But it give same error as above and incomplete please let me know you to fix
Old 10-26-2018, 08:22   #3 (permalink)
Member: 2023196
Thanks Meter: 1,893
Think you should try board software from dc-phoenix support area. There are multiple of them there, try them.
Old 10-26-2018, 11:16   #4 (permalink)
Mohsin-*'s Avatar
Member: 417298
Sonork: 100.1578269
Please point out firmware name
Old 10-26-2018, 16:39   #5 (permalink)
Member: 2023196
Thanks Meter: 1,893
Any FRD that has board software words in it.
The Following User Says Thank You to Namelocked For This Useful Post:
Old 10-27-2018, 14:27   #6 (permalink)
Mohsin-*'s Avatar
Member: 417298
Sonork: 100.1578269
Phone is Power on . onyl STUCk in Recovery .
is there no other way than Test point ?
Old 10-27-2018, 17:54   #7 (permalink)
Mohsin-*'s Avatar
Member: 417298
Sonork: 100.1578269
Finally Able flash but now comes on Fastboot and give error .
i have Flashed FRD-L19 and L00 both firmware
android reboot reason
BFM_S_Native_data_fail
NA
Reboot_panic_and_wdt_process_func
Old 10-27-2018, 18:19   #8 (permalink)
Mohsin-*'s Avatar
Member: 417298
Sonork: 100.1578269
in info Still detect as FRD-L19
Old 10-29-2018, 11:17   #9 (permalink)
Member: 2023196
Thanks Meter: 1,893
You have flashed board software, but phone still doesn't boot up?
Old 10-29-2018, 21:55   #10 (permalink)
Mohsin-*'s Avatar
Member: 417298
Sonork: 100.1578269
On bord software phone bootup ok
But after flash stock firmware stuck on fast boot and error
Old 10-30-2018, 08:46   #11 (permalink)
Member: 2023196
Thanks Meter: 1,893
It means files you applying to mobile does not suit it. I assume before flashing it you repair mobile's vendor/country and model on hcu accordingly to the new full stock rom data that you flash?
Old 10-30-2018, 12:38   #12 (permalink)
Mohsin-*'s Avatar
Member: 417298
Sonork: 100.1578269
Phone hve frd-l19 .oem and carrier info . and i hve flash same firmware . ill try other frd firmware .
Can you let me know correct oem / carrier and other info as basicly phone is FRD-AL00
The Following User Says Thank You to Mohsin-* For This Useful Post:
Old 10-30-2018, 16:24   #13 (permalink)
Member: 2023196
Thanks Meter: 1,893
I can not let you know it because this data is written on customization file name that you flash your device with and can see it only yourself.
Old 11-03-2018, 16:32   #14 (permalink)
Mohsin-*'s Avatar
Member: 417298
Sonork: 100.1578269
Flashed all model Firmware but still stuck on same ,
Old 11-05-2018, 12:41   #15 (permalink)
Member: 2023196
Thanks Meter: 1,893
If phone does not boot up after successfully flashing board software then only thing that can help it is main board replacement.
Page generated in 0.21532 seconds with 8 queries
