Go Back   GSM-Forum > GSM & CDMA Phones Hardware Repair Area > LCD Refurbish
LCD Refurbish All things related to LCD / Screen refurbish and repair
Old 05-28-2018, 07:36   #1 (permalink)
Member: 2621291
Thanks Meter: 124
Glass / screen only replacement for LENOVO K6 NOTE [k53a48]
To replace the screen without any trouble follow the steps from the guide:
http://www.youtube.com/watch?v=uM06IXqXgyo
The Following User Says Thank You to eselekt For This Useful Post:
Old 05-30-2018, 12:15   #2 (permalink)
KrzychuG's Avatar
Member: 25996
Thanks Meter: 253
It's a bit weird that you separated glass from digitized and then removed digitizer from LCD but it's fine. What's strange is that price difference between the "glass" and whole assembly is not that big but K6 Note has issues with touch that stops working after you, for any reason, turn off the screen (can be proximity sensor during call, can be by power button etc) and then wake it up. Touch works again after rebooting the phone. I had at least 3 different assemblies that does that and it's related to digitizer, not the screen. It's worth to check before bonding not only if touch works fine but also if it survices a simple sleep/wake without a problem ;-)
Page generated in 0.14156 seconds with 8 queries
