Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > HDBox
Old 03-30-2017, 06:49   #1 (permalink)
Gsm-extreme's Avatar
Member: 659181
Thanks Meter: 7,652
Managment software V1.7 for HD-Box
Management software V1.7 for HD-Box
  • Software and additional
+ Extended the list of devices & firmwares supported by HDBox manager,+ Improved functionality of the virtual keyboard for both IOS and Android,
+ Added mouse zone to virtual keyboard for Android,
+ Improved overall aspect of the virtual keyboard,
+ Added new iMac & MacBook tab for extended operations regarding apple computers:
– Can read the SPI FLASH directly, or load a dump from file
– Can display detailed info about the EFI Image
– Can help fix Intel Management Engine issues ( Macs not starting, or restarting all the time)
– Can instantly show firmware password for 2011 and early macs
– Can remove the firmware password for later mac models
– Can write to SPI FLASH directly, or can save as a new file
Download / Reseller / Resellers Program
HDBox firmwares and apps latest versions
BIOS 1.5, updated 2017-March-03
SYSTEM 1.7, updated 2017-March-03
Usb2Serial 0.9C, updated 2017-March-03 ( Download Driver, Pinout )
__________________
Best Regards
Gsm-Extreme
HD-Box
The Following 20 Users Say Thank You to Gsm-extreme For This Useful Post:
Old 03-30-2017, 09:22   #2 (permalink)
Member: 1128573
Thanks Meter: 242
hello boss,
if i wrong pls correction about SPI flashing ,
In a computer, a serial peripheral interface (SPI) is an interface that enables the serial (one bit at a time) exchange of data between two devices, one called a master and the other called a slave . An SPI operates in full duplex mode. This means that data can be transferred in both directions at the same time.
and EFI
The Unified Extensible Firmware Interface (UEFI) is a specification that defines a software interface between an operating system and platform firmware. ... In 2005, UEFI deprecated EFI 1.10 (the final release of EFI). The Unified EFI Forum is the industry body that manages the UEFI specification
its working only EMMC OR NAND ? pls if details , better for us.
thanks,
with best regards and wishes,
mahir
The Following 4 Users Say Thank You to mahir ashab For This Useful Post:
Old 03-30-2017, 16:35   #3 (permalink)
HDB
Member: 1300847
Thanks Meter: 547
Originally Posted by mahir ashab View Post
hello boss,
and EFI
thanks,
mahir
Dear Sir,
Thanks for your question! It will help others to understand the forensic tool better. Below is our reply to all you doubt.
we are refering to the SPI flashing for the mac computers. Using SPI flashing, we can read the information from the BIOS/UEFI chip and using our forensic algorithms we can see if the EFI firmware password is set, if computer is linked to an iCloud account ( and soon we will be able to display this account ), and also see if the icloud lock is activated ( already we can detect if it is 4 or 6 digit codes ).
And depending on the combinations of computer model, OS updates, EFI updates, etc we can EVEN show directly the EFI Firmware password, and show directly the iCloud Lock unlocking code.
For selected chips ( we are working in expanding the list) we can also directly removed/disable this locks, but we focused more on retriving them, instead of just nuking them, because retriving them and doing no changes to the content on the computer is a GREAT tool for forensinc investigations.
And for normal users, our SPI flashing tool, can help them fix certain problems of their apple computers, by updating / fixing Intel Management Engine, among this problems are computers stuck at boot, or they just keep playing the chime sound and reboot again, or starting slow. This is not a silver bullet for all problems of all apple computers, but for this specific things, is the best tool.
Thanks & Best Regards!
HDB Team
The Following 3 Users Say Thank You to HDB For This Useful Post:
Old 04-02-2017, 08:57   #4 (permalink)
Member: 901949
Thanks Meter: 50
all this functions required the efi chip to be removed from board or we can do it using specific connector ? and do you have links on tutorials?
The Following User Says Thank You to frosted For This Useful Post:
Old 04-03-2017, 23:36   #5 (permalink)
Member: 1738539
Thanks Meter: 11
We are working on implementing voltage regulators in our adaptors so there will be no need to desolder and solder back the chip, and besides some new macs got BGA chips... And those are extremly hard to service, so our focus as thia noment is safety while using our adaptor.
Of course,Ofc, if the mac got soic 8 chip then is easy to solder/desolder, and if the chip operates at 3.3 v, we can use normal soic 8 adaptor to read / write those kind of chips. After we finalize the pin asigment in our exptension port we will release the pinout.
...extension port, no limitation.
Page generated in 0.16928 seconds with 8 queries
