Old 10-09-2019, 17:54   #1066 (permalink)
canliyayin's Avatar
Member: 311558
Thanks Meter: 476
g611f 9.0 root done
g611f 9.0 root done......
Old 10-12-2019, 07:38   #1067 (permalink)
Member: 361094
Sonork: 100.1597521
Thanks Meter: 172
Thumbs up rne l21 frp done
Waiting for USB COM 1 port.....Detected {COM418} Connecting to device.....OK
Writing data 1.....OK
Writing data 3.....OK
Rebooting device to fastboot.....OK
Waiting for fastboot device.....OK
Reading info.....OK
Device Model: RNE-L21
Device Serial: FFY5T18411018617
Device IMEI: 869676033304491
Device IMEI2: 869676033340503
Device Firmware: :RNE-L21 8.0.0.348(C185)
Device FB Lock: UNLOCKED
Device USER Lock: LOCKED
Device Lock: unlocked
Resetting FRP.....OK
Operation ID: 72EC100925A4F4489A93D13EEA339F93
Elapsed time 00:34 -- Version 1.5.1
Old 10-12-2019, 08:28   #1068 (permalink)
Member: 2778229
Thanks Meter: 361
j200g frp done
Old 10-17-2019, 07:47   #1069 (permalink)
Member: 1079392
Thanks Meter: 444
Samsung j600g imei write succesfully wif eft pro
FIRST CREATED ROOT FILE WITH EFT DONGLE,then flashed with the root file,now device rooted,after that factory imei repaired succesfully with EFT PRO,
Old 10-19-2019, 13:37   #1070 (permalink)
jaan_e_ahsan45's Avatar
Member: 689829
Sonork: 100.1651716
Thanks Meter: 102
Wink M105F Patch Cert Done, Unexpected way...
M105F Patch Cert Done By EFT Pro (Unexpectedly).
IMEI Repaired by other tool, but after Patch Cert a couple of Very Popular tools Failed to bring network (IMEI Status NG).
Then with EFT Pro Repair Tab Restore Original IMEI , IMEI Remained Same but IMEI Status OK.
Waiting For Android Device.....Done
Reading Device Info...
Device Model: SM-M105F
Device Manufacturer: samsung
Device Firmware: M105FDDU2BSH2
Device Serial: RZ8M40V9CFB
Device Chipset: Exynos
Device IMEI: 351************
Android Version: 9
Android SDK: 28
Firmware Country: India
Firmware Code: INS
Checking Root.....Done
Checking CPID Protection Status.....Activated
Restoring Original IMEI.....Done
Current IMEI Backup Saved To: [Backup/SM-M105F_IMEI_BACKUP_351***********.tar]
Thanks EFT Team.
Old 10-20-2019, 08:46   #1071 (permalink)
Member: 2765424
Thanks Meter: 1,039
Samsung g610l flash done
SAMSUNG G610L FLASH DONE
Searching for Samsung ODIN protocol.....Detected {COM28}
Total flash size: 4,22 GB
Device Model.....SM-G610L
Setting PIT.....OK
Reading PIT.....OK
Flashing [sboot.bin].....OK
Flashing [param.bin].....OK
Flashing [cm.bin].....OK
Flashing [boot.img].....OK
Flashing [recovery.img].....OK
Flashing [system.img].....OK
Flashing [userdata.img].....OK
Flashing [modem.bin].....OK
Flashing [cache.img].....OK
Flashing [hidden.img].....OK
Rebooting device.....OK
Operation ID: B46DE46E2AAF68A0152038B32A86F386
Elapsed time 02:58 -- Version 1.5.1
Old 10-20-2019, 08:48   #1072 (permalink)
Member: 2765424
Thanks Meter: 1,039
SAMSUNG G930T RESET SCREEN LOCK DONE without data lose
SAMSUNG G930T RESET SCREEN LOCK DONE without data loss
Opening Port COM44...........OK
Verifying Download Mod
OK
Initialization.......OK
Reading Phone Partitation Table........OK
Partition Size : 8192
Unpak pit .......OK
FLASHING FIRMWARE TO PHONE.....
Sending data: ..........OK
FLASHING DONE!
Rebooting PDA TO NORMAL MODE........OK
Waiting For ADB Device.....Detecting Device Info.....DONE
Device Model: SM-G930T
Device CPU: arm64-v8a
Android SDK: 26
Android Version: 8.0.0
Screen Lock reset .......OK
Old 10-20-2019, 10:00   #1073 (permalink)
akhtar.abbas's Avatar
Member: 1190193
Sonork: 1619687
Thanks Meter: 406
G-920t-remove screen lock-adb mode
Old 10-20-2019, 18:30   #1074 (permalink)
Member: 361094
Sonork: 100.1597521
Thanks Meter: 172
Thumbs up htc flyer zip complete done
.. (bootloader) erase sector 163328 ~ 163839 (512)
OKAY
Execution time is 1(s)
imei: 355195000000000
Execution time is 2(ms)
modelid: PG4140000
cidnum: FHLTW601
sending 'zip'... (497205 KB) OKAY
writing 'zip'... (bootloader) zip header checking...
(bootloader) shift signature_size for header checking...
(bootloader) zip info parsing...
(bootloader) checking model ID...
(bootloader) checking custom ID...
(bootloader) start image[hboot] unzipping for pre-update check...
(bootloader) start image[hboot] unzipping & flushing...
(bootloader) [RUU]UZ,hboot,0
(bootloader) [RUU]UZ,hboot,100
(bootloader) start image[boot] unzipping & flushing...
(bootloader) [RUU]UZ,boot,0
(bootloader) [RUU]UZ,boot,32
(bootloader) [RUU]UZ,boot,64
(bootloader) [RUU]UZ,boot,95
(bootloader) [RUU]UZ,boot,100
(bootloader) [RUU]WP,boot,0
(bootloader) [RUU]WP,boot,99
(bootloader) [RUU]UZ,recovery,21
(bootloader) [RUU]WP,boot,100
(bootloader) start image[recovery] unzipping & flushing...
(bootloader) [RUU]UZ,recovery,0
(bootloader) [RUU]UZ,recovery,41
(bootloader) [RUU]UZ,recovery,63
(bootloader) [RUU]UZ,recovery,99
(bootloader) [RUU]UZ,recovery,100
(bootloader) [RUU]WP,recovery,0
(bootloader) [RUU]WP,recovery,99
(bootloader) [RUU]WP,recovery,100
(bootloader) start image[system] unzipping & flushing...
(bootloader) [RUU]UZ,system,0
(bootloader) [RUU]UZ,system,1
(bootloader) [RUU]UZ,system,2
(bootloader) [RUU]UZ,system,3
(bootloader) [RUU]UZ,system,5
(bootloader) [RUU]UZ,system,6
(bootloader) [RUU]UZ,system,8
(bootloader) [RUU]UZ,system,9
(bootloader) [RUU]UZ,system,11
(bootloader) [RUU]UZ,system,12
(bootloader) [RUU]UZ,system,14
(bootloader) [RUU]UZ,system,16
(bootloader) [RUU]UZ,system,17
(bootloader) [RUU]UZ,system,19
(bootloader) [RUU]UZ,system,20
(bootloader) [RUU]UZ,system,22
(bootloader) [RUU]UZ,system,23
(bootloader) [RUU]WP,system,0
(bootloader) [RUU]WP,system,1
(bootloader) [RUU]WP,system,2
(bootloader) [RUU]WP,system,4
(bootloader) [RUU]WP,system,5
(bootloader) [RUU]WP,system,7
(bootloader) [RUU]WP,system,9
(bootloader) [RUU]WP,system,10
(bootloader) [RUU]WP,system,12
(bootloader) [RUU]WP,system,13
(bootloader) [RUU]WP,system,15
(bootloader) [RUU]WP,system,16
(bootloader) [RUU]WP,system,18
(bootloader) [RUU]WP,system,19
(bootloader) [RUU]WP,system,21
(bootloader) [RUU]WP,system,23
(bootloader) [RUU]UZ,system,24
(bootloader) [RUU]UZ,system,25
(bootloader) [RUU]UZ,system,27
(bootloader) [RUU]UZ,system,28
(bootloader) [RUU]UZ,system,30
(bootloader) [RUU]UZ,system,32
(bootloader) [RUU]UZ,system,33
(bootloader) [RUU]UZ,system,35
(bootloader) [RUU]UZ,system,36
(bootloader) [RUU]UZ,system,38
(bootloader) [RUU]UZ,system,39
(bootloader) [RUU]UZ,system,41
(bootloader) [RUU]UZ,system,42
(bootloader) [RUU]UZ,system,44
(bootloader) [RUU]UZ,system,46
(bootloader) [RUU]WP,system,24
(bootloader) [RUU]WP,system,25
(bootloader) [RUU]WP,system,27
(bootloader) [RUU]WP,system,28
(bootloader) [RUU]WP,system,30
(bootloader) [RUU]WP,system,32
(bootloader) [RUU]WP,system,33
(bootloader) [RUU]WP,system,35
(bootloader) [RUU]WP,system,36
(bootloader) [RUU]WP,system,38
(bootloader) [RUU]WP,system,39
(bootloader) [RUU]WP,system,41
(bootloader) [RUU]WP,system,42
(bootloader) [RUU]WP,system,44
(bootloader) [RUU]WP,system,46
(bootloader) [RUU]UZ,system,47
(bootloader) [RUU]UZ,system,49
(bootloader) [RUU]UZ,system,50
(bootloader) [RUU]UZ,system,52
(bootloader) [RUU]UZ,system,53
(bootloader) [RUU]UZ,system,55
(bootloader) [RUU]UZ,system,57
(bootloader) [RUU]UZ,system,58
(bootloader) [RUU]UZ,system,60
(bootloader) [RUU]UZ,system,62
(bootloader) [RUU]UZ,system,63
(bootloader) [RUU]UZ,system,65
(bootloader) [RUU]UZ,system,66
(bootloader) [RUU]UZ,system,68
(bootloader) [RUU]UZ,system,70
(bootloader) [RUU]WP,system,47
(bootloader) [RUU]WP,system,49
(bootloader) [RUU]WP,system,50
(bootloader) [RUU]WP,system,52
(bootloader) [RUU]WP,system,53
(bootloader) [RUU]WP,system,55
(bootloader) [RUU]WP,system,57
(bootloader) [RUU]WP,system,58
(bootloader) [RUU]WP,system,60
(bootloader) [RUU]WP,system,61
(bootloader) [RUU]WP,system,63
(bootloader) [RUU]WP,system,65
(bootloader) [RUU]WP,system,66
(bootloader) [RUU]WP,system,68
(bootloader) [RUU]WP,system,70
(bootloader) [RUU]UZ,system,71
(bootloader) [RUU]UZ,system,72
(bootloader) [RUU]UZ,system,74
(bootloader) [RUU]UZ,system,76
(bootloader) [RUU]UZ,system,77
(bootloader) [RUU]UZ,system,79
(bootloader) [RUU]UZ,system,80
(bootloader) [RUU]UZ,system,82
(bootloader) [RUU]UZ,system,84
(bootloader) [RUU]UZ,system,85
(bootloader) [RUU]UZ,system,87
(bootloader) [RUU]UZ,system,88
(bootloader) [RUU]UZ,system,90
(bootloader) [RUU]UZ,system,91
(bootloader) [RUU]UZ,system,93
(bootloader) [RUU]WP,system,71
(bootloader) [RUU]WP,system,72
(bootloader) [RUU]WP,system,74
(bootloader) [RUU]WP,system,75
(bootloader) [RUU]WP,system,77
(bootloader) [RUU]WP,system,79
(bootloader) [RUU]WP,system,80
(bootloader) [RUU]WP,system,82
(bootloader) [RUU]WP,system,83
(bootloader) [RUU]WP,system,85
(bootloader) [RUU]WP,system,86
(bootloader) [RUU]WP,system,88
(bootloader) [RUU]WP,system,89
(bootloader) [RUU]WP,system,91
(bootloader) [RUU]WP,system,93
(bootloader) [RUU]UZ,system,94
(bootloader) [RUU]UZ,system,95
(bootloader) [RUU]UZ,system,96
(bootloader) [RUU]UZ,system,97
(bootloader) [RUU]UZ,system,98
(bootloader) [RUU]UZ,system,99
(bootloader) [RUU]UZ,system,100
(bootloader) [RUU]WP,system,94
(bootloader) [RUU]WP,system,96
(bootloader) [RUU]WP,system,98
(bootloader) [RUU]WP,system,100
(bootloader) start image[sp1] unzipping & flushing...
(bootloader) [RUU]UZ,sp1,0
(bootloader) [RUU]UZ,sp1,99
(bootloader) [RUU]UZ,sp1,100
(bootloader) [RUU]WP,sp1,0
(bootloader) [RUU]WP,sp1,100
(bootloader) start image[dzdata] unzipping & flushing...
(bootloader) [RUU]UZ,dzdata,0
(bootloader) [RUU]UZ,dzdata,100
(bootloader) [RUU]WP,dzdata,0
(bootloader) [RUU]WP,dzdata,100
(bootloader) start image[radio] unzipping & flushing...
(bootloader) [RUU]UZ,radio,0
(bootloader) [RUU]UZ,radio,8
(bootloader) [RUU]UZ,radio,14
(bootloader) [RUU]UZ,radio,20
(bootloader) [RUU]UZ,radio,28
(bootloader) [RUU]UZ,radio,35
(bootloader) [RUU]UZ,radio,47
(bootloader) [RUU]UZ,radio,55
(bootloader) [RUU]UZ,radio,40
(bootloader) [RUU]UZ,radio,64
(bootloader) [RUU]UZ,radio,71
(bootloader) [RUU]UZ,radio,80
(bootloader) [RUU]UZ,radio,87
(bootloader) [RUU]UZ,radio,95
(bootloader) [RUU]UZ,radio,100
(bootloader) [RUU]WP,radio,0
(bootloader) [RUU]WP,radio,6
(bootloader) [RUU]WP,radio,14
(bootloader) [RUU]WP,radio,22
(bootloader) [RUU]WP,radio,30
(bootloader) [RUU]WP,radio,38
(bootloader) [RUU]WP,radio,48
(bootloader) [RUU]WP,radio,53
(bootloader) [RUU]WP,radio,61
(bootloader) [RUU]WP,radio,69
(bootloader) [RUU]WP,radio,77
(bootloader) [RUU]WP,radio,85
(bootloader) [RUU]WP,radio,91
(bootloader) [RUU]WP,radio,100
(bootloader) start image[rcdata] unzipping & flushing...
(bootloader) [RUU]UZ,rcdata,0
(bootloader) [RUU]WP,rcdata,0
(bootloader) [RUU]WP,rcdata,100
sending time = 77.740 secs
OKAY
Flash Zip Complete
Execution time is 279(s)
rebooting...
Execution time is 320(ms)
Old 10-21-2019, 04:45   #1075 (permalink)
Member: 2778229
Thanks Meter: 361
honro bnd-al10 frp with great eft one click test point
Old 10-21-2019, 11:12   #1076 (permalink)
AL-KARAM MOBILE's Avatar
Member: 1329373
Thanks Meter: 87
EASY-TEAM
Waiting For Android Device.......OK
Reading Device Info.......OK
Product: Sony
Device Chipset: qcom
Device Model: E5823
Device Serial: CB5A2957HH
Android Version: 7.1.1
Android SDK: 25
Architecture: arm64-v8a
Free space in system disk: 590M
Phone Mode: Normal Mode
Checking Root Permission.......Fail
Frp reset ......OK
The Following User Says Thank You to AL-KARAM MOBILE For This Useful Post:
Old 10-22-2019, 05:25   #1077 (permalink)
Member: 2233266
Thanks Meter: 252
Opening Port COM20...........OK
OK
Unpak pit .......OK
Sending data2: ........OK
FLASHING DONE!
Please Enter your device into recovery mode
Waiting Adb in Recovery Mode.....DONE
Device Model: SM-G532F
Device CPU: armeabi-v7a
Android SDK: 23
Android Version: 6.0.1
Resetting Samsung Account / Frp .....
Found protection1
Protection1 has been deleted
Found protection2
Protection2 has been deleted..OK
Old 10-22-2019, 07:30   #1078 (permalink)
Member: 2778229
Thanks Meter: 361
Thumbs up Huawei LDN-LX2 FRP rest
Huawei LDN-LX2 FRP rest with Huawei King *EFT Pro*
Old 10-24-2019, 12:50   #1079 (permalink)
Member: 2171555
Thanks Meter: 129
new exe incorrect ...
Connecting Fastboot ............OK
Model Phone: RNE-L21
SW: :RNE-L21 8.0.0.348(C185)
Downloading upgrade partitions.......OK
Connecting to device.......OK
Preparing Firmware.......OK
UPDATE.APP:
Flash: sha256rsa.img..............OK
Flash: crc.img..............OK
Flash: curver.img..............OK
Flash: verlist.img..............OK
Flash: package_type.img..............OK
Flash: efi.img..............OK
Flash: xloader.img..............OK
Flash: fw_lpm3.img..............OK
Flash: fastboot.img..............OK
Flash: modemnvm_update.img..............OK
Flash: teeos.img..............OK
Flash: trustfirmware.img..............OK
Flash: sensorhub.img..............OK
Flash: fw_hifi.img..............OK
Flash: kernel.img..............OK
Flash: ramdisk.img..............OK
Flash: recovery_ramdisk.img..............OK
Flash: recovery_vendor.img..............OK
Flash: erecovery_kernel.img..............OK
Flash: erecovery_ramdisk.img..............OK
Flash: erecovery_vendor.img..............OK
Flash: recovery_vbmeta.img..............OK
Flash: erecovery_vbmeta.img..............OK
Flash: dts.img..............OK
Flash: modem_fw.img..............OK
Flash: vbmeta.img..............OK
Flash: odm.img..............OK
Flash: cache.img..............OK
Flash: system.img..............OK
Flash: cust.img..............OK
Flash: vendor.img..............OK
Flash: version.img..............OK
Flash: product.img..............OK
Flash: userdata.img..............OK
update_RNE-L21_hw_meafnaf.app:
Operation Completed.
All Done By EFT Dongle
Old 10-25-2019, 07:59   #1080 (permalink)
Member: 1028799
Thanks Meter: 49
huawei mya-l22 frp done
Run eft dongle v2.7
Select mtk
Select brand Huawei
Select model Huawei mya-l22 c185
Select services – eft – frp reset(fast)
Click start
Phone off mode, connect usb to pc
Detection is auto, wait till done =
Page generated in 0.40041 seconds with 9 queries
