03-07-2018, 19:10 | #1 (permalink) |
Freak Poster Join Date: Jul 2016 Location: U.S.A
Member: 2604559 Status: Offline Sonork: Ventaslaredo Thanks Meter: 131 | ZTE Z982 FRP REMOVAL DONE. BY Uni Android Tool. 0- Select ZTE window. 1-press vol- and power at same time for 15 sec., ( when EFT MODE appears.) you can leave pushing bottoms. 2- plug your phone on FTM mode and scan the port., 3- select the model ZTE Z982. 4 ON "REBOOTS" window select FTM TO EDL MODE and push the little gren bottom at your Right. (screen phone well be appears on black) 5- on "RESET FRP {EDL MODE} window select or mark EDL MODE (option) 6- then Press "RESET FRP" AND uniAndroid tol will start to work and done fast. HERE MY LOG its fron Today,. Checking Current Version Current Version OK Checking User Login User Login OK. Searching device Device on Port : [ COM72 ] Analyzing Please wait ... MODEL : ZTE Blade Z MAX Z982 MEM_TYPE : EMMC BLOCK_ID_S : 23FCA4F7 BLOCK_ID_L : 00000000 BLOCK_ID_H : FDAC87167C2B5ABD71D9D9D948B180B8 BLOCK_ID_H : DAFE3F0FC6AF795BD67E17ADC7233D58 Starting Zte Frp Removal Method Reading Data .. Please wait Sending loader Please wait ... Loader successfully Sent ... Model : Z982 Android Version : 7.1.1 Name : Z982 Display ID : Z982_MPCSV1.0.0B14 Device : crocus Manufacturer : ZTE Product : crocus Reading Frp Data FRP Data Found Removing Frp data .. Please Wait Writting Data @ 512kb/s Write data done Frp Removal Succeeded. Rebooting Device If You Think my post its Good. You Know what to do. Thanks., // UniAndroidTool. |
The Following 7 Users Say Thank You to ventaslaredo For This Useful Post: |
06-24-2018, 06:09 | #7 (permalink) |
No Life Poster Join Date: May 2016 Location: 574 Age: 31
Member: 2567774 Status: Offline Thanks Meter: 255 | I have issue for all ZTE devices I have tried so far. When using FTM->EDL tool always says searching device when connected USB and in FTM mode already. It won't connect to start the job. May it be the cable I am using? I use same cable for all ANDROID, LG SAMSUNG etc Sent from my SAMSUNG-SM-G890A using Tapatalk |
06-24-2018, 07:24 | #8 (permalink) | |
Product Manager Join Date: Mar 2012 Location: Some Where
Member: 1737175 Status: Offline Sonork: 100.1667675 Thanks Meter: 10,532 | Quote:
You need to Install FTM drivers which are available on Support Area. | |
06-24-2018, 11:29 | #10 (permalink) | |
Product Manager Join Date: Apr 2017 Location: Konstantinopolis
Member: 2709688 Status: Offline Thanks Meter: 2,186 | Quote:
ZTE Devices in FTM Mode recgonize adb drivers, so you can reboot adb to edl mode also. BR | |
The Following User Says Thank You to namyelus For This Useful Post: |
09-14-2018, 05:17 | #15 (permalink) |
Junior Member Join Date: Sep 2018
Member: 2863926 Status: Offline Thanks Meter: 0 | ok so i downloaded the zte driver but this still doesnt work for me? the only way it will scan the port is after i press the green reboot button, but after i do that and the port shows up, if i try to press the reset frp button then it tells me it cant find a device? |
