09-13-2005, 09:23 | #1 (permalink) |
Junior Member Join Date: Sep 2005 Age: 42
Member: 177427 Status: Offline Thanks Meter: 0 | 3390b please help! how to convert |
09-14-2005, 06:19 | #2 (permalink) |
Insane Poster Join Date: Aug 2005 Location: philippines Age: 48
Member: 169368 Status: Offline Thanks Meter: 3 | my teacher converted this unit. He changed uem to 3310 and then flashed it. He got uem from a unit that had different problem. then you will have problem with not charging, you have to remove diode next to charging ic i think i will verify and post again re: not charging. Good luck!! |
09-14-2005, 06:46 | #3 (permalink) |
Freak Poster Join Date: May 2005 Location: Nigeria Age: 44
Member: 142704 Status: Offline Thanks Meter: 9 | the solution is that you first did the hardware part after that you flash with 3310 flashing file and rebuild the IMEI please that is all i know about that have try my own is ok but the network is not ok |
09-25-2005, 19:02 | #4 (permalink) |
Junior Member Join Date: Jun 2005 Age: 40
Member: 154566 Status: Offline Thanks Meter: 0 | Here is little trick for 3390 to 3310 *z501,z500 top 1 2 3 4 5 6 ==>short 2 5 *remove v500 short all it terminals to c525 *short capacitors c242 and c227 near ccont *remove r113 and short terminals of c113 and r117 near IC cobba *jumper wire beetwen r450 and r402 near simcard connector *Open tin shielding of vco G503(FDK) remove big capacitors then short it after steps..flash with Nhm-5 firmware and run NokTool18 init simlock Good lucks... |
09-26-2005, 03:45 | #5 (permalink) |
Member: 169368 Status: Offline Thanks Meter: 3 | hi chapkiwi! your idea seems nice to try have you tested this? no problems occured? may i request you to put diagram so begginers like me can understand your wonderfull solution better? thank you very much! |
09-26-2005, 16:42 | #7 (permalink) |
Member: 177427 Status: Offline Thanks Meter: 0 | thanks guys, but someone tells me that the solution i did is wrong, b'coz i did the hardware solution first and changed the firmware. someone tells me that you have to flash it first before converting it. wich is i did is wrong. anyway thank all guys for your concerned. at list we have a tip like me beginners. the first thing to do is flash it first to 3310-3315 then do the hardware part. like CHAPKIWI posted. anyway thank you CHAPKIWI for the diagram. nice work men... |
09-27-2005, 11:46 | #8 (permalink) | |
No Life Poster Join Date: Apr 2004 Age: 49
Member: 61294 Status: Offline Thanks Meter: 49 | Quote:
before convertion of softwares, you have to check , the software versions of both mobile phone model before any possible convertion. if you are not correct or for more sendme any email. bestman | |
10-22-2005, 05:36 | #10 (permalink) |
Member: 142704 Status: Offline Thanks Meter: 9 | hafe done the hardware part before software but the network is bad when i try to put the phone on the network will come alfter the network will go off pleae any onw help please |
10-25-2005, 02:32 | #11 (permalink) |
Member: 142704 Status: Offline Thanks Meter: 9 | hello guy thanks for good job done ,but i have another problem after the hardware and the software i have network problem ,when i try t put the phone on the phone will bring network after like 2 sec the network will disapear,if try try to go to restore factory setting the network logo will come but the bar will not come please amy solution. what i use is twister to flash it and have done all the convertion to 3310 from 3390 but i have just only network it only comes when i on the phone just only for 2 sec thanks ......................www.koollife.net.ms |
12-03-2005, 16:28 | #13 (permalink) | |
No Life Poster Join Date: Jul 2005 Location: Pakistan Age: 36
Member: 158181 Status: Offline Thanks Meter: 113 | enjoy Quote:
just change the cobba ic.ur fone go to simcard not accepted if ur cobba is correct change.then unlock ur fone. enjoy br Shami | |
12-04-2005, 11:13 | #15 (permalink) | |
No Life Poster Join Date: Jun 2005 Location: rajabrothers communications Age: 43
Member: 155773 Status: Offline Sonork: 1606514 Thanks Meter: 87 | Quote:
br raja | |
The Following User Says Thank You to rajabrotherscom For This Useful Post: |
help how to convert SGH-E105 | Jherlon | Trident/AGERE Platform | 3 | 10-30-2008 08:06 |
PLEASE HELP! HOW TO UPLOAD TURKISH LANG TO SAMSUNG i300? | KUBAT1 | HTC & PDA WM( With Touchscreen) | 3 | 06-20-2006 18:13 |
Need help how to convert my smart-clip... | Elioni | Smart-Clip | 10 | 02-07-2006 17:15 |
Please help ! How to upgrade N620 to N628 ? Thanks. | chyelim | VLSI, Conexant, Skyworks and Old Models | 8 | 06-02-2005 14:33 |
Please help! How to open MC922 Call-ID? | ooifk | Infineon C16X M51 & ARM7 M52 BASED | 2 | 10-28-2001 05:58 |
