11-11-2002, 06:18 | #1 (permalink) |
Freak Poster Join Date: Oct 2002 Location: www.tapgsm.com.ph/forum Age: 48
Member: 16768 Status: Offline Sonork: 1583568 Thanks Meter: 37 | 8210 no power |
11-12-2002, 18:58 | #3 (permalink) |
Member: 16768 Status: Offline Sonork: 1583568 Thanks Meter: 37 | @debeliamark,ive already checked d power button all are good.anyway thanks 4 reply man,can somebody still offer a help regarding my 8210 fon? |
11-16-2002, 15:48 | #4 (permalink) |
Crazy Poster Join Date: Jul 2002 Location: on the earth Age: 52
Member: 13425 Status: Offline Thanks Meter: 0 | 8210 It is coming from the power on button, it seems ok but it is not !!! Just test like this : Power button _ - - 1-- | | --2 3-- | | --4 ---- 1 2 3 4 are soldering point just connect 1 & 3 you will turn on your phone without using a power button. If it is working your power button it damaged not dead just damaged but sometimes you'll have to change it. |
11-18-2002, 19:11 | #5 (permalink) |
No Life Poster Join Date: Sep 2001 Location: Palestine-Iraq-Afghanistan.... Age: 25
Member: 6478 Status: Offline Thanks Meter: 3 | check the battery conector( internal) as this f u c k i n ****ty NOKIA fones the conector springy clip contacts bend & touch the ****ty sheilding-so bend them so they dont contact the sheilding when reassembled. p.s excuse my very poor english |
11-12-2003, 15:34 | #6 (permalink) |
Junior Member Join Date: Aug 2003 Location: Maharashtra - India Age: 49
Member: 37360 Status: Offline Thanks Meter: 0 | 8210 shows charging but doesen't switch on hi! i have the same problem too. I tried changing 2-3 switches, checked broken tracks and also cheked resistance connected to the CCOUNT line, every thing is OK. I'm confused? does anybody have the solution? BTW I need url for 8210 service manual and also photo copy of PCB may help. Thnx in advance |
11-20-2003, 05:57 | #7 (permalink) |
Insane Poster Join Date: Nov 2003
Member: 44386 Status: Offline Thanks Meter: 0 | hi there ,below power swicth there have a small resister without this it cant power on b4 u remove it u better move out ur power switch try it.if still cant reflow ccont ic .those crysstal ic also will effect the set cant power.good luck |
solution on 8210 no power but charging and flashing due to water damaged!!!!!! | andrew14 | Nokia Hardware & Hardware Repair | 0 | 02-02-2005 03:20 |
8210 no power when batt operated | aboveconnection | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 03-18-2003 05:24 |
8210 no power problem | feverdj | Nokia Hardware & Hardware Repair | 6 | 08-30-2002 17:33 |
nokia 6210 charging all the time and 8210 no power on | emmibox | Nokia Hardware & Hardware Repair | 0 | 08-30-2001 05:46 |
8210 no power | CellM@n | Nokia Hardware & Hardware Repair | 5 | 07-13-2001 07:28 |
