04-05-2002, 09:02 | #1 (permalink) |
No Life Poster Join Date: Jun 2001 Location: London Age: 41
Member: 5006 Status: Offline Thanks Meter: 2 | HARDWARE CONTACT SERVICE (solution) Thanks in advance. |
04-05-2002, 22:10 | #2 (permalink) |
Junior Member Join Date: Mar 2002
Member: 10338 Status: Offline Thanks Meter: 0 | first check it with eeprom tools if it sayes mcu check sum test failed then this is unrepairable if any thing else than just heat the ccont and cobba to the point where the solder melts but dont touch it what so ever try to add some flux or paste while heating note that u need an a smd rework station |
04-06-2002, 09:07 | #3 (permalink) | |
No Life Poster Join Date: Aug 2008 Age: 52
Member: 1841 Status: Offline Thanks Meter: 469 | @NAS: Quote:
just try to reflash the MCU, sometimes more erase-cycles are necessary, but if the flash IC is not completely damaged, you may succeed. | |
04-06-2002, 10:35 | #5 (permalink) |
No Life Poster Join Date: Dec 2001 Location: USA Age: 45
Member: 8051 Status: Offline Thanks Meter: 6 | hanoon© sure ur solution will be with wintesla...u must learn where is ur faulty part in ur phone however its software or hardware.... if its hardware it will be in Ccont or Cobba ,,u must first try to rehot them with good liquid flux then its will be ok to repace faulty part if no sucess,,,,,, good luck! |
04-06-2002, 16:32 | #6 (permalink) |
No Life Poster Join Date: Jul 2001 Location: RP Age: 48
Member: 5246 Status: Offline Thanks Meter: 9 | CS might be due to: CCONT interface COBBA: -serial interface -parallel interface MCU Checksum PPM Checksum Eprom tune checksum CCONT, COBBA failure just reflow using hot air rework station. MCU, PPM, and EEPROM tune just flash with corresponding flash files. Then recalculate faids, or splocks |
04-07-2002, 05:10 | #8 (permalink) | |
Freak Poster Join Date: Mar 2002 Location: morocco Age: 49
Member: 10288 Status: Offline Thanks Meter: 16 | nokia cs solution Quote:
04-07-2002, 23:13 | #9 (permalink) |
Freak Poster Join Date: Nov 2001 Location: Omsk, Russia Age: 41
Member: 7337 Status: Offline Thanks Meter: 0 | Help! Hi all! I have 8250 in Contact service. When I'm reading it by M-Bus with NokiaTool it shows: MCU SW: V 3.18.03-04-01.NSM-3D.(c) NMP. IMEI: 000000000000000 Original IMEI: 656565656565656 All locks are closed with FF. I've made one 8210 with similar problem by flashing eeprom area from working phone and updating FAID. But I can't flash this 8250! I think F-Bus on phone isn't working... So what parts should I check or rehot? |
04-08-2002, 01:12 | #10 (permalink) |
Member: 5246 Status: Offline Thanks Meter: 9 | Its possible that the Flash ID of your phone is 08988c2, in this case you will need 956 bytes boot.bin and 6.09KB f_loader for use with Dejan 1.00. Alternatively, you may use Rolis 4.77. Just select your mobile model, and ignore "mobile choosing wrong" message box. It will flash the eprom area of your phone. |
11-29-2002, 15:06 | #11 (permalink) | |
Crazy Poster Join Date: Aug 2002 Location: Belarus, Vitebsk Age: 47
Member: 15045 Status: Offline Thanks Meter: 5 | Quote:
MCU Eeprom Interface - Failed Eeprom Tune Checksum - Failed After calculation of FAID and eeprom checksum still Contact Service. It can't be flashed... Unknown flash ID... Any comments? | |
11-29-2002, 15:46 | #12 (permalink) |
No Life Poster Join Date: Apr 2002 Location: Radiometer Medical ApSBrønshøj Age: 51
Member: 10854 Status: Offline Sonork: 1578988 Thanks Meter: 3 | Hiya If u have message: flash type unknovn then is 95 % that flash is phisically damaged or bad soldered. Try to resolder flash or change it. There is 2 type of CS: - software ( phone powers itself, reset and show CS ; phone powers itself, reset, show insert simcard, then reset again and show CS ) - hardware ( phone powered, lights only then CS; no reset at all ) For software - reflash mcu, ppm, eeprom and pmm, recalculate checksums, restore imei and ur phone working. For hardware: cobba, flash or eeprom ( if present physically) can be bad soldered or damaged. Sometimes ccont also can be cause for this. Also there can be other reasons like broken lines on pcb but this is rare case. BR Vule |
03-21-2003, 16:57 | #13 (permalink) |
No Life Poster Join Date: Apr 2002 Location: West Midlands, UK
Member: 11099 Status: Offline Thanks Meter: 5 | I also have an 8850 CS reason eeprom checksu, failed. Flashed it, but still CS. Can not get the phone to communicate with eeprom tools ? phone not connected Anyone help |
03-22-2003, 13:16 | #14 (permalink) |
No Life Poster Join Date: Jun 2001 Location: Uranus Age: 53
Member: 5072 Status: Offline Thanks Meter: 91 | In my experience ....If the "contact service " cannot be reapaired through software by flashing the set....then the Audio IC (COBBA) should be replaced..... this is what we do in our workshops and the problem is solved.After replacing COBBA just calculate FAID...and unlock Please try and post results here. Rgds |
1110/1112/i/1600/2310/2610/6030 & Many More Contact Service Hardware Solution | danish_aziz18 | Nokia Hardware & Hardware Repair | 71 | 10-10-2014 09:11 |
Software or Hardware? contact service | Mang mel | Nokia Base Band 5 ( BB-5 ) | 3 | 05-06-2009 06:13 |
1600 hardware contact service problem | rajdodani | Nokia Hardware & Hardware Repair | 5 | 01-22-2009 10:04 |
65656565 funny IMEI,with Contact Service on Screen, is it Hardware or software Problm | AboAli | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 23 | 10-13-2002 15:00 |
hardware 8310 contact service | trafix | Nokia Hardware & Hardware Repair | 3 | 08-24-2002 10:02 |
