Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Nokia > Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L )
Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) Nokia Legacy Models Like 1011, 1610, 211x, 2x20, 6050, 3110, 8110, NKxxx , 2100, 3210, 3310, 3330, 3410, 5110, 5210, 5510, 6110, 6150, 6210, 6250, 7110, 8210, 8250, 8850 also 9110 & 9210
Old 12-31-2000, 09:12   #1 (permalink)
ChM
Member: 1326
Unhappy Help with EEPROM reading needed
Hi all,
I've tried to make a backup copy of EEPROM in my Nokia 5110 v 05.29 and I wasn't success
Please correct me if I'm wrong:
I disassembled phone (front cover&keys, then 4 screws from the back, white peace with speaker) and EEPROM chip is located in left upon display (looking normaly to phone). It's only one IC which has 8 pins (and - it has shorted 4 pins on upper side of IC, therefore I think it's 24C16).
And then I'd connect Ponny SI API I2C (schema is on ponnyprog www and I verified it on some 24C16) directly to the pins on board solded EEPROM. First I've tried to measure pin 8 if it has proper voltage when phone is on. It was near 3.75V (battery wasn't full charged) so I jugged that pinout of 24C16 is:
4 3 2 1
_______
_______
5 6 7 8
(still looking "normaly" to disassembled phone)
I've tried to run ponnyprog and read EEPROM but it tells "device not responding". Then I'd tried to connect external power of 4V to pin 8 of 24C16 but still "device not responding"
May be I have bad scheme for EEPROM reading, I've no idea if my scheme supports in-circuit connection of 24C16, can anyone help me?
I don't wanna destroy my phone while playing with unlocking, so I badly need backup....
P.S.: May be someone will gimme advice to desolder EEPROM and then read it. But it looks very hard to desolder it and also IC chip hasn't any mark of pin layout - it's very small to make my own and how should I recognize then pinout?
P.P.S: My phone is still working after all I did with its
Old 01-01-2001, 03:13   #2 (permalink)
Member: 2769
Post
Hello, I have the same problem but i'm trying to read 24c256 to no avail, because its says "device not responding". I'm using the PONYPROG SI v.2.2 with I2C Bus Adapter. I just bought it thru lancos. I think this hardware interface has a problem or error. Anybody who can help us?
Old 01-01-2001, 10:28   #3 (permalink)
Josif&R
Guest
Posts: n/a
Member:
Hello
PonyPro funkcional full only on parallel \LPT\ ports with adapter "Easy I2CBus" and external +v. Tested 16-512. If this not work for you must wiev and corect your ponyprog.ini in directory PonyProg.
Old 01-01-2001, 13:38   #4 (permalink)
lotfi17's Avatar
Member: 2616
Thanks Meter: 6
Post
I suggess that you bay a very simple eeprom
reader writer wich you can find allmost every
where in net, I use my old ludipio eeprom and
pic reader it cost around 40-50$, just search
like:eeprom reader. Anyway I know that the pinout of the 24cXX (nokia 61xx 24c64) are
like this: back side
ground <---1- -8- Vcc
ground <---2- -7- NC
ground <---3- -6- Scl
ground <---4- -5- Sda
Use any version of ponyprog, I use old version it works with less problems for both
Com and Lpt ports, and experienced that ponyprog works as well on com ports.
Regards.
[This message has been edited by lotfi17 (edited 01 January 2001).]
Old 01-01-2001, 16:28   #5 (permalink)
ChM
Member: 1326
Exclamation
At first I must say that my interface *works*. I've tried it on new 24C16 eeprom which I was buy. But it wasn't connected to the circuit, therefore I'm asking. When I connect my interface to the phone it doesn't worked for me.
lotfi17: some time ago I was used ludipipo interface to read some eeproms, but now I though that it's better to use ponnyprog interface. But OK, if I understand well ludipipo is working with eeproms connected in circuits for you. I'll try it.
But I also fear that when I connect power to eeprom solded in phone I'll damage the phone. Phone has 3.6V battery and all eeprom readers has power about 5V. What about this? Is it safe to connect 5V to the eeprom on the board?
Old 01-01-2001, 22:14   #6 (permalink)
ARS
Member: 2721
Thanks Meter: 23
Post
Try to desolder pin 5,6 of eeprom and conect the programer.
Old 01-02-2001, 00:37   #7 (permalink)
Member: 1551
Unhappy
Hello, is it safe to use 5v ext. power on at24c256. i'm using the serial interface of ponyprog si. and also I already desolder the eeprom from the fone but when I read it say Device not connected. what does it mean? My computer is a 733mhz P3. does this make any difference? thanks
Old 01-02-2001, 18:16   #8 (permalink)
ChM
Member: 1326
Exclamation
ARS: it's very hard to desolder this small piece of ****! But it's more harder to sold it back!
All: Is it really safe to use 5V power for reading de-solded eeprom?! Phone is using 3.3V technology, I'm not sure...
Old 01-02-2001, 19:11   #9 (permalink)
Member: 318
Post
100% safe for these 24CXX.
sometime you'll need to dessolder pin 5 and/or pin 6 , when you get " device not responding".
You must ensure that you have ~5V at pin 8, if not , dessolder pin 8 too.
1|[]----|8--->to vcc=5v
2| |7--->to GND
3| |6
4|______|5
Old 01-02-2001, 20:47   #10 (permalink)
Member: 2415
Post
Hi,
I always desoldered all pins of 24Cxxx to
read and repair content, and always
successfully.
100%
br,
bone
Old 01-02-2001, 21:40   #11 (permalink)
ARS
Member: 2721
Thanks Meter: 23
Post
Is not problem to desolder/solder eeprom. You just need the right tools and some experience. You can try it on another ICs from totaly death phones. I ever desolder eeprom from phone and i use too 5 volt power suply.
Old 01-03-2001, 14:08   #12 (permalink)
Member: 2769
Hi Baypierre,
Just want to clarify.
desolder the eeprom from the fone, connect pin 4 to pin 4 of the reader (ground)
pin 5 to pin 5 of the reader
pin 6 to pin 6 of the reader
pin 7 to pin 1-4 of the reader (ground)
pin 8 to Vcc 5v
and read
Can anyone help with eeprom for D600 Ramik UST Pro II 0 07-22-2008 04:39
Need Help with Eeprom problem on N600 sed_alex VLSI, Conexant, Skyworks and Old Models 2 12-15-2003 19:50
help r210 eeprom read Blueman1 VLSI, Conexant, Skyworks and Old Models 2 07-25-2003 14:31
Need Help With Eeproms/flash cyrus_ss Sony Ericsson 0 07-08-2003 17:23
help with eeprom 24C32 gsmflash Various 1 08-16-2000 18:03
Page generated in 0.18776 seconds with 9 queries
