02-15-2006, 19:42 | #1 (permalink) |
Junior Member Join Date: Feb 2006
Member: 232178 Status: Offline Thanks Meter: 5 | Nokia 2100 Contact Service Problem Today I flash Nokia 2100 today and after successful flashing,a message appeared on the phone's screen"contact service".I flash it again but the problem was same.What is the solution of this problem?I shall be very thankful to you if u may help me. Sultan |
The Following 5 Users Say Thank You to sultanpk For This Useful Post: |
02-18-2006, 11:27 | #4 (permalink) | |
Member deceased !! Join Date: Jan 2006 Location: INDIA Age: 40
Member: 226535 Status: Offline Thanks Meter: 7 | may be hardware problem Quote:
if you have flashed it the correct way and still getting the same problem, try to change or reboll the COBBA if not then FLASH IC. Flash again. | |
02-24-2006, 12:34 | #6 (permalink) | |
No Life Poster Join Date: Aug 2005 Location: Treasure Island of the pacific
Member: 168090 Status: Offline Thanks Meter: 92 | Quote:
Coz mostly N2100 contact service problem can't be repaired by Sarasoft boxes..e.g. twister, powerflasher,tornado,UFS,.. try to use flasher that is developed by Dejan, nutzo, nasiriyan or rolis... then after flashing don't forget to change it's IMEI by program developed by Rolis.. that is rolis tool v1.8...change IMEI the update FAID.. This works 100% i'm sure of it... BR.. | |
02-27-2006, 12:42 | #8 (permalink) |
Member: 226535 Status: Offline Thanks Meter: 7 | Hi friend If you are getting contact service after flashing, now only thing you have to do is 1. read info if you find in info cobba numbers 0000000 that is cobba problem and also check in the same info if imei number net & osn should be the same if you have anything like blank or full zeros try to rewrite imei number if it is not possible change flash ic your problem will be solved |
03-10-2006, 15:05 | #10 (permalink) | |
No Life Poster Join Date: Apr 2004 Location: nagaur raj Age: 57
Member: 62820 Status: Offline Thanks Meter: 175 | 2100 contec service solution Quote:
now rebuild ime auto | |
The Following 4 Users Say Thank You to shantilal For This Useful Post: |
03-10-2006, 18:09 | #11 (permalink) | |
No Life Poster Join Date: Sep 2005 Location: Uttaranchal Age: 35
Member: 181696 Status: Offline Sonork: 100.107830 Thanks Meter: 5,406 | Quote:
Try to rebuild IMEI... if not ok then change cobba Last edited by ..::ArchitRaj::..; 03-07-2007 at 19:11. | |
03-28-2006, 18:07 | #12 (permalink) | |
Freak Poster Join Date: Jul 2004 Location: always around
Member: 74338 Status: Offline Thanks Meter: 11 | Quote:
please, give a try and post result. good luck to you. regards. dennis1 | |
03-28-2006, 18:08 | #13 (permalink) |
Member: 74338 Status: Offline Thanks Meter: 11 | just like what shantilal gave to you, flash with the pm file. you must no that the imei will be ?????????????????. that means you must rebuild imei and do full UI SETTINGS. if it does not correct it, use any nok eeprom tools (rolis) to rebuild imei, set faid, reset software. please, give a try and post result. good luck to you. regards. dennis1 |
nokia 2100 contact service --still problem after flash--- | crossings | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 49 | 11-11-2007 17:06 |
help nokia 2100 contact service | ramoon20 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 10-29-2004 06:52 |
nokia 2100 - contact service | imran_k | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 7 | 10-23-2004 11:06 |
Nokia 2100 contact service | Natali | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 7 | 09-03-2004 08:24 |
Nokia 2100 Contact service | thunoy | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 09-10-2003 09:46 |
