Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Saras Boxes > HWK
Old 05-15-2017, 11:19   #1 (permalink)
Crazy Poster
Member: 40299
Thanks Meter: 3
UFS HWK death suddenly
Hello
I write this post a second time. Earllier was delete.
When I want use box in UFSx (HWK) Control Panel v 2.3.0.7 i get this info:
Check Box:
App: UFSx (HWK) Control Panel v 2.3.0.7 by SarasSoft
Ftd: Ufs2xx.dll 3.2.7, Ufs2xx.sys 2.8.30
Box: 1 Location: 82 Serial: 78217
Boot Id: 62 CF
Box Login Failed
Bad IX: ABCD
Failed: -102
HID Number Corrupted, Try to Use [Update Box]
Update Box:
Boot Id: 62 CF
Box Login Failed
Fatal LOGIN Error, Need Repair Box, Contact Distributor
Box is oryginal product, I have it from 7-8 years. There was no problem with him until now. Please, guess what I have to do with him to raise him.
Old 05-15-2017, 19:21   #2 (permalink)
Odia The Ultimate's Avatar
Member: 4042
Thanks Meter: 24,043
http://forum.gsmhosting.com/vbb/f311...-help-2224086/
The Following 2 Users Say Thank You to Odia The Ultimate For This Useful Post:
Old 05-16-2017, 07:52   #3 (permalink)
Crazy Poster
Member: 40299
Thanks Meter: 3
Thanks Odia for you answer. I resolder all of component on ufs pcb and HWK pcb and letter clean all from flux and dry. But nothing change.
I thought this is a server error with my box not working and not a hardware malfunction.
But if you say this is a bug on the box then I'm going to look for a pcb vulnerability. Thanks for You help.
Old 05-28-2017, 07:02   #4 (permalink)
khangsm786's Avatar
Member: 1196610
Thanks Meter: 34
Originally Posted by Odia The Ultimate View Post
do you have any successful perfect solution or just simply posting links
Old 05-28-2017, 22:48   #5 (permalink)
Member: 4042
SERVER STATUS - USE Panel V 2.3.0.7 - Upgrade/Installation/Support Server Problems - Page 69 - GSM-Forum
The Following User Says Thank You to Odia The Ultimate For This Useful Post:
Old 06-02-2017, 05:12   #6 (permalink)
Member: 2255200
Thanks Meter: 9
sir ji give me correct solution
my ufst box working well but last ten days ufst box not started always box login failed here is screen log
Box: 1 Location: 1127010 Serial: TMA10845004
Boot Id: 54 4D
Box Login Failed
Bad IX: ABCD
Failed: -102
Old 06-02-2017, 05:17   #7 (permalink)
Member: 2255200
Thanks Meter: 9
box login failed pls help ufst team urgent help
Boot Id: 54 4D
Box Login Failed
Bad IX: ABCD
Failed: -102
Old 06-02-2017, 18:48   #8 (permalink)
Member: 2721051
Thanks Meter: 5
ufs dead.................
Page generated in 0.20810 seconds with 8 queries
