Old 09-05-2009, 07:17   #1 (permalink)
Member: 1108823
Thanks Meter: 20
1110 display
respected members 1110 mobile water damage all is ok but no display,incoming outgoing ok,but set is not off by power key,i wash the set,heat cpu but same,sir please help
Old 09-05-2009, 07:29   #2 (permalink)
Member: 617666
Sonork: 100.1592356
Thanks Meter: 397
try to change display
if not ok then full flash
write good pm
your problem solve
Old 09-05-2009, 07:43   #3 (permalink)
Member: 1108823
Thanks Meter: 20
i changed 3 display,flash set 6.40v,write pm,ui setting,but not good result,sir what can i do in hardware?
Old 09-05-2009, 07:50   #4 (permalink)
Member: 527467
[QUOTE=gangadhar121212;4814819]respected members 1110 mobile water damage all is ok but no display,incoming outgoing ok,but set is not off by power key,i wash the set,heat cpu but same,sir please help[/QUOTE change lcd connector if same then must be any track of lcd is missing try to find the missing track
Old 09-05-2009, 09:34   #5 (permalink)
chamak-liton's Avatar
Member: 735673
Thanks Meter: 3,101
01 - try this display connector.
02 - rehot cpu.
post reply
The Following User Says Thank You to chamak-liton For This Useful Post:
Old 09-05-2009, 09:47   #6 (permalink)
Member: 1079496
Sonork: kumaran7730
Thanks Meter: 2
change to display connecter your problem solved
Old 09-05-2009, 09:49   #7 (permalink)
Member: 1079496
Sonork: kumaran7730
Thanks Meter: 2
change to display connector your problem solvteed
Old 09-05-2009, 09:59   #8 (permalink)
Member: 1079496
Sonork: kumaran7730
Thanks Meter: 2
check the display connector track
Old 09-05-2009, 11:07   #9 (permalink)
Member: 997427
Sonork: 100.1590909
Thanks Meter: 26
rehot cpu.
post reply
Nokia 1110 Display Problem zubairok Nokia Hardware & Hardware Repair 13 06-19-2012 16:14
nokia 1110 displaying nokia after on de brain box Nokia Hardware & Hardware Repair 13 08-26-2010 07:38
1110 display back light ok. but not display letter john80 Nokia Hardware & Hardware Repair 2 12-22-2008 14:39
Nokia 1110 display service info in standby pitone02 Nokia Digital Core Technology 4 ( DCT-4 ) 3 06-23-2008 18:44
1110 display problem after flashing!!! ionelka Twisterflasher 14 07-20-2006 13:04
Page generated in 0.19965 seconds with 9 queries
