10-07-2006, 13:30 | #1 (permalink) |
No Life Poster Join Date: Jun 2006 Location: UK
Member: 294200 Status: Offline Sonork: 100.1586184 Thanks Meter: 658 | Nokia 1110 Display Problem |
The Following 3 Users Say Thank You to zubairok For This Useful Post: |
06-01-2007, 15:46 | #2 (permalink) |
Insane Poster Join Date: Oct 2006
Member: 363878 Status: Offline Thanks Meter: 61 | solve this problem event some case. you can got idea nokia 1110 some one broken lcd. i chang new one is lcd 1110i but is show only nokia and boot on ok. but display is strang can't read. call and received call ok. first time i check all line socket and second i think software problem but it all wrong way. i try to flash ufs with 1110i/1112 version but phone got "contact service" ... i have to use flash with nokia 1110 same real type of phone. it ok. and i use with lcd nokia 1600 to test it agian this play all ok. This case i think this display upon version. and display must compatible your phone .. (i ever use lcd nokia 1110i with 1110 phone it ok but not for all case) |
The Following 3 Users Say Thank You to lsurasak For This Useful Post: |
07-21-2007, 11:53 | #3 (permalink) |
Freak Poster Join Date: Sep 2006 Location: INDIA Age: 48
Member: 350948 Status: Offline Thanks Meter: 32 | N 1110 Rh93 display problem (after flash) I have got solution for this problem.I just flash with latest version RH93Ver 6.41.Using JAf & problem solved .. Try & post here...Also threr is no need to change display.If not damaged.... |
The Following 4 Users Say Thank You to shritelmob For This Useful Post: |
07-21-2007, 15:31 | #4 (permalink) | |
No Life Poster Join Date: Apr 2006 Location: Fast-Code™ MBKPHONE Ltd Age: 38
Member: 269035 Status: Offline Sonork: 1,618,0786 Thanks Meter: 301 | Quote:
Or Flash wiz nokia 1600 Flash File (RH-64-dp_v_26_01_MCUSW6_00) + change lcd, put 1600 lcd ur phone is nw nokia 1600!!!!!!!!!!!!!!!!!! | |
The Following 3 Users Say Thank You to khem For This Useful Post: |
07-21-2007, 15:50 | #5 (permalink) |
No Life Poster Join Date: Jun 2005 Location: Punjab , INDIA
Member: 153805 Status: Offline Thanks Meter: 325 | atach to jaf and see info and see display type there.and flash with latest version. |
The Following User Says Thank You to baldev For This Useful Post: |
01-17-2008, 08:33 | #8 (permalink) |
Junior Member Join Date: Jun 2006
Member: 289014 Status: Offline Thanks Meter: 1 | Nokia 1112 display prblem event some case. you can got idea nokia 1110 some one broken lcd. i chang new one is lcd 1110i but is show only nokia and boot on ok. but display is strang can't read. call and received call ok. first time i check all line socket and second i think software problem but it all wrong way. i try to flash ufs with 1110i/1112 version but phone got "contact service" ... i have to use flash with nokia 1110 same real type of phone. it ok. and i use with lcd nokia 1600 to test it agian this play all ok. This case i think this display upon version. and display must compatible your phone .. (i ever use lcd nokia 1110i with 1110 phone it ok but not for all case) not okkkkkkkkkkkkkk |
The Following User Says Thank You to waqar1985 For This Useful Post: |
03-26-2008, 12:42 | #9 (permalink) |
Junior Member Join Date: Jun 2006 Location: kuala lumpur Age: 40
Member: 290127 Status: Offline Thanks Meter: 1 | hi bro i have sony ericssion w610i problem is cannot on pls any body tel me the solution |
The Following User Says Thank You to srjhtech For This Useful Post: |
03-26-2008, 13:08 | #10 (permalink) |
Freak Poster Join Date: Sep 2003 Location: tunisia Age: 46
Member: 39239 Status: Offline Thanks Meter: 97 | |
The Following User Says Thank You to riadhset For This Useful Post: |
06-19-2012, 15:30 | #13 (permalink) |
Banned Join Date: Aug 2009 Location: Cheyyar Age: 40
Member: 1103371 Status: Offline Thanks Meter: 19 | nokia 1600 lcd jumper nokia 1600 lcd jumper Welcome to Cell Dial |
nokia 1110 displaying nokia after on | de brain box | Nokia Hardware & Hardware Repair | 13 | 08-26-2010 07:38 |
nokia 1110 display | fast2pk | Nokia Hardware & Hardware Repair | 13 | 09-09-2009 12:33 |
nokia 1110 display problem | nitinkansara | Nokia Hardware & Hardware Repair | 5 | 10-31-2008 11:37 |
nokia 1110 display problem | vinkle | Nokia Hardware & Hardware Repair | 2 | 09-12-2008 16:55 |
Nokia 1110 display service info in standby | pitone02 | Nokia Digital Core Technology 4 ( DCT-4 ) | 3 | 06-23-2008 18:44 |
