Old 08-21-2008, 15:46   #1 (permalink)
farshad2009's Avatar
Member: 716976
Sonork: 100.1674578
Thanks Meter: 108
1200 contect service
Hello sir i have 1200 mobile display show contect service plz any body help me
Old 08-21-2008, 15:51   #2 (permalink)
shaikh_zubin's Avatar
Member: 461699
Thanks Meter: 80
flash with good file and reply
Old 08-21-2008, 17:15   #3 (permalink)
amol_sm's Avatar
Member: 343326
Thanks Meter: 1,463
Full flash the phone with latest firmware.
And finnaly just unlock u r phone via JAF.
If still problem same try to change the LCD.
Post result.
Old 08-21-2008, 17:25   #4 (permalink)
sunnyarora's Avatar
Member: 483406
Thanks Meter: 180
Full Erase Than Flash Write Good P.m. And Unlock With H.w.k Its Solve 100%
Other Solution Change Lcd
Old 08-21-2008, 17:36   #5 (permalink)
Shohel_sst's Avatar
Member: 577653
Thanks Meter: 235
Contact service solution
1st:Full erase
2nd:flash with 5.23
3rd:wr good pm
4th:unlock with jaf then full ul setting
The Following 4 Users Say Thank You to Shohel_sst For This Useful Post:
Old 08-21-2008, 18:34   #6 (permalink)
Member: 836137
Thanks Meter: 28
1200 contact service
just heat to back side in power ic
your problem will be solve
Old 08-22-2008, 04:25   #7 (permalink)
Member: 671345
Thanks Meter: 7
try flash with ubox write good pm and unlock..have tried it..
Old 04-27-2009, 09:01   #8 (permalink)
Member: 550615
Thanks Meter: 37
full erase the and flash dnot write pm set still contect service u are wrong
Old 04-27-2009, 09:37   #9 (permalink)
cel_phon's Avatar
Member: 950201
Thanks Meter: 1,928
1. flash phone
2. good PM
3. unlock
if contact service still persist
then its ur 100% LCD problem
if u have HWK u can check ur LCD with the option '' SELF TEST '
Old 04-27-2009, 19:19   #10 (permalink)
Member: 995100
Thanks Meter: 4
Flash with ufs box after check display 100 percent
Old 04-28-2009, 08:14   #11 (permalink)
gsmcrazy1's Avatar
Member: 897524
Sonork: 100,1609543
Thanks Meter: 172
1 erasae full flash
2 flash
3 write pm
4 unlock
5 factory setting
i hope your problem ll solve
Old 04-28-2009, 17:44   #12 (permalink)
Member: 667962
Red face
heat the cpu ic
Old 04-28-2009, 19:30   #13 (permalink)
azez.sd's Avatar
Member: 735523
Sonork: 100.1591830
Thanks Meter: 262
1200 contect service Mohsin-* Nokia Hardware & Hardware Repair 24 05-28-2009 14:07
1200 contect service after changing lcd SARFUDINJ Nokia Hardware & Hardware Repair 6 07-19-2008 11:50
Page generated in 0.21033 seconds with 10 queries
