Old 10-09-2007, 19:50   #1 (permalink)
Member: 174853
Thanks Meter: 84
N70 LCD EMIF Z4403 line broken
hi...
dear Sirs,
i have accidentally make the EMIF Z4403 line broken when trying to make it clean from left off lead, before applying new EMIF.... there is suppossed to be 25 dots representing the line
Now i have lost dots no 09 and 19, according to the EMIF diagram here...
does anyone know how to make jumper for the broken line?
i will very gratefull for your help,
thanks in advance
Old 10-09-2007, 22:17   #2 (permalink)
Member: 290384
practically its impossible to connect the track to OMAP.
Old 10-10-2007, 08:58   #3 (permalink)
Member: 174853
Thanks Meter: 84
is there any test point left on the board to jumper on?
Old 10-10-2007, 12:33   #4 (permalink)
mobilagy's Avatar
Member: 217479
Thanks Meter: 267
Man, just mount the new filters that you were doing & then give it a try & i'm bit sure it will work; there's a lot free pins with these filters & it's which mostly gets off board, just give it a try & you will not regret, i have faced such same problems & was as i told, B.R ...
Old 10-22-2007, 14:33   #5 (permalink)
Member: 174853
Thanks Meter: 84
i already try mounting the new filters but there were still no good display on LCD....
please anyone who have encounter the same problem give advice
thanks mate
Old 10-22-2007, 15:12   #6 (permalink)
quickgsm's Avatar
Member: 414755
Sonork: quickgsm
Thanks Meter: 389
Originally Posted by virtue View Post
hi...
dear Sirs,
thanks in advance
Good work thx for sharing !!!!!!!!!!!!!!!!!!!!!!!!!!!
br taoufik
Old 10-22-2007, 17:12   #7 (permalink)
Registered User
Member: 483748
Thanks Meter: 47
hi...
dear Sirs,
thanks in advance
ACCORDING TO MY KNOWLEDGE THESE TWO DOTS ARE NC .FIX A NEW ONE EMI UR PROBLEM WILL BE SOLVE & BE ALWAYS CONFIDENT IN UR WORK.POSSIBILITY DURING REMOVING & REFIXING Z4403 SOME DAMAGE OCCURED IN Z4402.NOW U HAVE TO CHANGE BOTH FILTERS.
Old 10-22-2007, 17:54   #8 (permalink)
reji's Avatar
Member: 227127
Thanks Meter: 241
no bro,
in both of the ic's these pins have connection.
Old 10-22-2007, 22:23   #9 (permalink)
r a nadeem's Avatar
Member: 241039
Thanks Meter: 4,170
dear in Z4403 pin 09-19 are empty , so change the both filters , prob will be solve
rashid
Old 10-22-2007, 22:26   #10 (permalink)
r a nadeem's Avatar
Member: 241039
Thanks Meter: 4,170
br taoufik
dear read carefully before posting anything . thanks for what ? he has prob , he want help , you are say thanks.
rashid
Old 10-23-2007, 14:32   #11 (permalink)
reji's Avatar
Member: 227127
Thanks Meter: 241
rashid
bro,
in Z4402 and Z4403 the pins 9 and 19 have connections
The Following User Says Thank You to reji For This Useful Post:
Old 10-23-2007, 20:18   #12 (permalink)
r a nadeem's Avatar
Member: 241039
Thanks Meter: 4,170
Originally Posted by reji View Post
bro,
dear reji
i know you have knowledge , and appreciate your work , but read schematic. that is empty point i think , second we are only discussing , plz don't mind it . coz members want share with us . may this way they gain something. 3rd i did not criticized negatively . plz keep in mind
rashid
Old 10-25-2007, 20:28   #13 (permalink)
Registered User
Member: 483748
Thanks Meter: 47
bro,
IT IS 7TH PRINT WHICH U SHOWN IN PIC
BE SENSIBLE, READ CAREFULLY SCHEMATIC U WILL FIND GOOD RESULT .IF U R NOT SATISFY WITH SCHEMATIC THEN U CAN CHECK IT BY URSELF BY REMOVUNG BOTH IC'S FROM THE BOARD AND THEN CHECK THE CONTINUITY FROM DISPLAY IC PRINTS TO THE DISPLAY CONNECTER .IF U FIND ANY CONNECTIVITY THEN POST UR RESULT HERE OTHERWISE CHECK BEFORE POSTING .HOPE U TAKE IT AS A POSTIVE .
a little ADVICE to a member means a BIG HELP to them...
Old 10-26-2007, 13:46   #14 (permalink)
reji's Avatar
Member: 227127
Thanks Meter: 241
i checked many times, two diiferent boards,
i got this
The Following 3 Users Say Thank You to reji For This Useful Post:
Old 10-26-2007, 15:02   #15 (permalink)
Registered User
Member: 483748
Thanks Meter: 47
ok, checking procedure is correct but ur counting trick is wrong.we count it left to right.
n70 display ic z4403 need help alvine281 Nokia Hardware & Hardware Repair 1 11-29-2008 07:02
N70 key emif line broken alpin Nokia Hardware & Hardware Repair 2 10-29-2007 03:21
UEM line broken fontelense Nokia Hardware & Hardware Repair 0 06-15-2006 05:03
V360 Line Broken with TestPoint ZezualMatrix Smart-Clip 0 02-17-2006 12:40
Samsung 2200 data line broken Bigbrothers2000 Various 1 01-10-2000 22:58
Page generated in 0.24100 seconds with 10 queries
