Old 04-24-2010, 13:43   #1 (permalink)
>>PakFones<<'s Avatar
Member: 553178
Sonork: 100.1592454
Thanks Meter: 957
1208 backlights always on and also auto keyguard working.
Hi to all can someone help me in 1208 key guard and back light problem.
(1)
1208 backlights always on and when i do off from setting thats are working but on normal not auto off.
(2)
auto keyguard not working but on pressing menu+* keypad lock working.
i think it is S/W problem but after full erase and flash and written pm with JAF and mx key same condition.
and after this i have cleaned with ctc and after this same condition.
plz advise me how can i solve this?
Old 04-24-2010, 13:56   #2 (permalink)
>>PakFones<<'s Avatar
Member: 553178
Sonork: 100.1592454
Thanks Meter: 957
here is the phone info.
Version Info:
MCU SW version: V 5.91 27-03-09 RH-105 (c) NMP
HW version: 1602
UEM version: 1328
UPP version: 8850
RFIC version: 0700
DSP version: ICPR62_08w31_UPP
LCD version: TPO:NAXvD6 ST7628
PPM version: V 5.91 27-03-09 RH-105 (c) NMP IA
ADSP SW version: p V 5.91\n27-03-09\nRH-105\n(c) NMP\nia
Product Info:
Production serial number: DBN423924
Product code: 0549986
Module code: 0203484
Basic production code: 0515534
Serial Numbers:
IMEI plain: 358095019374352
IMEI spare to net: 3A 85 90 05 91 73 34 05
IMEI SV to net: 33 85 90 05 91 73 34 75 F0
Other Info:
CS type : GSM/DCS1800
BSI: 3.3 KOhm
Imei net: 35809501937435
Version: SIMLOCK SERVER
Provider: ALL Operator, Country: -
Counter: 0/3, 0/10
CONFIG_DATA: 0010100000000000
PROFILE_BITS: 000000000001000B
BLOCK 1: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 2: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 3: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 4: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 5: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 6: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 7: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
FULL FACTORY... OK
USER DATA... OK
LEAVE FACTORY... OK
SERVICE CENTER... OK
SOFTWARE UPGRADE... OK
PRODUCTION TUNING... OK
Reset User Code (to default:12345) ... OK
Completed in 3.890 s
Old 04-24-2010, 13:59   #3 (permalink)
ChandruChiyyan's Avatar
Member: 660093
Sonork: 100.1602344
Thanks Meter: 277
(1)
(2)
just change light ic and keypad ic ur problem will solved brother...........
100% hardware...................
Old 04-24-2010, 14:03   #4 (permalink)
>>PakFones<<'s Avatar
Member: 553178
Sonork: 100.1592454
Thanks Meter: 957
read my post carefully dear i have mentioned manualy both are working.
Old 04-25-2010, 04:45   #5 (permalink)
Member: 1289993
Sonork: pkbanik
please send picture solution.
Old 04-25-2010, 05:09   #6 (permalink)
suraj9860607689's Avatar
Member: 787710
Sonork: not using
Thanks Meter: 771
check phone is water lock...........
Old 04-25-2010, 05:19   #7 (permalink)
rajeshlehal's Avatar
Member: 666540
Thanks Meter: 354
I think u should flash ur phone, some times i solved it after flash I think should be ok after flash
Old 04-25-2010, 05:21   #8 (permalink)
Member: 513210
Thanks Meter: 110
clean usb connector or headset connetor.....
it may help your problem...
Old 04-25-2010, 08:09   #9 (permalink)
>>PakFones<<'s Avatar
Member: 553178
Sonork: 100.1592454
Thanks Meter: 957
dear i think you are trying to say easy cable connector. because usb not supported in these type of phone. i already said that i have cleaned it with ctc.
thanks any way for your comments.
6110 power does not stay on sc~micro Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 6 08-30-2014 08:14
IR between 6150 and IBM TP 600 favdijck Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 3 11-15-2011 13:08
how the **** do i make wintesla 6.03 work Ravetrancer Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 06-16-1999 08:41
wt603 and .pkd ARt Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 06-13-1999 19:18
Page generated in 0.25750 seconds with 9 queries
