01-13-2003, 12:30 | #1 (permalink) |
Freak Poster Join Date: Jun 2002 Location: North Pole
Member: 12869 Status: Offline Thanks Meter: 3 | 2 x 3310 with PA problem I changed PA 'cos it had no signal and now signal comes but after five seconds it disappears I know its not the PAs because I tested them on another phone and their working fine, what could be the problem does anyone know? |
01-13-2003, 13:20 | #2 (permalink) |
No Life Poster Join Date: Dec 2001 Location: United Arab Emirates, Dubai Age: 52
Member: 7751 Status: Offline Thanks Meter: 74 | @Black-Axe Had quite a few 3310 with this problem. Some of them have been solved by reflowing CCONT, or changing it, others the antenna switch. You can make a "bridge" on the antenna switch, to see if it's faulty, you'll find this info on gsmschwantz site. In my exsperience it's the CCONT which is faulty, when phone has signal for a few seconds. Others have solved it by changing HAGAR, and others again the COBBA. But as you'll find out theres so many variables in this "no signal" that not all can be mentioned here. Furthermore I suggest you read all the exellent posts by Moderator Willy, He have made alot post regarding No signal in 33xx series problem. Regards |
01-13-2003, 18:13 | #3 (permalink) | |
Member deceased !! Join Date: May 1999 Location: Wien/Austria Age: 65
Member: 5 Status: Offline Thanks Meter: 1,884 | Re: 2 x 3310 with PA problem Quote:
next i`ll warn you. | |
3310 with light problems!!! | sergioems | Nokia Hardware & Hardware Repair | 16 | 08-09-2004 10:17 |
3 3310 with same problem today | .::AkhavanGSM::. | Nokia Hardware & Hardware Repair | 5 | 08-08-2003 08:57 |
nokia 3310 with this problem? | cut_r2000 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 06-18-2003 23:18 |
3310 with network problem | VREDNYJ | Nokia Hardware & Hardware Repair | 3 | 09-14-2002 16:03 |
