08-28-2002, 16:00 | #1 (permalink) |
No Life Poster Join Date: Feb 2002 Location: Portugal- Center of Europe Age: 42
Member: 9502 Status: Offline Thanks Meter: 9 | 3310 with light problems!!! thanks in adavance Last edited by willy; 08-29-2002 at 06:19. |
08-29-2002, 06:14 | #2 (permalink) |
No Life Poster Join Date: Apr 2001 Location: Croatia Age: 45
Member: 4185 Status: Offline Thanks Meter: 3 | Replace the only IC on the pcb that is outside of the metal protection..... Its located on the lower right side of the pcb,black,and its 20 pin IC....its written NMP......... on it........ Work 100%.......... |
08-29-2002, 07:04 | #3 (permalink) | |
No Life Poster Join Date: Mar 2000 Location: inside NOKIA phone Age: 58
Member: 1060 Status: Offline Thanks Meter: 10 | sergioems <p><center><A href="http://imagehost.auctionwatch.com/bin/viewimage.x/00000000/demetan1/3310dig1.jpg"><img src="http://imagehost.auctionwatch.com/bin/imageserver.x/00000000/demetan1/.mids/3310dig1.jpg" <br><br><br> Click image to view larger version</font></A></center> Upper show to you where is N400 ! <p><center><A href="http://imagehost.auctionwatch.com/bin/viewimage.x/00000000/demetan1/N400_led.jpg"><img src="http://imagehost.auctionwatch.com/bin/imageserver.x/00000000/demetan1/.mids/N400_led.jpg" <br><br><br> Click image to view larger version</font></A></center> Here, you have to also check R407 and R406,, is it short to GND ! Willy Quote:
09-01-2002, 23:06 | #6 (permalink) | |
Member: 1060 Status: Offline Thanks Meter: 10 | Wesam, as member george gsm said:" even with phone off the four leds of display are always light on." Is it flash phone will work ? i do not think so it must be HW problem, not SW ! Willy Quote:
09-02-2002, 00:47 | #7 (permalink) |
Insane Poster Join Date: Jul 2002 Location: Egypt Age: 45
Member: 14194 Status: Offline Thanks Meter: 4 | Dear Willy I'm shure that your experince is very big than me and i'm happy to learn from you . i tried to flash more than one phon was with 4 leds light and it's sucssesifull thank's Wesam |
09-02-2002, 17:26 | #8 (permalink) |
No Life Poster Join Date: Jun 2002 Location: Iran Age: 47
Member: 12724 Status: Offline Thanks Meter: 30 | I also agree with willy. It can be caused by water damages. Also I think wesam is right. I had a 3310 wich was dead.I flash and it bacame alive,but no 1 did not work. I thought it was HW but after reflashing the phone , the problem was solved. I am waiting for other answers. GOOD luck LIGHT |
09-02-2002, 17:43 | #9 (permalink) | |
Member: 1060 Status: Offline Thanks Meter: 10 | Hello GSM Light, thanks ! of casue, we have to make sure, that phone SW has no problem,, then we go HW ! Is it any 3310 or NOKIA phone ,, just put battery, without switch it on,, and phone will have 4 led light up ? Willy Quote:
10-26-2002, 12:53 | #12 (permalink) |
No Life Poster Join Date: Oct 2001 Location: No route to host. Age: 44
Member: 6772 Status: Offline Thanks Meter: 17 | I'm 10000% agry with Willy! Just look at the schematics!!! Tottaly imposible that lights could lit on sw problem unless MCU hangs. But If phone turns on . I'm 100000n% sure that it is hardware failure. N400 has two inputs LCDLED and KBDLED that are interconnected. Only if you have potential more then 0.7v on those pins the LEDs should lit. WBR B0BA |
08-06-2004, 01:29 | #13 (permalink) |
No Life Poster Join Date: Jan 2000 Location: NL Age: 55
Member: 847 Status: Offline Thanks Meter: 36 | Hi, has same problem. 4 leds lcd burn with phone turned off, changend N400 same. removed R406 and all is ok. Whats function off R406, i see no difference after removing it. All is ok. Thanks Sjakie |
3 3310 with same problem today | .::AkhavanGSM::. | Nokia Hardware & Hardware Repair | 5 | 08-08-2003 08:57 |
nokia 3310 with this problem? | cut_r2000 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 06-18-2003 23:18 |
2 x 3310 with PA problem | Black-Axe | Nokia Hardware & Hardware Repair | 3 | 01-13-2003 18:13 |
3310 with network problem | VREDNYJ | Nokia Hardware & Hardware Repair | 3 | 09-14-2002 16:03 |
problem with 3310 keypad light | frigor1 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 11-06-2001 20:09 |
